Best coilover suspension 3-3.5” for under $1,000?
Discussion in 'Suspension' started by 16cmt, Aug 20, 2018.
  1. Aug 20, 2018 at 12:41 AM
    16cmt
    16cmt [OP] New Member
    Portland Oregon
    2016 Sr5 Crewmax
    best coilover suspension 3-3.5” for under $1,000 and go!
    currently 3/1 level
  2. Aug 20, 2018 at 1:22 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Old man emu, very simple and reliable setup that tons of people run
  3. Aug 20, 2018 at 3:04 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Check out Toytec.They have a couple of lifts under $1K.
    16cmt[OP] likes this.
  4. Aug 20, 2018 at 9:53 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Have you checked out Toytec/ Eibach 3'' front coilover setup?
    Nice simple front coilover system that yields 3'' of front end lift, all bolt on application and will give the proper stance and ride quality without messing with spring rates. Shoot me a pm if you have any questions!
    Thanks
    16cmt[OP] and Stroke250 like this.
  5. Aug 20, 2018 at 9:56 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    What is your current setup? Spacers/blocks?
    16cmt[QUOTED][OP] likes this.
  6. Aug 20, 2018 at 11:47 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I would probably look at the Eibach kit through Toytec. Roughly $800 and comes fully assembled already, just swap them out.
    16cmt[OP] and Toytec Lifts like this.
  7. Aug 20, 2018 at 3:16 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    That Toytec/Eibach Kit is a great price at $475. You may also want to look into the Bilstein 6112’s or the Fox 2.0 stuff.
    16cmt[OP] and OBXTundra like this.
  8. Aug 20, 2018 at 10:06 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    factory trd off-road suspension with 3-1 level. the front shock busted and i need something fast. icon stage 1 maybe. how well are the bilstine 6112 and the ome compared to the icon stage 1? anyone know?
  9. Aug 20, 2018 at 10:57 PM
    ertlonggun
    ertlonggun New Member
    2013 Dbl cab grey TRD
    TRD air filter TRD air flow accelerator Dirty Deeds budget SS Exhaust Worx wheels Roadmaster active suspension (rear) P-3 brake controller 3” Toyotec lift w/ shackles 35” Nitto Ridge Grapplers
    I put this lift kit on my 2013 tundra in July, promptly went to the desert handled all types of terrain much softer and smoother than the TRD off-road suspension that my truck came with. Put 35 x 11” wide Nitto ridge grappler’s couldn’t be happier with the whole set up
  10. Aug 20, 2018 at 11:19 PM
    TexasTundra27
    Mark
    I started with the Icon stage 1, loved it. I’d say the better option that has been mentioned since it’s rebuildable and all.
  11. Aug 21, 2018 at 4:43 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Toytec/Eibach 3/1.
  12. Aug 21, 2018 at 5:22 AM
    The OME's are great but I got maybe 2 3/4" lift. They are advertised at 2.5". Depends on coils you select and load. Best bang for the buck 3" coilover lift is mentioned already>>>>>ToyTec's Eibach setup.
    Toytec Lifts and Stroke250 like this.
  13. Aug 21, 2018 at 5:53 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    As other have said. The biggest bang for the buck right now is this setup... sub $500. I have run this for 6-8 months. Drop in. No assembly required. Ride is great on and off road.
  14. Aug 21, 2018 at 10:03 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    forgot to mention i have front bumper & winch and rear bumpers along with rock sliders. so weight is pretty heavy
    Toytec Lifts likes this.
  15. Aug 21, 2018 at 10:25 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    :popcorn:
  16. Aug 22, 2018 at 6:02 AM
    TexasTundra27
    Mark
    The OME has a heavy option that handles weight real well
  17. Aug 22, 2018 at 7:01 AM
    Toytec Lifts
    Denver, CO.
    Depending on weight you can (as stated above from texastundra27 a few times) go with the OME coilovers, they do offer a heavier coil option for the additional weight that you have.
    The Toytec BOSS front coilovers are a good option too, full adjustable coilovers with a 700lb spring rate to insure proper stance and ride quality the first time without any issues!
    OME: Coil options:
    • OME-612 Coils - Stock/Light Load (0-150 lbs) 2.5" Lift
    • OME-613 Coils - Heavy Load -5.7L V8 (200+ lbs) 2.5" Lift
    • OME-614 Coils - Heavy Load 4.7L V8 (200+lbs) 2.5" Lift
    BOSS front coilovers:
  18. Aug 22, 2018 at 7:20 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Do you know what you were doing when it busted? Were you rock crawling? Driving on the highway?
  19. Aug 22, 2018 at 7:46 AM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Replaced my TRD Bilstiens with the Toytec Boss setup w/700lb spring. Nice lift and rides great on the hwy. Rides even better offroad. Whatever you end up with get it from Toytec. The customer service is spot on.
  20. Aug 22, 2018 at 9:22 AM
    TexasTundra27
    Mark
    I have 700lb springs on my Icons with no added weight and it rides great so don’t be afraid of the ride of such a heavy spring, it also helps with running no sway bar. @Toytec Lifts how are the Boss coilovers valved?
  21. Aug 22, 2018 at 9:30 AM
    Toytec Lifts
    Denver, CO.
    The BOSS lineup is Toytec's brand specifically, so what we did was paired up with the engineers at Eibach to build each shock and valve it specifically to the weight of each vehicle.
    For the Tundra not only are you getting the shocks that are valved specific we also added a lower spherical heim for better articulation, along with double zinc coating the shock bodies and larger nitro steel hardened shock shafts for increased corrosion resistance.
    Mwray8909, mattyd170 and 16cmt[OP] like this.
  22. Aug 24, 2018 at 8:27 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    i was driving and my entire wheel went flying off broke all the lug bolts off. next thing i noticed was the shocks bent.
  23. Aug 26, 2018 at 5:46 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    just days before my hunt i had oil change and tire rotation by toyota service. previous oil change, i caught it and heard the lug nuts and tightened them myself. this time was just a bad experience. wheel flew right off
    TexasTundra27 likes this.
  24. Aug 26, 2018 at 6:20 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Awe shit. Hope it didnt cause to much damage.
    Everytime I take the truck/s to the dealership and tires were touched, I tighten my lugs before I leave.
    Had a service advisor come out once and assure me the lugs are torqued to spec.....as I was able to get a full turn and a half on one.
    16cmt[OP], Samoan Thor and jewsNbrews like this.
  25. Aug 26, 2018 at 6:52 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    This kit looks and sounds like the bomb.com. Damn. Ready to go and coilover for under $500. Might be the kit I look at in the future, although I like the Toytec coilovers a lot.
    OBXTundra and 16cmt[OP] like this.
  26. Aug 26, 2018 at 6:52 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Yup, everytime they drop it off after service I whip out the torque wrench check all the lugs and all the nuts theyve unscrewed, then crawl under and inspect before driving off. They always come and ask if somethings wrong which is good but I just double check everything
  27. Sep 7, 2018 at 9:41 PM
    Tundrago
    Tundrago New Member
    Nashville area
    2016 SR5 upgrade. TRD
    how do you like the cooper stt pros?
  28. Sep 7, 2018 at 9:45 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    i got almost 40k on them and i half a little under 50% but they’ve been great. my first mts ever
    Tundrago[QUOTED] and parker44 like this.
  29. Sep 14, 2018 at 10:55 PM
    n8saki
    n8saki New Member
    Nate
    8361 / 01H5
    Looking for the same as well. Waiting a response from Dave - then will order.
  30. Sep 14, 2018 at 11:13 PM
    16cmt
    Portland Oregon
    2016 Sr5 Crewmax
    i got the icon 2.5 w/resi for the front and 2.0 non-resi for the rear. so far it’s been riding like a champ! Chas Moore from MRTMotorsports out in las vegas! don’t forget to mention Sarn
    n8saki likes this.
