  1. Aug 4, 2018 at 6:56 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Are those racks height adjustable?
  2. Aug 4, 2018 at 7:37 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Thats what i used. Hope to paint the console chrome this weekend.
    NewImprovedRon likes this.
  3. Aug 4, 2018 at 10:29 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Drove her to work in the pouring rain. I rarely park in the garage so I went up to check on her during my lunch break.
    And yes I parked like an asshole, garage is empty no cars even on my floor
  4. Aug 4, 2018 at 10:30 AM
    .manny.
    .manny. New Member
    Manny
    2018 Cement Tundra SR5 Crewmax
    installed my AMP Research Bed Extender. :)
    Super happy with it. Ordered the no-drill brackets from AMP and it worked out well, because the brackets gave me just enough clearance to flip the extender past the tonneau cover rails.
  5. Aug 4, 2018 at 11:21 AM
    geno0506
    geno0506 New Member
    Michael
    Welcome to the Elite Club! I will show my wife your picture because every time I park wrong she calls me an asshole, LMAO!
  6. Aug 4, 2018 at 11:28 AM
    Pudge
    CT
    Haha awesome.
    I try to park far far away to avoid this. But the garage limits this.
  7. Aug 4, 2018 at 11:32 AM
    Dryflyhunt
    Dryflyhunt New Member
    2016 Black Tundra Crewmax Limited TRD
    Tint, tonneau, chrome to black
    Said “bye” to the chrome and upgraded to yellow fogs...upload_2018-8-4_14-31-48.jpg
  8. Aug 4, 2018 at 11:35 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Added Undercover Elite LX tonneau and Husky Xact Contour mats.20180802_081032.jpg 20180801_163243.jpg
  9. Aug 4, 2018 at 11:37 AM
    Pudge
    CT
    I spy a neighbor with a nice second gen red rocket
    HecticEnergy and NewImprovedRon like this.
  10. Aug 4, 2018 at 11:50 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    No they are not.
  11. Aug 4, 2018 at 12:53 PM
    geno0506
    geno0506 New Member
    Michael
    I'm with ya brother! :cheers:
    RW-3 and Pudge[QUOTED] like this.
  12. Aug 4, 2018 at 1:28 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    I am also a card carrying member!! My wife does a back flip from the seated position because of how far away I park.
  13. Aug 4, 2018 at 2:18 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Did u just pop the brushed silver piece around it off and lay in there and clip back in, or did u do something else?
    NewImprovedRon and lionix like this.
  14. Aug 4, 2018 at 4:41 PM
    That's what I did. Just tuck it in all around clip it back in.
  15. Aug 4, 2018 at 6:50 PM
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    @mgm16trdpro Ok so I saw this picture on ARB’s website. Awhile back there was talk regarding this bed rack not being strong enough to have a RTT mounted on top of it and that it would have too much stress on the hindges of the Diamondback Bed Cover. However, here I see it with an RTT on top and a pretty good size. I know it says the weight limit is what it is, but I do think if you were to add four of these, this would definitely work. Thoughts?
  16. Aug 4, 2018 at 8:15 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Added the driver-side grab handle.....after a few mods...
    Keeping with the theme of the steering wheel mod I did back in an earlier post, here...
    I got some black suede material from Joann's, some black perforated leather from ebay. Had plenty of red thread from steering wheel cover. Used weldwood contact cement.
    First, the pillar:
    Being an injected molded polypropylene, I started by prepping the pillar to remove as much of the mold release oils as I could;
    1.) Used small torch to slowly heat (6" sections at a time), the wiped down with 91% alcohol/paper towels.
    2.) Sanded with 320 grit to rough up the surface, as well as 1" on the underside edge.
    3.) Washed with dish detergent, dried, and wiped down with 91% alcohol again.
    Wrapping the pillar...Not much to it, but time. Take plenty of it. Did lower face surface first, then each side about 6" at a time.
    The area around the handle attachments took a bit more time, and was done in smaller sections to mitigate any wrinkles. Wrapped around to the back side. X-cut the opening, then after drying overnight, detail trimmed.
    For the handle:
    1.) Started by trimming about 1/16" - 3/32" around the lower edge of the handle, where it seats on the pillar. This is to allow space for the leather to be tucked in later. I ended up gluing a couple washers to the bottom of the handle to give some space and not have to cut to much of the handle.
    2.) Followed the same prep as the pillar. The handle material is some type of a rubber compound plastic, so it's not has hard as the pillar and I had to be more careful with the heat.
    3.) I made a template, and cut out the perforated leather. Following the design of the steering wheel, I hand-stitched some of the red thread about 3/16" from the edges. I'll take more pictures of this process while working on the passenger side.
    4.) I glued, wrapped and stitched the center part of the handle, leaving the ends unglued so I could leave the covers open, to access the bolts.
    5.) Once installed (there's tons of how to vids on YT), I glued down the rest of the leather and tucked it in the edges.
    Passenger side next.
  17. Aug 4, 2018 at 8:21 PM
    Pudge
    CT
    You've become quite the seamstress @GAknight it looks great with that steering wheel, great idea and very unique.
    Is the grab bar worth the money? I'd love to have one but cant bring myself to spend the money.
    jewsNbrews likes this.
  18. Aug 4, 2018 at 8:32 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks man!
    I've always been a big DIY kind of guy. Nothing against buying unique items, but if I can figure out how to do something on my own, or have a creative idea, I go for it. My confidence for upholstery comes from several years of making my own tac/hunting gear.
    As far as the grab bar, I love it. I've got a 3" lift and while the side steps help, I always grab the steering wheel when getting in. Not no mo'. I've had it on for a day and love it.
    Pudge[QUOTED] likes this.
  19. Aug 4, 2018 at 8:43 PM
    mgm16trdpro
    Northern NJ
    Hmm, idk I'm guessing it all depends how many people in the tent. For me, I was looking at 4. 2 adults and 2 kids. Unfortunately, in my fam we are all beasts lol. Even my 9 and 4 yr old are big boys for their age. It would have to support at very least around 500 lbs and that's just in people. Idk know if adding 4 at 165lb each works like that. Maybe only way to find out is call manufacturers. I know as an alternative the DB can be drilled into. I probably shouldn't be hesitating to drill since I already took over an inch bit into my bed and made 4 holes for the bedslide. I'm not in any rush to figure it out though, got couple other plans and might have to wait until next year to figure this 1 out.
    KTJO 4x4[QUOTED] likes this.
  20. Aug 4, 2018 at 8:54 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Awesome job! Looks bad ass!
    How did you trim out around the pop caps that cover the bolts?
    GAknight[QUOTED] and KTJO 4x4 like this.
  21. Aug 4, 2018 at 9:23 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks man!
    I didn't trim the caps. I stitched the edges together, using the same technique as the steering wheel, while gluing down the center part of the handle (the part you actually grab). I left the ends unglued and just pulled the leather back (like how one might take off a sock). With the ends being larger, it wasn't an issue. Once the handle was installed, I popped the caps back in, applied some glue, then pulled the leather back down. Then I trimmed the leather to about 1/4" from the end, applied some glue, then tucked it under.
    I was consumed with the fitment and gluing the first time around and didn't take any pics. I'll take more as I do the passenger side.
  22. Aug 4, 2018 at 9:50 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    That’s COOL!
    GAknight[QUOTED] likes this.
  23. Aug 4, 2018 at 10:40 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    DAYUM @Jim LE 1301 that came out awesome! Glad you like it! :)
    T-Rex266[OP] likes this.
  24. Aug 5, 2018 at 4:41 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Painted the console trim yesterday and installed it this morning. I did it a little different than most. I used a dremel to to cut the plastic welds under the gray trim ring then drilled holes where they were. I removed the gear indicator plate so i could paint the shiny plastic area around the chrome around the shifter gate. After paint was dry, i used double sided foam tape to reinstall the gear indicator plate. I then used jb kwik to re-bond the trim ring to the larger black piece. Im happy with the results.
  25. Aug 5, 2018 at 8:01 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Smittybuilt winch installed this weekend
    0BFE6B82-512C-471B-8130-DD7BE5072ECC.jpg 0E080B49-80FC-4D23-A269-000BD682CC84.jpg
  26. Aug 5, 2018 at 8:24 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Truck looks great!
  27. Aug 5, 2018 at 8:41 AM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    what offset? spacers?
  28. Aug 5, 2018 at 9:41 AM
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    On mine or @GodlessPro ? I’m stock wheels, no spacers. I’m guessing you meant his truck setup!
  29. Aug 5, 2018 at 10:21 AM
    jaredmillerdvm
    Anderson, SC
  30. Aug 5, 2018 at 10:31 AM
    Blueknights75
    Ron
    Clayton, NC
    What company and where are you located in NC?
