Tire repair
Discussion in 'Wheels & Tires' started by Bappa, Aug 30, 2018.
  1. Aug 30, 2018 at 4:29 PM
    Bappa
    Bappa [OP] Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    This morning on the way to work I saw that I picked up a screw in the tire and it was leaking about 2 lbs per hour. Since I was going right past the dealer (where I bought my 2018 CrewMax about 6 months ago), I stopped to see if it was covered. They said when you drive off the lot, the tires are your responsibility. We will fix it for $35.
    I said no thanks and went to Discount Tires. They fixed it right away and said, “No Charge”
    That’s what I’m talking about!
  2. Aug 30, 2018 at 6:48 PM
    Nick T
    Nick T New Member
    $35 Would mean the dealer will repair it correctly by dismounting the tire, install a plug patch on the leak remount and balance.
    No charge means they just plugged the leak. You want a plug patch not just a plug, the only way to install a plug patch is to remove the tire as the patch part is adhered to the inside of the tire.
  3. Aug 30, 2018 at 6:53 PM
    Rica25
    Ricardo
    Tulare
    I work at dealer and we see so many comeback do get done the right way just sayin
  4. Aug 30, 2018 at 7:01 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Discount Tire will not plug tires.
    sprtbkr and ColoradoTJ like this.
  5. Aug 30, 2018 at 7:28 PM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    True! Discount Tire only does it the right way. They're actually a really good company.
    Grumpy Uncle, equin and ColoradoTJ like this.
  6. Aug 30, 2018 at 7:29 PM
    I buy all my tires from them. Definitely not always the cheapest, but service is second to none.
    Grumpy Uncle and sprtbkr[QUOTED] like this.
  7. Aug 30, 2018 at 7:30 PM
    sprtbkr
    Scott
    Denver, CO
    They will negotiate and beat other deals and match Costco.
  8. Aug 30, 2018 at 7:33 PM
    That they will. Usually its only a few dollars. I get treated very well.
    sprtbkr[QUOTED] likes this.
  9. Aug 31, 2018 at 5:11 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
    I think my dealer is pretty good as far as dealers go, but I’ll take Discount Tire for tire matters any day of the week over any dealer. I’ve been dealing with the same branch for 13 yrs and have always had excellent service.
  10. Aug 31, 2018 at 5:19 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'll be the outlier, I've plugged a dozen or so tires with a Safety Seal kit and never had a leak. It's a lot more convenient than pulling the wheel or taking it in for service.
    equin and OBXTundra like this.
  11. Aug 31, 2018 at 6:08 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    ^x2
    I've plugged quite a few tires on different vehicles. I've had no issues at all. Never had them leak. Never had them come back out.
    Had a brand new set of tires on my Ridgeline in 2008. Screw in the tire 1 week later. 2 more plugs over the next 2 years. 40k miles and a new set of tires later.....never an issue.
    I've only ever plugged nail and screw holes. If it was a chunk of debris then I had it patched if possible.
  12. Aug 31, 2018 at 6:21 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Most of the bigger tire companies only do patches due to liability. I worked a short time at tire kingdom and if the boss found a plug kit in one of the tech's boxes, they'd be in some hot water.
    OBXTundra likes this.
