Keep stock 20" wheels on a Platinum or swap back to 18"?
Discussion in 'Wheels & Tires' started by cashsmoney, Aug 11, 2018.
  1. Aug 11, 2018 at 4:13 PM
    cashsmoney
    cashsmoney [OP] New Member
    Cash
    2018 Tundra Platinum CrewMax
    TRD Duel Exhaust TRD Rear Sway Bar TRD Cold Air Intake To be continued .....
    Hello,
    I just bought a 2018 Tundra Platinum. I want to keep the suspension sock no lift kits, or leaving kits, don't want any offset or anything like that. It has the 20" wheels on it now, but I want to put some Ko2's tires on it. Should I try and see if the dealer would swap out for the 18"s or as anyone put 20" Ko2s on the tundra. i seen pictures of the tundra with the 18"s but not many 20" without a lift kit. Thanks
    Black Wolf likes this.
  2. Aug 11, 2018 at 5:18 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. 18" tires are less expensive and offer more protection for the wheels. However, 20s are gonna have less sidewall flex in turns.
  3. Aug 11, 2018 at 5:29 PM
    polymerhead
    polymerhead New Member
    I do not like the factory 20s, but that’s just me. I would think the Dealer might be able to swap out, especially if you’re open to doing it on a used truck (since you’re changing tires anyway). If he has a chance to put brand new 20” wheels and tires on a used truck, he might do it.
    zcarpenter92 likes this.
  4. Aug 11, 2018 at 6:10 PM
    Tsoot
    Tsoot New Member
    18 Plat White
    No lift 20” KO2
    I replaced the silver platinum rims with T-force 20”
  5. Aug 11, 2018 at 6:19 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    AWESOME LOOKING RIDE..I HAVE THE SAME WHEELS..
    Leo's first and Tsoot[QUOTED] like this.
  6. Aug 11, 2018 at 8:09 PM
    cashsmoney
    Cash
    Awesome that’s what I was looking for. What size tires are those? Did you have any fit issues? Any rubbing
    Leo's first likes this.
  7. Aug 11, 2018 at 8:48 PM
    Tsoot
    Tsoot New Member
    18 Plat White
    285 55 R20 no rubbing they come on Tundras
  8. Aug 11, 2018 at 8:55 PM
    Cajuntex
    Cajuntex New Member
    2018 Tundra Limited CrewMax 2wd
    Added Digital Processor,amp,speakers and sub; ESP storage tray, Driver Handle, husky mats, Diamondback se, TSS rims and BFG KO 2s
    I just did the same. I didn’t care for the 2018 Limited rims. Went to Texas Truck and Tire in Houston and got the 20” TSS rims with 285 BFG KO2s for very reasonable price. Was able to get some money back for the Limited rims and tires. Like the pictures above no lift and they fit fine. I know I could have gotten other rims but I like these and they are OEM here for Gulf States Toyota. Check eBay because Texas truck and tire also sell these online. Dealer wanted $465 for the TSS rim alone.
  9. Aug 20, 2018 at 4:23 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    Are you selling your old rims? Let me know if you are
  10. Aug 20, 2018 at 10:56 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    No lift or leveling kit. 285/55r20 BFG ko2's.
    polox40 and Toyotoholic like this.
  11. Aug 20, 2018 at 3:38 PM
    cashsmoney
    Cash
    Yeah the price difference between 275s and 285s is like $120 per tire
  12. Aug 20, 2018 at 3:50 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Cool thread op
    You people have AWESOME TUNDRAS
    GNTundra and cashsmoney[OP] like this.
  13. Sep 3, 2018 at 9:02 AM
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    Painted the rim caps yourself? I love that look! I want mine blue now lol
  14. Sep 3, 2018 at 9:43 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I've got a few pics of the 20's in my albums. I will be switching to 18's, but my reasons for doing so may differ from yours.
  15. Sep 3, 2018 at 10:12 AM
    baylrballa
    baylrballa New Member
    2016 Black Crewmax Limited
    I'm in the same decision process, seems like 20s are a little better handling on roads, but the larger sidewall on the 18s looks pretty good too.
  16. Sep 3, 2018 at 1:03 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Factory Platinum wheels with 275/60/20 BFG KO2s. No rubbing.
  17. Dec 22, 2018 at 5:09 PM
    Donkeypunch
    Donkeypunch New Member
    Hard to tell but did you have to remove the mudflaps. I want try to run the biggest K02 with no trimming or removing mudflaps on my 2019 platinum and also run the new Tundra TSS 2018+ 20” wheels which are 50mm offset.
  18. Dec 22, 2018 at 5:19 PM
    Donkeypunch
    So I am reading that 275/60/20 is te biggest tire to run on our Tundras no lift.
    But then I find thisnthread which ppl are running 285/55/20. I think factory is 275/55/20.
    Anyone know if 285/60/20 fit on factory height and no trimming?
    Inwas going to go 275/60/20 but the I see TSoots truck and running 285/55/20.
    I also have the new TSS wheels. I have a White 2019 Platinum and was going to do exactly like TSoot’s setup (before seeing his truck and body matched handles/side mirrors, flat black nerf bars), but now I am going to bronze powder coat the new TSS 20” wheels to be different.
  19. Dec 22, 2018 at 6:14 PM
    easleycrawler
    Travis
    My truck is a 2wd, not sure how much higher a 4wd sits compared to mine. I have zero lift and running 20x9 with +50 offset, which should be the same as yours. I've got 285/55r20 Bfg ko2's. It's pretty close but doesn't rub anywhere at anytime. 285/60's will probably rub, maybe not.
    WlieTiger, TokerJoker and NCTundra18 like this.
  20. Dec 22, 2018 at 6:17 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I have 285/55s on my stock platinum wheels and no lift without issue I'm pretty sure I could do 285/60s and still clear everything.
  21. Dec 22, 2018 at 6:43 PM
    Donkeypunch
    Which is a bigger tire? 285/55/20 or 275/60/20?
  22. Dec 22, 2018 at 6:49 PM
    bigblue14
    Craig
    285/55 is 32.34" tall x ~11.25" wide
    275/60 is 32.99" tall x ~10.75" wide
    285/60 is 33.46" tall
    Donkeypunch likes this.
  23. Dec 22, 2018 at 6:49 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    those center caps come with? What's in the middle of the "T"
  24. Dec 24, 2018 at 8:44 PM
    757TUNDRA
    Illinois
    I didn’t remove anything, the 275/60/20s fit perfect with no rubbing. Anything smaller doesn’t look right to me.
  25. Dec 25, 2018 at 7:29 AM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Having similar thoughts about the 275/55/20s on my 2017 CM limited, stock/factory installed suspension, wheels, tires and rake at this point.
    I would like to get a taller tire on there. Hadn't considered the cost of 18" vs. 20" tires until this thread.
  26. Dec 31, 2018 at 2:44 PM
    RoscoePico
    RoscoePico New Member
    2018 Tundra 4WD CrewMax
    Just went with KO2 275/55R20s with no lift or leveling on my 18 CM Platinum and I DO have rubbing in reverse with the wheel turned sharp. Just have to make sure I'm pointed in the right direction for quick getaways!
  27. Dec 31, 2018 at 3:15 PM
    easleycrawler
    Travis
    That's odd. Heck that's the size that comes on factory 20's. I've got 20x9's with +50 offset and running 285/55's and have zero rubbing anywhere.
  28. Dec 31, 2018 at 3:21 PM
    RoscoePico
    Yep, my factory 275/55R20 Bridgestone Dueler H/L Alenzas didn't rub. I'm guessing it's the offset. Mine are mounted on SCS Stealth 6 with a +12mm offset...
  29. Dec 31, 2018 at 4:18 PM
    easleycrawler
    Travis
    Oh ok. I was thinking you still had factory wheels. The +12 would make them rub, I've seen guys have a +18 with the 275/55's without rubbing. It's a game of mm's lol.
    RoscoePico[QUOTED] likes this.
  30. Feb 17, 2021 at 1:57 PM
    waynescorp
    waynescorp New Member
    2012 Tundra Limited DC TRD 4X4
    Leveling Kit
    Hello, I know this is an old thread but wondering how those 275 60 20 BFG's LR D ride and are they pretty stiff? Also how is the noise level on the highway. Great looking truck by the way. :)
