Door issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thattundradude, Aug 2, 2018.
  1. Aug 2, 2018 at 6:41 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all. Got a issue that I can't figure out. My front passenger door does not lock nor unlock (and the window) from the remote and the driver side main control switch. The weird thing is that the front passengers door switch still rolls the window down and locks and unlocks all the doors.
    The auto light blinks for the passenger door
  2. Aug 2, 2018 at 7:07 PM
    RonW
    RonW New Member
    Is there a seperate fuse for the different sides maybe?
  3. Aug 2, 2018 at 7:39 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Could be a loose connection inside the door panel. When I took my door apart for sound deadening I ended up with a loose connection and had similar symptoms as you describe.
  4. Aug 2, 2018 at 7:40 PM
    Thattundradude
    Platinum Tundra
    Lifted
    No loose connections I just installed my speakers and all the connections are tight
  5. Aug 2, 2018 at 7:41 PM
    Was this occurring before the speaker installation?
    Pudge likes this.
  6. Aug 2, 2018 at 7:42 PM
    Pudge
    CT
    The fact you just did speakers makes me think even more it's a loose connection or displaced wiring pin in a plug somewhere in there
  7. Aug 2, 2018 at 7:44 PM
    Thattundradude
    Platinum Tundra
    Lifted
    It was doing this before
