NEW TUNDRA TIRE OPTIONS
Discussion in 'Wheels & Tires' started by Fiestee23, Jun 30, 2017.
  1. Jun 30, 2017 at 3:23 PM
    Fiestee23
    Fiestee23 [OP] A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    OK GUYS IM NEW TO THE TUNDRA FORUM BECAUSE MY TRUCK IS A WEEK OLD. ALREADY STARTED THE MODS AND WILL POST SOME PICS SOON. I TRADED MY TACOMA IN THAT WAS WELL VERY MODIFIED.
    HERES THE QUESTION THOUGH... I AM GOING TO LEVEL THE TRUCK. 3/1 PRO COMP LEVELING KIT JUST BECAUSE I DONT WANT TO VOID ANY WARRANTIES QUITE YET. IM GETTING DIFFERENT SUGGESTIONS WITH TIRE SIZES. IM THINKING 295/70R18 BUT IS THIS REALISTIC WITH JUST THE LEVELING KIT? DOES ANYONE HAVE PIX OF THIS SET UP? IVE LOOKED ON THE FORUMS BUT THERE IS JUST AN ABUNDANCE OF ANSWERS, I JUST WANT TO SEE IT. 4WHEEL PARTS IS SUGGESTING THE 275/70R18 AND I JUDT DONT THINK THATS ENOUGH FOR THIS TRUCK. POST THE PIX ON THE PAGE IF YOU CAN
  2. Jun 30, 2017 at 3:36 PM
    PaRunnerd
    PaRunnerd No N00B, No Pro.
    Dave
    Lehigh Valley, PA
    2014 Magnetic Gray Tundra SR5
    Plenty planned thanks to all of you.
    Law323, T-Rex266 and SouthBoundSteve like this.
  3. Jun 30, 2017 at 4:06 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    ^^ WHAT HE SAID! WELCOME BY THE WAY!
  4. Jun 30, 2017 at 6:22 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Welcome Fiest. Depends on your offset. What wheels do you have?
  5. Jun 30, 2017 at 6:49 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Welcome. No need to YELL. We're all friends here :)
    +1 on those links from @PaRunnerd and @WarEagleSteve. You'll often hear admonishments about using the search tool, but I'm with you. Far too many search results to attempt to wade through, particularly about tires.
  6. Jun 30, 2017 at 9:53 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    295/70/R18 (that's almost 35s)would look sharp with a 3 inch lift.
    Fiestee23[OP] likes this.
  7. Jul 11, 2017 at 8:27 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    I think so. I seen a few on here with an +18mm off set so I went ahead and ordered 18x9 with +18 offset and cross my fingers... lol. Ill post some pix when that stuff is done. Just getting the bumper swapped, a TRD grill, and the steps on this week when I find time.
  8. Jul 11, 2017 at 8:30 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    ProComp has lift shield warranties on all their 6 in lifts that covers everything that Toyota's warranty does. If that helps
    Fiestee23[QUOTED][OP] likes this.
  9. Jul 11, 2017 at 8:33 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Don't have much knowledge but a lot of guys in here will chime in...and btw welcome from mo
  10. Jul 11, 2017 at 8:34 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Thank u
    SlickRick2013Tundra likes this.
  11. Jul 27, 2017 at 9:14 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Here is is with the 295/70r18 +183880bb2f87d938a61e238cb04339e11c_a6a8c9c8d915f07f7bdff0ddc9356bcd46826a60.jpgf323be620e52dfc1b1cb58af4345e479_98f57cee9572ef417d07d299d0f4506de0274393.jpg
    dbeacham15, Law323, drhntr and 2 others like this.
  12. Jul 31, 2017 at 2:36 PM
    cmrock
    cmrock New Member
    Connor
    Vancouver Wa
    2014 Bronze 1794
    Lets see more!!!! :) Looks great! I was thinking about doing the same wheel setup except 25 offset. Was going to put a 2.5/1 on my truck and unsure if they will fit or not....
  13. Jul 31, 2017 at 4:17 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Honestly... wish I had less of an offset I think. Front sits a bit inside the flare but rear sits even. but I have a 3/1 level
  14. Sep 10, 2018 at 1:50 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Screenshot_20180909-203704.jpg IMG_20180908_115838.jpg So... The Atturo tires... First time on rock, gravel, sand this past weekend and they did really well. The guys aired me down to 30PSI and it softened them up nicely. No weird cuts or gouges in them after the ride. The Raceline wheels also did well. No scratches on them either. And we made it home, cleaned it all up and they are as good as new. Thanks to all the guys on the ride I wasn't bouncing all over the damn place. Lol
    Marty McFly, JoshuaA and sr5shark like this.
  15. Sep 10, 2018 at 2:02 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Um, I know you went on a different trail on the way to Oktoberfest, did you air back up at some point?
    Marty McFly likes this.
  16. Sep 10, 2018 at 2:52 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Yes I did. Right when I got outta the dirt
  17. Sep 10, 2018 at 3:13 PM
    jordanpop1
    jordanpop1 New Member
    Alright so here is what I’ve found as ideal large tire size relevant to your 3/1 lift
    18” wheel - +18mm to +30mm offset you can fit 295/70r18 with removal of mud flaps, and trimming or manipulating of the front fender wells. You may or may not need a cab mount chop. You can also fit a true 35x12.5r18 however a cab mount chop is basically guaranteed, removal of mud flaps, and fender manipulation. It is unclear if you will rub still though at full lock/full bump. I’d imagine you will. So if you plan to offroad maybe avoid the 35x12.50
    17” wheel - +18mm to +30mm same tire selection but on a 17” wheel. Ideal is a 17” wheel with a +25mm offset and a 315/70r17 tire. This is actually claimed by Icon to not need any trimming/cab mount etc. at full lock full bump.
    Popular choice - 18x9 wheel with +18 to +30 and a 295/70r18 tire. It does require a bit of trimming but it seems to be the most desirable of choices.
    Hope this helps. I ordered my TRD pro today and am going with Fuel Vector 18x9 wheels and 295/70r18 Nitto ridge grapplers.
  18. Sep 10, 2018 at 3:23 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    295/70/18 Toyo MT's Offset +18
    parker44 likes this.
  19. Sep 10, 2018 at 3:53 PM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    WHY IS EVERYONE YELLING?
    I LOVE LAMP!!!!
