Assistance requested to troubleshoot intermittment ac/heater blower issue?
Discussion in '2nd Gen Tundras (2007-2013)' started by chugs, May 30, 2018.
  1. May 30, 2018 at 9:22 AM
    chugs
    chugs [OP] New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    2007 Tundra. Sympton: Blower switch occasionally does not turn on the blower motor. Cycling switch, nothing. Sometime it works and sometimes it doesn't. Had to reach in blower motor to manually spin it once to get it going, and then another occasion attempted to spin it and didn't work at all. So before I start buying replacement parts, any methods to troubleshoot/isolate, test and check switch and blower motor? Thanks.
  2. Aug 30, 2018 at 1:36 PM
    Thinnius
    Thinnius New Member
    Pinon Hills, Ca
    08 TRD Tundra 5.7 - 4x4
    Did you end up finding out what was wrong with your blower? Having the same issue. The blower motor sometimes runs at a very slow speed.
  3. Aug 30, 2018 at 4:30 PM
    chugs
    Ciao
    Central Cali
    Replaced blower motor no issues since then. It was about $100 and replaced cabin filter as well. Easy to replace a few screws and a connector.
  4. Aug 30, 2018 at 4:48 PM
    Thinnius
    Thinnius New Member
    Pinon Hills, Ca
    Awesome. Thanks for the reply.
    chugs[OP] likes this.
  5. Aug 30, 2018 at 4:50 PM
    chugs
    Ciao
    Central Cali
    No problem.
  6. Aug 31, 2018 at 4:52 PM
    Trhomas25
    Trhomas25 New Member
    2012 Tundra
    I also just replaced mine after it went out on me. I didn’t have the intermittent issues, it just stopped blowing a few days ago. There are good videos on YouTube that show this. Remove a panel and three screws. Extremely easy
