Welcome to the Official SoCal BS/ Shenanigans, Tundras and NEW GUY JOINED TO FIND MEET-UP Thread
Discussion in 'California' started by Sunnier, Dec 21, 2017.
  1. Aug 5, 2018 at 8:17 AM
    #1411
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    You want to be around 20-25 psi. Easy enough to start at 25 and work your way down as needed.
    Marty McFly, Sunnier[OP] and BestGen like this.
  2. Aug 5, 2018 at 8:17 AM
    #1412
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    20 psi should get you a nice sidewall bulge. About half the normal pressure should work. I run 30 and air down to 15.
  3. Aug 5, 2018 at 8:20 AM
    #1413
    typeone
    typeone about time I realized you could change this...
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Is 20 okay to highway drive to a gas station after we're done?
  4. Aug 5, 2018 at 8:20 AM
    #1414
    typeone
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Also, is there an app for this so I can be in contact with you guys on my phone for chats? <3
    Marty McFly and eccracer104 like this.
  5. Aug 5, 2018 at 8:22 AM
    #1415
    BestGen
    BestGen New Member
    Paul
    Only if you keep your speed down. Get yourself an inflator asap. :thumbsup:
  6. Aug 5, 2018 at 9:44 AM
    #1416
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    :spending::spending::spending:
    ....THIS INCLUDES ME!
  7. Aug 5, 2018 at 10:12 AM
    #1417
    eccracer104
    San Diego, CA
    On straight road, yes. When you go around a corner go slower than you normally would.
    And what @BestGen said, get an air compressor or some way to air up tires ASAP. Viair makes some great compact portable compressors that hook up to your battery.
    Just the forum website.
    Join our trail run - https://www.tundras.com/threads/9-8-18-big-bear-gvl-run.28694/
    Meet some locals, get phone numbers, or once you know some people set up a group PM so it’s easier to follow.
    But threads and PMs tend to move pretty quick haha
  8. Aug 5, 2018 at 10:53 AM
    #1418
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    @eccracer104 and @BestGen
    Between Viair and ARB, which do you prefer?
  9. Aug 5, 2018 at 11:19 AM
    #1419
    eccracer104
    San Diego, CA
    The ARB is nice because you mount it somewhere permanently so you always have it, but it’s more expensive.
    The viair compressors are cool because they’re pretty compact and in a bag so you can keep it with your camping/wheeling supplies and throw it in the truck when needed. And a lower cost.
    Long term plan, the ARB is a solid investment and gives you the ability to run an air locker in the future if desired. You do need to run a switch into the cab to turn the compressor on and off.
    The viair is just simple and easy, no wiring, no mounting, just pop the hood and attach the alligator clamps to the battery and air up.
    Both are solid choices.
  10. Aug 5, 2018 at 12:25 PM
    #1420
    BestGen
    BestGen New Member
    Paul
    Excellent advice. For me it's pretty simple; if you're going to run a locker, it's ARB. Huge price difference compared to ViAir because its on a whole 'nother level! For what most ppl want the ViAir is perfect. It's even easier with the Milwaukee inflator I picked up. It uses the M12 batteries I already had. No need to pop the hood!
  11. Aug 5, 2018 at 12:51 PM
    #1421
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    Yup, we all want ARB. But if you're not sure if you'll use it enough to "need" it more than this once, you can get one of the Viaiars shown in the products list below this thread. You can get one as small as this:
    https://www.amazon.com/dp/B00CDW2MCM
    This one will take longer than ARB, and higher powered Viaiar options that attach to your battery under the hood. But you can do the 4 tires of your Tundra and 2 of another parked next to it, in the cycle time before you have to turn it off. But it plugs into the cigarette adapter (and from the one in the rear seat will reach all 4 tires + that hypothetical truck parked next it). And stores easily in the under seat storage (assuming you have that). With any, they get damned hot! Can't put it away right after; instead, I put it in the truck bed to cool on the drive back, then store it away when I get home.
    I bought a couple others that did not work for the Tundra because the power cord and air hose lengths weren't long enough to reach to each tire. This one described was the cheapest I found that works.
    Marty McFly, eccracer104 and porkitt like this.
  12. Aug 5, 2018 at 12:59 PM
    #1422
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
  13. Aug 5, 2018 at 1:18 PM
    #1423
    Sunnier
    Sunny
    San Diego, CA
    I think I recall, there's no app because Tapa talk did intrusive stuff with members' info.
    Depending on what phone you use though, the user functionality mimics an app, kind of. When I use an iPhone, I have a shortcut on the screen that looks like an app. It opens to the home forum screen with the list of most recently updated threads. Bold lettering lets me know which have new comments since I last viewed it. You can "watch" threads, so you can go back and check to see if you've missed posts on any threads you care about.
    It is not as comfortable on my Kindle. On iPhone I get to see who made the most recent comment before I open each thread; on Kindle, I see how long ago the most recent comment was made, which I don't care about, but not who posted it. Both let me stay "signed in".
    Anyway, like @eccracer104 said, "conversations" tend to be sporadic and quick, and dependent on who's checking the thread at any given time.
  14. Aug 6, 2018 at 4:37 AM
    #1424
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    So the Ram shoot is going to be at Wildomar OHV. I live in Murrieta but I never even knew this place existed LOL Anybody ever been there?? I'm going to prerun it on Friday. Anybody want to join me?
  15. Aug 7, 2018 at 11:36 PM
    #1425
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    I found you SoCal BS... Been looking for you my whole life!!!
  16. Aug 7, 2018 at 11:39 PM
    #1426
    eccracer104
    San Diego, CA
    :wave: Welcome to the mad house! :cheers:
  17. Aug 8, 2018 at 5:02 AM
    #1427
    osidepunker
    Alex
    2013 Tundra DC 4x4
    EDIT looks like they changed the location again LOL now it's going to be at San Gabriel Canyon. I haven't been there either, but I'm not driving all the way up there to pre run it
    BestGen, Marty McFly and Sunnier[OP] like this.
  18. Aug 8, 2018 at 6:19 AM
    #1428
    Sunnier
    Sunny
    San Diego, CA
    Hmmn. Getting there gonna cut into your wages...?! I kinda wanna go as your groupie/ vlogger....
    Marty McFly likes this.
  19. Aug 8, 2018 at 6:30 AM
    #1429
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I have to take a day off, it's an 8 hour shoot. But they're paying me more than I make so I'm ok with it. But really I'm just doing it because I've never done anything like this before. Also I'm just going to take the rest of the week off because I'm leaving Thu night for Vegas. It'll be a fun mini vacation. I'll go to Big Bear after the shoot and do some mtb and camp the night. MTB in the morning then go home and then off to Vegas
  20. Aug 8, 2018 at 6:31 AM
    #1430
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Come on out! I have no idea what it'll be like so I can't promise you won't be bored but the more the merrier LOL
  21. Aug 8, 2018 at 7:21 AM
    #1431
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    hahahaha welcome. Trip coming up to Bid Bear soon. Has its own tread so I hope you find that one too.
  22. Aug 8, 2018 at 7:23 AM
    #1432
    Sunnier
    Sunny
    San Diego, CA
    Sounds like you worked this out great; should be a fun weekend!!
    Hey, @Marty McFly, I read this as an invitation for the entire SoCal Tundra club to show up in support of @osidepunker's debut. Hahahaha! How cool would it be to have 70 Tundras on that background of every shot. LOL!!
    :rofl::rofl::rofl::rofl::rofl::rofl:
    (I crack myself up! :D)
  23. Aug 8, 2018 at 7:30 AM
    #1433
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Alex takes Rebel offroad. Alex forgets he’s not driving an LT Tundra. Alex returns Rebel looking like....
    :p
  24. Aug 8, 2018 at 7:39 AM
    #1434
    BestGen
    BestGen New Member
    Paul
    San Gabriel Cyn..? Sounds like Azusa Cyn. Maybe it's a different place. If it is I haven't heard of it. If it is Azusa then it'll be rocks, stream crossings, and a bottomless mud pit. I think they have a rock course too. I avoid the place. You'll be bored of it in an hour. The best thing about Azusa is watching the sh!t show. Ever see someone trash a $65K(or more)4x that doesn't even have plates yet...? Odds are good you'll see it here. They filmed an episode of American TopGear here once. Adam flipped a brand new Dodge truck iirc and broke his arm. This place likes to cut tires too.
  25. Aug 8, 2018 at 7:43 AM
    #1435
    Sunnier
    Sunny
    San Diego, CA
    :rofl:Joon cracks me up too:rofl:
    joonbug[QUOTED] likes this.
  26. Aug 8, 2018 at 7:44 AM
    #1436
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    @porkitt I'm close to pulling the trigger on one of these too so I'll let you do the thinking for me. Let me know what you find out, please.
  27. Aug 8, 2018 at 8:50 AM
    #1437
    n2deep
    n2deep Pavement Princess
    Sounds like my kinda place - might have to go explore after the Big Bear meetup.
  28. Aug 8, 2018 at 9:16 AM
    #1438
    Marty McFly
    Morty McBoonJug
    That would be hilarious. I’d be down to photo bomb Alex’s commercial lol
  29. Aug 8, 2018 at 9:18 AM
    #1439
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Will do...So far I'm leaning towards the ARB, having multiple vehicles and being able to transport it if I decide to use a different other than the Tundra.
    https://www.amazon.com/ARB-CKMA12-C...=UTF8&qid=1533744957&sr=8-4&keywords=arb&th=1
    Sunnier[OP] and Marty McFly like this.
  30. Aug 8, 2018 at 9:18 AM
    #1440
    Marty McFly
    Morty McBoonJug
    I was thinking it has to be Azusa too! I like watching the shit shows and people stalling out in the river crossing :anonymous:
    BestGen[QUOTED] and Sunnier[OP] like this.
