How do I check the transmission fluid?
Discussion in '2nd Gen Tundras (2007-2013)' started by Randy Morton, May 21, 2016.
  1. May 21, 2016 at 8:41 AM
    Randy Morton
    Randy Morton [OP] Life takes its toll, please have exact change.
    Randy
    Deepinahearta, Texas
    I looked in the manual and didn't see a reference to checking the level, and a fairly thorough search under the hood didn't reveal a dipstick. What am I missing?
  2. May 21, 2016 at 8:50 AM
    Sealed system. The dealership will have to do this service. (30/60/90/120K miles)
    T-Rex266 likes this.
  3. May 22, 2016 at 8:51 AM
    Randy Morton
    Randy
    I'm not sure I like that idea. I prefer checkable fluids. My previous pickup (non-Toyota) started leaking transmission fluid during a trip to the Davis Mountains (the McDonald Observatory is well worth the trip) and I'd have been hard pressed to find a dealer, and possibly a qualified mechanic.
  4. May 22, 2016 at 10:30 AM
    The fluid level is able to be checked....just not by you. Lol. You can get a scan gauge and go that route.
    I haven't had an issue with it yet. If transmission fluid is leaking all over the place, time to get it fixed anyway.
    nickm95 likes this.
  5. May 22, 2016 at 11:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  6. May 22, 2016 at 12:34 PM
    Randy Morton
    Randy
  7. May 22, 2016 at 1:49 PM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Most manufacturers are going to sealed systems. My last couple cars have been the same.
  8. May 22, 2016 at 5:29 PM
    Not too bad of an idea with a top notch tranny. Mercedes trannies are sealed too.
  9. May 23, 2016 at 5:08 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    You simply pull the dip stick! OH...I have a 1st Gen, they actually gave us one of those things! I'm pretty sure the new ones are similar to the Taco which has a real convoluted process to get a light blinking and then you pull the fill plug and it should just drip out. If they have a code for the Tundra Tranny you can get a Scan Gauge which will show the actual tranny temp so you know when to pull the plug to check it. Pretty simple with a Scan Gauge, a real PITA if you don't have one.
    Mike likes this.
  10. May 23, 2016 at 5:25 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Priceless.. 1st gens rules.
    FirstGenTundra likes this.
  11. May 23, 2016 at 5:59 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
    The correct answer is... YOU DONT
  12. May 23, 2016 at 7:31 PM
    We 2nd gens have a better tranny. Apparently can last to 999,999 miles +. Who needs a dip stick. 2nd gens rule actually.
  13. May 23, 2016 at 7:32 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    If 2nd generation are so great then why did they make 3rd
  14. May 23, 2016 at 7:34 PM
    "3rd" was sheet metal and fancier cab. Same mechanics. Not really a true new gen. Just sayin......you were sayin???
  15. May 23, 2016 at 7:42 PM
    1st gen:
    2nd gen:
    3rd gen:see above:
  16. May 23, 2016 at 7:43 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    Lol, I know. I would say the true 3rd Gen will be a diesel
  17. May 23, 2016 at 7:47 PM
    I wouldn't lose too much sleep waiting for the diesel. Better to dream about a gas 4.0L, 350HP, 390 torque, turbo'd V-6. Odds are much better for that than the Cubs to make it to the world series or a diesel.
  18. May 23, 2016 at 7:49 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    This is the one I wanted
    323a57338c8c1dc82346601ac2197305_2e15935c409e7ad606f6797eac341849f514a0da.jpg17b5272454c22d9287a168ace9d458d1_0de43527de3d97b209b4424aa2b64b0eff4e28de.jpg
  19. May 23, 2016 at 7:51 PM
    Japanese prototype. One off. Very cool. I wouldn't want it. I go off pavement.
  20. May 23, 2016 at 7:52 PM
    Mike Tread lightly.
    south carolina
    Not going to happen. You have a better chance at stepping on a land mine then that thing getting off the ground anytime soon.
  21. May 23, 2016 at 7:53 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    I know but it's fun to dream
  22. May 23, 2016 at 7:53 PM
    Or this:
  23. May 23, 2016 at 7:55 PM
    That proto dually is a garish nightmare to me. Toyota was smart to not even show it here.
  24. May 23, 2016 at 7:55 PM
    Mike Tread lightly.
    south carolina
  25. May 23, 2016 at 7:59 PM
    I prefer the flying pig with shades any day. Or Floyd:
  26. May 23, 2016 at 8:02 PM
    Bottom line is, to get back on track before Sean or Brian notices..heh heh............Don't worry too much about your tranny until at least 60K, more like 90K.
  27. May 23, 2016 at 8:09 PM
    Mike Tread lightly.
    south carolina
    Now the games are over.
    The oil today is transmissions is way advanced of the transmissions today. Only company that pushes the oil limit is GM. While most of us are in dextron 2,3 or 4.. GM is on dextron 6 I heard dextron 7 is on the way or already here.
    Just like engine oils are more advance than you think. Thank Mobil oil for that.
    Black Wolf likes this.
  28. May 23, 2016 at 8:12 PM
    Ditto^^ except the games are just beginning:
  29. Jun 4, 2016 at 6:21 PM
    oldschoolhdmike
    oldschoolhdmike New Member
    mike
    2007 tundra crew max 5.7
    not much
    my manual says 60k and 120k service on my 07. i just hit 100k and the PO said he had it done maybe 5 years ago so i am just going to have mine done at 120k. i had one shop tell me about $150, and the another one tell me $590.....i would do it myself but it is such a messy job and i dont have a lift etc.....the oil changes suck enough as it is...
  30. May 2, 2025 at 5:08 AM
    nickm95
    nickm95 New Member
    2012 Tundra TRD Rock Warrior
    3.5” full suspension lift, bds 2.0 shocks and skid plate
    10 years later this is still relevant and very helpful, thank you sir, I just got a nifty new tool to put next to my obd reader.
    Looks like those sealed trannys turned out to be one of the best things they’ve ever done, the first guy with a million mile 2nd gen said he towed with it across the country all the time
