Why is 2018 Platinum ride so much better than my current Tundra?
Discussion in 'Suspension' started by mcchase, Aug 29, 2018.
  1. Aug 29, 2018 at 7:20 AM
    mcchase
    mcchase [OP] New Member
    chase
    A little about my truck 1st. 2010 with Bilstein 6112 at 2nd highest setting. Toyo 295/60/20 on stock platinum wheels. Rears are Fox 2.0 which I just put on a few weeks back to replace Bilstein 5100. Front setup probably has 15k miles on it.
    I replaced rear shocks even though they only had around 10k miles on it. The fox improved the ride a little.
    I test drove a 2018 platinum and was surprised at how much better it road. Made my current tundra feel like my old f250, well not that bad really, but still was surprised at the stock platinums shocks handled better even down washboard roads than my “upgraded” suspension
    Are my Bilstein 6112 shot at 15k miles? Is there something else I could be messing up the ride? Do the 3rd gens just ride that much better than 2nd gen. Maybe I’m just getting old...
  2. Aug 29, 2018 at 7:22 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's your tires VS stock that made the 2018 feel better.
    YTThao530, joonbug, Vendeta2k and 6 others like this.
  3. Aug 29, 2018 at 7:30 AM
    mcchase
    chase
    I do realize the p rated tires would improve my ride but didn’t think it would be that much difference.
  4. Aug 29, 2018 at 8:52 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Tires make a huge difference. Even just tire pressure.
    GNTundra, Marty McFly and Prostar 190 like this.
  5. Aug 29, 2018 at 9:05 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    The Platinum seats make a big difference as well .
  6. Aug 29, 2018 at 9:10 AM
    TheBeast
    TheBeast The Beach
    tires, creature comforts
    Prostar 190 likes this.
  7. Aug 29, 2018 at 9:16 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I haven't checked out a 2018 but my 2015 Platinum came with mush for shocks. Nice soft ride, sucky for handling. Maybe that made the difference?
    Pudge likes this.
  8. Aug 29, 2018 at 9:26 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    My guess tires and suspension. You have off road tuned suspension and I would guess different rated tires.
    GNTundra and 15whtrd like this.
  9. Aug 29, 2018 at 10:23 AM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    those seats in the Platinum and the 1794 are awesome! much better than the regular leather seats.
    Pudge likes this.
  10. Aug 29, 2018 at 10:35 AM
    mcchase
    chase
    Is there anything else in my suspension that might be causing the jittery ride. Truck has 120k miles. Shocks were placed a few years back but only 10k miles on them. I feel like it has gotten worse recently. Think the shocks could be shot already or is there something else I’m not thinking of. And how do I check if front shocks are bad?
  11. Aug 29, 2018 at 10:46 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe you need to drop a few psi tires. Are your current shocks at the top setting? That stiffens is it up as well.
  12. Aug 29, 2018 at 11:29 AM
    TheTripleLindy
    TheTripleLindy New Member
    i have a 18 1794 edition that i swapped the shocks to bilstein and the tires to a heavy tread at; it is more than likely shocks and tires. My ride is different now. Tighter, louder, but better on the bigger potholes.
  13. Aug 29, 2018 at 11:58 AM
    mcchase
    chase
    I’m on 2nd highest setting on the 6112. But I’ve been on this setup for over a year but feel like it has gotten worse in the past few months. Tires are at 40psi. How low can you run load e tires safely on road?
