3rd brake light
Discussion in '2.5 Gen Tundras (2014-2021)' started by robzillaaa, Aug 24, 2018.
  1. Aug 24, 2018 at 1:31 PM
    robzillaaa
    robzillaaa [OP] New Member
    Anyone have a video or tutorial on how to replace a 3rd brake light on a 3rd gen?
  2. Aug 24, 2018 at 1:34 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The whole light fixture? Or just the bulbs?
    The whole thing is a pain in the a$$ you need to drop the headliner
    aperezsh likes this.
  3. Aug 24, 2018 at 1:37 PM
    robzillaaa
    I wanted to do the whole thing to match all the other spyder lights.
  4. Aug 24, 2018 at 1:45 PM
    Pudge
    CT
    It's a lot of work from what I gather.
    Might be worth just installing good LEDs and tinting the cover with vinyl or spray tint.
    I actually was thinking about adding LED brake bulbs in there that give some quick flashes before going solid on for increased visibility.
  5. Aug 24, 2018 at 1:54 PM
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    I added LED bulbs to mine only thing is make sure rubber gasket it back correctly. From what I gather people that replaced the whole thing ended up with water leaking into the cab from rain getting in. I think @Pudge had a great solution in my opinion.
    NorCalTrdsport and Pudge like this.
  6. Aug 24, 2018 at 2:03 PM
    They make a bulb that does that or do you have to add something to make it flash?
    That is on my list. I only know of a module that does that.
    Pudge[QUOTED] likes this.
  7. Aug 24, 2018 at 2:10 PM
    Pudge
    CT
    I saw some bulbs on Amazon that do that. Some were constant strobe some do like 5 flashes then solid red
  8. Aug 24, 2018 at 2:11 PM
    I like the 5 flashes then solid. Do you have a link?
  9. Aug 24, 2018 at 2:12 PM
    Pudge
    CT
    I'll try and find it. The bulb is 921 right? @Jim LE 1301
  10. Aug 24, 2018 at 2:17 PM
    Yes
  11. Aug 24, 2018 at 2:18 PM
    Pudge
    CT
  12. Aug 24, 2018 at 2:23 PM
    I was was looking at these on Ebay
    192534636693
    Pudge likes this.
  13. Aug 24, 2018 at 2:26 PM
    Theses mods sure do add up fa$t
    Pudge likes this.
  14. Aug 24, 2018 at 2:27 PM
    Pudge
    CT
    Yes sir they sure do
  15. Aug 24, 2018 at 2:45 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Here is the instruction on removing your headliner if you want to replace the 3rd brake light. It’s a lot of work for sure. Steps you will need to do.
    1. Disconnect battery. Your working near your side curtain airbags so I would recommend this to be safe.
    2. Take off your two front sun visors.
    3. Remove both the the roof grab bars. These are the biggest pain about this whole project. They are not easy to get them off without messing them up.
    4. Remove the rear, mid and front upper pillar trim pcs that butt up to the headliner.
    5. Unscrew the front and center overhead cab lights.
    6. You will want to be wearing clean latex gloves before you touch your roof liner. Any oils on your hands will leave finger print marks. Now you can reconnect the battery to lower your rear window. This is how the hood liner will be removed.
    7. Once the liner is dropped you have to be careful because it large and it will bend. So it can cause a crease in it if your not careful.
    8. Now you should have access for the two 10mm bolts inside above the liner to detach and unplug the 3rd brake light.
    9. Install the new light and repeat all the previous steps.
    I went ahead and did the sound deadening and a layer of 1/4” sound insulation since I had the roof liner off. It’s the best time to do it. I hope this helps you if you decide to do this mod. 3A15040B-9050-429D-9564-12C00CFAA438.jpg
    Pudge and aperezsh like this.
  16. Aug 24, 2018 at 2:53 PM
    Guess I won't be changing mine.:rofl:
    Pudge, aperezsh and 1UPPER[QUOTED] like this.
  17. Aug 24, 2018 at 3:19 PM
    War Machine
    War Machine SSEM # 5 3MW
    So led bulbs and vinyl tint. Got it.
  18. Aug 24, 2018 at 3:21 PM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    It is a pain. If you do, make sure you seal it correctly or it will leak!!
    Jim LE 1301 likes this.
  19. Aug 24, 2018 at 3:21 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Looks like a swift kick in the nutz would be more fun..:rofl:
    Pudge, Jim LE 1301 and 1UPPER like this.
  20. Aug 24, 2018 at 3:35 PM
    1UPPER
    TEXAS
    Flux capacitor!
    That’s the short and simple way to keep from loosing 4hrs or your life. Lol
    Pudge and Jim LE 1301 like this.
  21. Aug 24, 2018 at 4:23 PM
    Pudge
    CT
    I would only do this if you had another reason to be dropping the liner. Such as sound dampening, roof rack install, roof lights....then maybe it's worth the work to do the 3rd brake light while your at it.
    Some day I wanna sound deaden my roof and this post will be very helpful. Thanks 1upper
    1UPPER[QUOTED] likes this.
  22. Aug 24, 2018 at 6:02 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Your welcome. I had my recon led third brake light for over a year before I finally installed it. I decided to wait until I did my roof rack and sound deadening. It was a royal PITA project for sure.
    aperezsh and Pudge[QUOTED] like this.
  23. Nov 15, 2018 at 10:23 PM
    NorCalTrdsport
    NorCalTrdsport New Member
    2018 MG TrdSport
    I just put some led bulbs in up there about an hour ago. I heard the gasket peel off of the housing but was almost still on the cover. Went to put the cover on and the gasket was all over the place. Damn near impossible to get it to stay long enough to get the cover back on. Read up a lil hear after looking at new cover options... decided to get some gorilla glue, a toothpick, and tac it back down. Took less than 5 min to seal it properly all around.
    It was when I read in your post about water in cab... that's all I had to see lol I've had that issue before with a sunroof and dont ever want that hassle again. I know you were talking about replacing the whole assembly and the leak but it was enough for me to make sure my cover was sealed properly lol.
    jewsNbrews likes this.
