School a new guy
Discussion in 'Suspension' started by P-funk, Sep 4, 2018.
  1. Sep 4, 2018 at 5:24 AM
    P-funk
    P-funk [OP] New Member
    Parnell
    2018 Tundra CM TRD Off Road
    I want to lift my 18' CM. Gonna go with bilstiens and was told by a truck shop 5100s in the back would give me a 1" lift. Is this correct? Everyone seems to be using shackles and he never mentioned or quoted them. I want a 2" lift in the front and a 1" to 1-1/2" in the back to maintain some rake. I'm pretty sure I need shackles but wanted to ask the pros.
  2. Sep 4, 2018 at 5:27 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Rear shocks wont provide any lift. To achieve lift, you have several options: replace entire leaf pack, add-a-leaf, shackles, or blocks. Blocks would be the least desirable.
    Lake.Life24 and equin like this.
  3. Sep 4, 2018 at 5:39 AM
    P-funk
    Parnell
    Thanks. If I go the shackle route I'll get CB or toytec. How about leaf pack recommendations?
  4. Sep 4, 2018 at 6:43 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    Icon, Deaver, Alcan or have a local shop rebuild/custom make you a set. Going with a aftermarket set of leaf packs may still require the use of aftermarket shackles.
    Check the Toytec website. Pretty sure I saw the new Icon leaf pack on there as well as Deaver.
    Deaver has two different Tundra spec packs: K-37 and U748 which offer different load capabilities.
    Both Deaver and Alcan offer a custom pack based on your requirements. You would have to provide loaded axle weights for them to make you a pack.
    The new Icon pack looks pretty solid. It offers different load capabilities by adding or removing the overload leaf IIRC.
    Lake.Life24 likes this.
