Heavy Duty tundras
Discussion in 'General Tundra Discussion' started by tenntundra, Aug 28, 2018.
  1. Aug 29, 2018 at 1:57 PM
    Sunnier
    Sunny
    San Diego, CA
    @GNTundra
    GNTundra likes this.
  2. Aug 29, 2018 at 2:49 PM
    Sunnier
    Sunny
    San Diego, CA
    So bright and shiny, I thought of you. I know you like pretty things! :)
  3. Aug 29, 2018 at 4:45 PM
    6point8
    6point8 New Member
    James
    Here's my 2007 SR5 with 178,000. I've only had to replace front axles, starter, and u-joints. Only thing I ever complain about is 280miles to a tank of fuel.00000IMG_00000_BURST20180826141818452_COVER.jpg
    Northernheat, equin, Trooper2 and 2 others like this.
  4. Aug 29, 2018 at 8:58 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    What I want in a Tundra (as an option):
    240A alternator
    Full-floating rear axle with some extra ribs in the carrier and housing
    3-inch wide leaf springs
    Stronger frame (at least aft of the cab)
    Slightly larger front differential (The weight rating of the AAM 9.25" in the front of a gas powered Chevy 2500 is only 4400 lbs, not much more than the 3950lbs of the Tundra 8.7" front differential)
    equin and UpSteer32 like this.
  5. Aug 29, 2018 at 9:21 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    IMG_2401.jpg ‍♂️
    equin likes this.
  6. Aug 30, 2018 at 6:01 AM
    Rica25
    Ricardo
    Tulare
    Wow that's pretty bad I am little over 300 with 295 70 18 and a lot more before I switched to this tire size
  7. Aug 30, 2018 at 8:37 AM
    UpSteer32
    UpSteer32 New Member
    I can' talk too much about GM's current stuff. Personally, I prefer to see a solid front axle for a HD truck. All the problems you're referring to for the older trucks don't surprise me. The domestic OEM trucks weren't well-built back then. Nowadays, I think the build quality is much better, at least in the 3/4 and 1 ton market segments. 1/2 ton trucks I still think are under-built, with the Tundra being the main exception.
    equin likes this.
  8. Aug 30, 2018 at 9:05 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Looks like about 40 bundles of shingles there. 70 lbs per bundle. 2800 lbs. Plus whatever is under the tarp....plus the driver.
    Payload is around 1600ish.
    Way to go.
    :facepalm::annoyed:
  9. Aug 30, 2018 at 9:22 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Curious, but what happened to your front axles? Boots or the axles themselves snapped? Also, what happened to your u-joints that required replacement?
  10. Aug 30, 2018 at 2:35 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    30 bundles and just a tarp But yeah :annoyed:
  11. Aug 30, 2018 at 3:12 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    O.K.
    Last Spring, pallet of bagged mulch from Lowes, weight unknown, about a mile drive.
    Got Mulch?
    Alexstundra and equin like this.
  12. Aug 30, 2018 at 3:38 PM
    6point8
    6point8 New Member
    James
    Driver side axle caught a piece of wire and ripped the CV boot, passenger side came apart completely. Carrier bearing went out and I believe that's what did the u joints in..all easy fixes. Except the starter, that was a pain. Horrible location
    equin[QUOTED] likes this.
  13. Aug 30, 2018 at 3:50 PM
    6point8
    6point8 New Member
    James
    Now 280 is when the fuel light comes on, I always put in 21 gallons. So I figure there is 5 more gallons actually left in the tank, which would put me kicking pavement at about 340 miles total. Figuring the 12mpg LOL
  14. Aug 30, 2018 at 6:42 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Haha nice I like it. That's a lot of weight. I know I didn't wanna do a full pallet of mulch bc they were really wet but well done just be careful drivin
    Trooper2[QUOTED] likes this.
