  1. Aug 11, 2018 at 11:34 AM
    #811
    Professional Hand Model
    Fred
    Hand Protectors
    Cover dry fit with new bolts with washers about to be installed.
  2. Aug 11, 2018 at 11:35 AM
    #812
    Fred
    Hand Protectors
    Darkness likes this.
  3. Aug 11, 2018 at 12:25 PM
    #813
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I probably missed it but were you leaking or just replaced for fun? I need to do this soon on the wife's Honda.
  4. Aug 11, 2018 at 12:34 PM
    #814
    Fred
    Hand Protectors
    Was/have been leaking for 4-5 years. First time I noticed the leak was from the burning oil smell while towing. Took a 10mm to the bolts and noticed severe looseness at just about all 9 of them. Snugged them down and that worked. Been snugging every 1 year but only so much you can do when the gasket is past its service life. The spark plug tube gaskets (3 or 4) were leaking as well. Noticed that when doing spark plugs last week.
    Youtube the process. Its not hard. Like anything its all about having the proper tools, parts, and attitude.
    Darkness[QUOTED] likes this.
  5. Aug 11, 2018 at 12:51 PM
    #815
    Fred
    Hand Protectors
    Here is the before pic. You can see the oil below valve cover. And the blow out residue around certain spark plug tubes.
  6. Aug 11, 2018 at 3:13 PM
    #816
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ahh yeah. My wife's seems to be leaking at the back of the valve cover, haven't really figured out if it's just the valve gasket or also the vtech solenoid gasket but I plan to change both. One of her coil packs had quite a bit of oil on it too. She never drives it bbn so I'm not in a hurry.
    Doesn't look bad. Just need a cool day with some shade and maybe a 6 pack.
  7. Aug 11, 2018 at 4:06 PM
    #817
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Got some new shoes today there 285/75/16 falken wildpeak at3. They drive so much better than my super swampers. 7BFDCF66-2683-4403-8CFC-42402F979C3B.jpgDDA9EEFD-FB55-42CA-B5DA-FF981B01BA82.jpg078F9944-BBB9-4C8E-97D2-824A0FD99920.jpg
  8. Aug 11, 2018 at 4:16 PM
    #818
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Nice. Looks like the tread will be relatively quiet on the road and may give you a bit of a boost in efficiency over the Swampers. How much lift do you have and are you having any fitment issues like rubbing when turning?
  9. Aug 11, 2018 at 4:35 PM
    #819
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    D088082E-6AC9-4C46-BA55-AF96F77301A2.jpg DF6D482A-CC90-496D-B6E3-BAD9911D2A9C.jpg All washed, waxed and out on the town for date night. I think my wife may be jealous for taking these shots.
    Sampson, Y0TA PR0, BestGen and 2 others like this.
  10. Aug 11, 2018 at 4:36 PM
    #820
    ethan1911
    I really don’t how much lift it has because it’s all different suspension because of the straight axle swap, they don’t rub at all my swampers rubbed on my front leafs at full turn
  11. Aug 12, 2018 at 12:54 PM
    #821
    Fred
    Hand Protectors
    Got the drivers side valve gasket in today (3 hrs). Drivers side is a little easier. The valve cover was pretty carboned up compared to the passenger side. Degreased it and then scraped off all the carbon deposits with a flat knife then degreased again. The spark plug tube gaskets were pretty dry rotted and harder to get out compared to passenger side.
    Think some of the problems stemmed from the partially clogged PCV valve which was gunky. Put in a new PCV valve. Cleaned up the old one and its like new again and will save for future.
    Test drove and she is purring nicely.
  12. Aug 12, 2018 at 12:58 PM
    #822
    Fred
    Hand Protectors
    Any one here due an engine oil purge? Been researching differing methods. Necessary? Suggestions?
    1). Kerosene purge
    2). Mystery Oil purge
    3). Royal Purple purge
    Want to do this before/during next oil change if its worth it.
  13. Aug 13, 2018 at 7:07 AM
    #823
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Haven't done what would be considered a purge but when I once neglected to change my oil for about 20k miles I did some really short changes after. Did one at 500 miles and the next at 2500, not sure it was worth the trouble but felt like I was making up for the neglect.
  14. Aug 13, 2018 at 2:12 PM
    #824
    Fred
    Hand Protectors
    Most I’ve gone without changing the 02’ was about 6k miles. Usually, its changed about every 4500 miles.
    My passenger side valve cover looked good. My drivers side had some carbon. That side seems to get the heat maybe because of a clogged PCV valve. Not sure, but she is running better than ever now.
    Been dialing in on the purge and looks like Liqui Molly is the one to go with. Pour in to your old oil with engine hot and run on idle for 10 minutes, then drain and proceed like a normal oil change.
    Read about 300 reviews on Amazon and some guys did 2 flushes. Old oil flush, then new sacrificial oil with another flush, then new synthetic oil (no flush) for the final until your new oil change. These were mostly BMW guys that did the double. Alot of the other people were not changing enough because of the new ‘high mileage’ oil marketing and running into sludge problems.
    Did a few Youtube vids and it looks like it works. Even the new double oil change/flushers their brand new oil looked black after the second change. Some had chunks coming out.
    I’ll be doing this in a few weeks as its coming time for an oil change.
    FirstGenVol likes this.
  15. Aug 13, 2018 at 2:57 PM
    #825
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Haven't tried their additives but I strictly run Liqui Moly synthetic in my turbo GTI. It burns less than Castrol did, I would trust anything from them. They also go by Lubro Moly.
  16. Aug 13, 2018 at 3:00 PM
    #826
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Damn! That’s a really nice first gen! Really like the colour! :thumbsup:
    tye[QUOTED] likes this.
  17. Aug 13, 2018 at 3:47 PM
    #827
    ethan1911
    40EF7594-40BC-4580-9C3C-2EC1A59B9DB8.jpg Installed some led headlights after work today
  18. Aug 13, 2018 at 3:51 PM
    #828
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those look nice. Projector needed or no?
    You know you gotta post a night time output pic now, I'll post one of my HID's tonight if I can.
  19. Aug 13, 2018 at 4:49 PM
    #829
    ethan1911
    They’re just cheap ones from Amazon no projector needed. Haha I can’t wait for it to get dark so I can try them out.
  20. Aug 13, 2018 at 4:51 PM
    #830
    Outbound
    Aaron
    Northern Alberta
    I tried to locate an squeaking noise that doesn't sound healthy. No joy yet though
  21. Aug 13, 2018 at 5:05 PM
    #831
    Fred
    Hand Protectors
    Ordered up some Liqui Moly and sacrificial oil with a 5 pack of Toyota oil filters on sale. Picked up a combo of oil filters and oil bolt plug washers. These are the bigger D3 filters.
    khmerkid14, Jerry311SD and Darkness like this.
  22. Aug 13, 2018 at 5:09 PM
    #832
    Fred
    Hand Protectors
    Castrol cheapy synthetic for second flush if needed. Best price going.
  23. Aug 13, 2018 at 6:40 PM
    #833
    ethan1911
    Darkness, it’s not quite night yet but I’d say there $25 bucks well spent if they last.
  24. Aug 13, 2018 at 8:21 PM
    #834
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Under the hood? Bad pulley maybe?
    Those look pretty damn good to me.
  25. Aug 13, 2018 at 8:25 PM
    #835
    Outbound
    Aaron
    Northern Alberta
    No, suspension related I think. Happens when the truck bounces. Had The Woman stand on the running board to trigger it for a vid:
  26. Aug 13, 2018 at 8:34 PM
    #836
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's a nice one. Probably need to do the long screwdriver stethoscope move to isolate it. If it's up front maybe a bad bushing in one of the arms or possibly the lower shock.
  27. Aug 14, 2018 at 4:43 AM
    #837
    Fred
    Hand Protectors
    If this truck is rockin’, don’t come a knockin’.
    NUDRAT and Outbound[QUOTED] like this.
  28. Aug 14, 2018 at 2:26 PM
    #838
    Tundralivesmatter4.7
    Tundralivesmatter4.7 New Member
    Andrew
    Memphis, TN
    2000 Toyota Tundra SR5
    2.5in lift 285/75 r16 ko2s Snorkel Skid row oil pan skid plate Trail gear rock sliders Lots of other stuff
    Flow master 40 series dual turn downs installed last week :bananadance:
  29. Aug 14, 2018 at 2:39 PM
    #839
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I bet your gas mileage went way down because you're put revving it everywhere.
    :burnrubber:
  30. Aug 14, 2018 at 2:41 PM
    #840
    Fred
    Hand Protectors
    Exhaust blowin’ so hard it sagged the parking brake cable.
