Purchased a supercharger kit
Discussion in 'Performance and Tuning' started by airosey, Jul 21, 2018.
  1. Aug 14, 2018 at 9:59 AM
    iamvietness
    iamvietness New Member
    Dallas, TX
    So i am able to get a 5.7 TRDSC but I have an 18 model and I don't see any information as to whether or not it will fit my year. Anyone provide any information?
  2. Aug 14, 2018 at 10:03 AM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    It should bolt up fine as long as it is the full kit including the blower and fit kit. Not sure if your computer will accept the TRDSC Flash or not, so you may have to go Bully Dog for the Tuner. The dealership should know if it will accept the factory flash once they plug it in to the system.
    iamvietness[QUOTED] likes this.
  3. Aug 14, 2018 at 10:05 AM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    TRD doesn’t offer it anymore, so you’ll have to find it, with the fit kit, used.
  4. Aug 14, 2018 at 10:16 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    Watching this!!!:yes:
  5. Aug 14, 2018 at 7:26 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    Check with Magnuson, I would have to say it is available for 2018s
    https://www.magnusonsuperchargers.com/
  6. Aug 14, 2018 at 7:41 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Magnuson produced the TRD SCs. When Toyota discontinued the SCs Magnuson rolled out with a newer version that pushes 50+ hp more than the "TRDSC". Why have 500 hp when you can have 550!!
    boostedtrdpro and TundraLuv like this.
  7. Aug 15, 2018 at 2:17 PM
    iamvietness
    Dallas, TX
    I reached out to Mangnuson. They are working on one for the 18 model but doesn't have an ETA
    Sas likes this.
  8. Aug 15, 2018 at 6:22 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Your truck is badass man
    airosey[OP] likes this.
  9. Aug 15, 2018 at 6:40 PM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    Beautiful truck!!! "the candle that burns twice as bright burns half as long" keep that in mind when you put that supercharger on.
  10. Aug 15, 2018 at 7:01 PM
    Warreng
    Warreng New Member
    If you are nice to it should last just as long. Thats what I am going with anyway.
  11. Aug 15, 2018 at 7:05 PM
    Thee_Oddball
    Eric
    Chicago
    My mechanic told that these engines were not designed todo 550hp and a supercharger would shorten the life of my motor :(
  12. Aug 15, 2018 at 8:26 PM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    TRD Supercharger 4.5 BDS lift 20” Method Standards sitting on 35 Nitto Grapplers Rigid grill top and bottom with lights AMP running boards Fender flares Magnum rear bumper Rear LED bar Air bags with onboard compressor Brake controller Alpine Navi Alpine amps x 2 Focal Separates front and rear 2 x JL 13s in a stealth box behind the back seat LTE cellular booster Rear seat under locked storage Dynamat from ceiling to floor LEDs all over Bed liner Bed rails Paint protector covering nearly the entire front end and more
    Love my SC! Enjoy it man!
  13. Aug 17, 2018 at 5:27 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Unless your mechanic is an engineer for Toyota idk how much water that holds for me. Warrantied and offered from the factory was enough assurance for me..i do understand the program was killed but there could be alot of reasons for that. That was my logic anyhow.
    When u can blow off 37s like nothing you tend to forget about these things I guess. :thumbsup:
  14. May 25, 2019 at 6:45 AM
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    Hey airosey, any updates?
    I did the exact same thing (except only had about half the fit kit.. Needed to find the missing parts).
    Installed it on my '15 CM myself in my garage about 2 months ago (after purchasing the SC like 3 years ago lol)
    I did it in steps to maintain my daily driver and keep it on the road until it was go time. (Did fuel pump one weekend, front great Exchanger, water lines, wiring another weekend... Then all the rest over 2 days)
    You're much better off being flex. The fuel pump was pretty intimidating... Although now that I've DONE it, it wouldn't be hard knowing the steps
    Im interested in knowing more about that water injection kit.
    Figured maybe I can offer some help/advice too since I just did this too.
    So what's the latest!?
  15. Jun 5, 2019 at 10:23 PM
    marcfs71
    marcfs71 New Member
    Marc
    2010 Grey Tundra TRD Offroad Pkg with TRD Supercharger
    Dual Exhaust
    I have a 2010 with TRD Supercharger (factory tuned). My wife was driving it and I pulled up in my C5 corvette. She put her foot down and blew my doors off! When she got out of the truck she said she only went part throttle. The truck is really fast!
    AZTundra, Migraine and Tundyfundy like this.
  16. Jun 5, 2019 at 10:46 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You're mechanic is a communist.:oldglory:
    Migraine likes this.
