35-12.5-18's
Discussion in 'Wheels & Tires' started by Silv333, Aug 19, 2018.
  1. Aug 19, 2018 at 8:07 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Hey guys, my plan for my 18 Tundra is the following, wanting to know if you guys think they'll fit;
    - 6112's in front at either 1.9 or 2.5
    - 5160's in rear
    - These rims;
    https://www.stealthcustomseries.com/products/sr8
    - 35-12.5-18 Goodyear Wrangler Duratracs (getting a hell of a deal on them)
    Do you guys think they'll fit with minor trimming? Thanks in advance. :oldglory:
  2. Aug 19, 2018 at 8:43 PM
    TheBeast
    TheBeast The Beach
    you 'll probably need CMC
    zcarpenter92 and 831Tun like this.
  3. Aug 19, 2018 at 9:06 PM
    Silv333
    NJ-NC-MD-NC
    CMC?
  4. Aug 19, 2018 at 9:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Totally agree with @TheBeast . SCS is a great wheel choice 'cause they're hub centric.
  5. Aug 19, 2018 at 9:08 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Cab Mount Chop, no big deal, sounds a lot worse than it is. Relentless or Bamf sell the plates that get welded in.
    TheBeast likes this.
  6. Aug 19, 2018 at 9:28 PM
    Rica25
    Ricardo
    Tulare
    I had to do BMC on with 295 70 18 +12 offset
  7. Aug 19, 2018 at 9:30 PM
    Silv333
    NJ-NC-MD-NC
    Damn I was trying to avoid having to do that.
  8. Aug 19, 2018 at 9:31 PM
    Rica25
    Ricardo
    Tulare
    Just got it done about a month ago wasn't bad 200 bucks
  9. Aug 19, 2018 at 9:37 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    would 34s need CMC?
  10. Aug 19, 2018 at 9:42 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    With the + 25 offset, probably.
  11. Aug 19, 2018 at 9:45 PM
    TundraLaw
    Northern Nevada
    There are so many conflicting stories about whether 295/70/18 requires CMC on a +18. Some say yes, some say no; but the usual consensus is no CMC
    Fiestee23 and 831Tun like this.
  12. Aug 19, 2018 at 9:48 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I didn’t need one with +12 offset wheels. The alignment numbers play a part in it as well, on stock arms with less than 3* of caster it doesn’t seem to needed.
    831Tun likes this.
  13. Aug 19, 2018 at 9:48 PM
    Rica25
    Ricardo
    Tulare
    Mine was very minor rub but was there so didn't want to ruin tires and had it done
  14. Aug 19, 2018 at 9:49 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I needed one. Caster plays a part in this too. I needed the CMC with 2* of caster and 295s. I'm now at 4.5*caster with 35s and am rubbing the back of the fender occasionally.
  15. Aug 19, 2018 at 10:02 PM
    Silv333
    NJ-NC-MD-NC
    I know this is a huge debate as well, but any affect on the factory warranty?
  16. Aug 19, 2018 at 10:13 PM
    Rica25
    Ricardo
    Tulare
    2008 so dont matter to me .....I have had it since new
  17. Aug 19, 2018 at 10:35 PM
    Silv333
    NJ-NC-MD-NC
    Any idea if it messed up your factory warranty by doing one?
    831Tun[QUOTED] likes this.
  18. Aug 19, 2018 at 10:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't honestly know. It really doesn't have any effect on the truck other than creating clearance. It's not very noticeable and most dealers won't even know it's been done. It's said that the dealer must prove the modification caused the problem in order to refuse a warranty claim. That said, I think it depends on the integrity of the dealer.
    Fiestee23 likes this.
  19. Aug 19, 2018 at 10:54 PM
    Silv333
    NJ-NC-MD-NC
    Copy, thanks
  20. Aug 19, 2018 at 11:15 PM
    Silv333
    NJ-NC-MD-NC
    Guessing you just get it done at your local truck shop?
  21. Aug 20, 2018 at 7:06 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I had a fabricator friend do mine. There's a 4x4 shop near me and I think they could've done it too but, I don't think I'd have someone like 4WP do it.
    TheBeast and dcsleeper408 like this.
  22. Aug 20, 2018 at 8:48 AM
    TheBeast
    TheBeast The Beach
    for the cost of tires and rims, cmc is cheap insurance. get the bigger tires you want now so you don't spend twice when you want to go from 33's to 35's :) depending where you are located I'm sure you can find a good fab guy
    831Tun likes this.
  23. Aug 20, 2018 at 9:11 AM
    TundraLaw
    Northern Nevada
    At the same time though, if 275/70/18 with 2 inches of lift is your thing, and you can reap the benefits of smaller tires (better MPG, less strain on bolts, brakes, functionality) then do it.
    275/70/18 is a sick combo, and with the right lift you'll appreciate the truck just as much.
    parker44 likes this.
  24. Aug 22, 2018 at 10:20 AM
    kingkabong
    kingkabong New Member
    Eric
    Parker, CO
    2016 Tundra DC
    I'm leveled (pro suspension). Put Icon wheels on, which are +25 offset and fit 315/70-17s without a BMC. Just removed the plastic shit.
