tailgate assist
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, May 22, 2016.
  1. May 22, 2016 at 2:11 PM
    TheBeast
    TheBeast [OP] The Beach
  2. May 22, 2016 at 3:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Your truck should have one tucked up under the driver's side bedside that I would suspect you could simply replace. Is there some reason that you would not wish to peruse that route?
  3. May 22, 2016 at 3:56 PM
    TheBeast
    I wasn't sure there was any. It might be used and needs replacement.
  4. May 22, 2016 at 4:20 PM
    Both my tundras had this already...pretty sure it was standard.
    15whtrd likes this.
  5. May 22, 2016 at 4:26 PM
    TheBeast
    thanks. I'm having hard time finding part online or even diagram for a 2012 Tundra.
  6. May 22, 2016 at 4:28 PM
    Roman and TheBeast[OP] like this.
  7. May 22, 2016 at 4:37 PM
    15whtrd
    15whtrd Mr. Blonde
    I haven't looked but I'm pretty sure you need to remove the driver side tail light. Remove it and see if you can find a comparable replacement in length.
    TheBeast[OP] likes this.
  8. May 22, 2016 at 7:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  9. May 22, 2016 at 8:51 PM
    TheBeast
    thanks !
  10. May 23, 2016 at 10:02 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Rica25 and TheBeast[OP] like this.
  11. May 26, 2016 at 1:16 PM
    TheBeast
    fixed under warranty :) much better now.
    Rica25 likes this.
