Slight squeak sound coming from front susepnsion area
Discussion in 'General Tundra Discussion' started by REV51, Jul 5, 2018.
  1. Jul 5, 2018 at 11:01 AM
    REV51
    REV51 [OP] New Member
    Hey All,
    Brand new to the forum as well as a first time tundra owner!
    Just purchased a 2018 Trd sport with sr5 package. Truck has just over 1500 on the motor and I've been hearing this slight squeaking noise coming from the front suspension area when going over small bumps this developed after the truck got a little dirty from recent thunderstorms in my area so not sure if it's just because the suspensions is a little dirty thats causing the squeak or what. Any insight would be awesome I haven't been able to find anything through research but would like to save myself a pointless trip to the dealership ;). Truck rides fine otherwise.
    Thanks!
  2. Jul 7, 2018 at 5:31 AM
    SAHank
    SAHank New Member
    2018 tundra TSS 4x4 extended cab
    none yet
    I have a 2018 TSS 4x4 off road and when i make a sharp left turn I get a pop noise. Purchased truck 2 months ago, returning to dealer for repairs.
  3. Jul 7, 2018 at 6:47 AM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Howdy...maybe give it a hosing off under there
    Tundyfundy likes this.
  4. Jul 7, 2018 at 6:55 AM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    I have the same problem. Makes squeaking noise when the passenger side hits the bump. I m planning to find this rat in my suspension this weekend.
  5. Jul 7, 2018 at 7:59 AM
    15whtrd
    15whtrd Mr. Blonde
    My stock suspension was doing this as well. I thought it may be the skid plate as that seems to be a problem with some. But usually that is the TRD skid plate. I just have the standard stamped sheet metal version. I ended up lubing the front right coil spring after cleaning and it went away. But then it came back. I recently switched to used TRD pro suspension... and no more squeak! I want to say it has something to do with the isolator on top of the spring.
    Either way it’s not going to hurt anything it’s just annoying. I had quit giving a crap about it because I just figured...Truck, fuck it. But I am happy that it went away LOL
    Black Wolf likes this.
  6. Jul 7, 2018 at 8:12 AM
    Mssmith8
    Mssmith8 New Member
    2018 Tumdra Limited
    I have a 2018 Limited with a little over 8100 miles. I have this same issue and have had it since right after my 5000 mile service. I was going to get it looked at when I go in for my next service at 10,000. My wife swears I am just being picky, but if you guys figure it out PLEASE FOR THE LOVE OF GOD POST IT. There is nothing I hate more than a squeak or rattle on something where there should be none.
  7. Jul 7, 2018 at 8:14 AM
    I just turn up my country music station. Problem goes away.
  8. Jul 7, 2018 at 8:54 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    I will find that SOB rat. So many sleepless nights.
    HighDesertSurfer and Black Wolf like this.
  9. Jul 7, 2018 at 9:04 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I swear I have a similar issue, but I keep telling myself it's my son's car seat so I don't have to worry about it. However, to top it all off, my new canopy is squeaking like a SoB...
  10. Jul 7, 2018 at 9:24 AM
    Tombob26
    Tombob26 New Member
    Tombob26
    2018 CM TSS 4X4
    Just got mine two days ago and noticed the same squeak/pop. It sounds like it is coming from the drive front. I noticed with the wheels turned all the way the tires are really close to the fender liner. I'm wandering if that is what the noise is.
  11. Jul 8, 2018 at 11:34 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Ok, so after inspecting all the bolts and finding nothing wrong, I WD40 the hell out of my front suspension, engine bay etc. Any bolts I saw was sprayed. Empty the whole big can of WD40. Some squeak gone but some remains. Then I drove the truck for the rest of the day. All of the squeak is gone.
    Looks like Rat swallowed the cricket and then i killed the effing rat. No more listening to loud music to ignore the squeaking sound.
  12. Jul 8, 2018 at 11:50 AM
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    When I bought my 2014 (after coming from a 08 limited) I loved the re-design. After a bit I heard a weird high patched squeaking coming from the front end. Usually happened when I pulled in a driveway, speed bump, or Really any small bump. I looked under the hood and when I hit the top of the grill I could replicate the sound.
    Took it to the dealer and showed them. Turns out is was a loose horn bracket mounted just under the grill. They tightened it up and within a week or so it came back. Brought it back to the dealer and they opened a case on it. Turns out if was something defective horn mount. They did something that fixed it permanently.
    I have had no problems with my 2018 sport squeaking.
  13. Aug 1, 2018 at 6:23 PM
    REV51
    Hey Guys,
    Thanks for all the replies sorry I didn't respond sooner. Here's an update I figured it out and fixed it!!! Ended up taking several trips to the dealership and they could never replicate the issue. I even had the quality control manager ride with me and he didn't truly know what for sure cause of the noise was, I found another thread on here that talked about a similar issue that was related to coolant tansmission mounts behind the grille. The mounts are located at the top of the grille on the passenger and driver side they are two silver bolts with a rubber bushing on the bottom, to test if the mounts are squeaky just pop the hood and lightly tap the top of the grill with your fist when the truck is off. After doing this I heard the squeak coming from this area so I grabbed some silicone spray and just lubed the bushings on both mounts then took the truck for a test drive NO MORE SQUEAKING!!! I was able to easily lube the bushings through the grill since I have the blacked out honeycomb grill.
    It's been almost a month now still NO SQUEAKING!!! :yes:
  14. Aug 1, 2018 at 7:50 PM
    Vizsla
    Vizsla 2 = 2.5
    You mean this?
    Almost drove me nuts. It is adjusted too tight from the factory, if it starts again, just loosen the mounting bolts, let it sit more neutral, and tighten.
  15. Aug 1, 2018 at 7:57 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Yep the condenser mount bushing
    NewImprovedRon and MistrRoboto like this.
  16. Aug 2, 2018 at 5:49 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good find!
  17. Aug 8, 2018 at 6:03 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Yes, thank you! Same noise on my 18. Popped hood and tapped above the area you circled, sure enough squeaked like a mouse. Now just need to loosen it and try the fix. Fingers crossed.
  18. Aug 8, 2018 at 6:19 PM
    TheBeast
    TheBeast The Beach
    good to know
  19. Jan 24, 2019 at 12:30 PM
    mattdrummer83
    mattdrummer83 New Member
    3+1 level w/king 2.5's front and back, 18" Method Bronze NV, Total Chaos UCA's.......the money doesn't stop being sucked outta my wallet for my baby
    mother of god, I hope this stops my issue to. I thought it may have been from the front sway bushing, which I replaced, and then it was still there, then I thought ok, maybe the shitty spacer for the leveling kit I had on, and finally upgraded the shocks, so no spacer anymore (which I wanted to do anyway), but sure enough still there, and yeah, only on my passenger side when the passenger side suspension goes over a bump through a drive way. I swear the squeak turns heads too. makes me crazy. Thanks for disclosing the fix, fingers crossed it's the same for me. i'll do back flips and cart wheels if it resolves the issue.
  20. May 28, 2019 at 9:15 AM
    So I messed with mine over the weekend. The bolt does not thread into that funnel looking insert. I took the insert out and put the bolt back in. I'll see if my squeak is gone now on my drive home this afternoon.
    georgiey22 likes this.
  21. Jun 25, 2019 at 9:20 PM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Any updates?
  22. Jun 26, 2019 at 4:16 AM
    Still chasing it and its driving me nuts. I'm going to take the bolts out completely to see what happens.
  23. Jun 26, 2019 at 1:52 PM
    Ntmid8r
    Ntmid8r New Member
    TBA
    Siliconed mine and took minimal noise away. Gonna check the other areas mentioned earlier in the thread
  24. Jun 30, 2019 at 5:45 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    THANK YOU!!!!! Finally got rid of my squeak..... silicone spray on both bushings and no more squeak on rough roads. Was driving me nuts!!
  25. Jun 30, 2019 at 1:15 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Can you share which bushings specifically?
  26. Jun 30, 2019 at 1:17 PM
    Chris001
    Chris001 New Member
    Ontario, Canada
    The bushings in the pic on post #14.
    georgiey22[QUOTED] likes this.
  27. Dec 21, 2019 at 7:37 PM
    jacked3d
    jacked3d New Member
    i was convinced it was my suspension, specifically the sway bar bushings. All of everyone's posts, above, made me look to the center, behind the grill. During my search, I noticed the hood latch had missing paint and bare metal showing. I grabbed a dab of grease, just for testing purposes, and applied it on the latch loop, hood-side. Squeak gone. My wife's 4Runner had the exact same squeak, only 14 months old. Applied the grease....gone. Anyway, if you can't find it, make sure you look at the latch... at least to rule it out.
  28. Dec 21, 2019 at 9:07 PM
    georgiey22
    After months of searching I just found the two creaks and squeaks!
    1: The windshield washer fluid hose that runs along the interior of the inner engine bay fender on the passenger side is moving and tapping the fender. Added an adapter and zip tie so there is no longer a tap and the wire can’t move. See the first photo?
    2: The ‘louder’ creak was coming from the area that I thought was the windshield cowl and what looks to be the A/C lines or break lines, along the firewall. They each sit in a plastic bracket that is designed to keep them from moving, bending or touching each other. When I applied a little pressure to them, they all replicated the creaking sound. I generously hit each of the fixed mounts with a spray dry lubricant and the creak is gone. See photo 2?
    Hopefully this can help someone else.
    S. Equoia, YardBird and GODZILLA like this.
  29. Jul 2, 2020 at 10:18 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Great thread the deserves a bump
  30. Jul 5, 2020 at 8:22 PM
    van
    van New Member
    Van
    '08 5.7 Dbl TRD ; EggNoG
    Custom Thru Fender Exhaust Custom Bull Bar Custom Body Paint Custom SS Hood Vents ...Lights, etc..etc..
    ..yeah but that's Another problem now
