  1. Jul 24, 2018 at 10:39 AM
    #2131
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    Park Road 22, past the visitors center, and onto the beach.
  2. Jul 24, 2018 at 11:13 AM
    #2132
    Sorry, I meant through which town?
  3. Jul 24, 2018 at 11:33 AM
    #2133
    Lars
    Lars
    Cedar Creek Texas
  4. Jul 24, 2018 at 12:47 PM
    #2134
  5. Jul 24, 2018 at 8:16 PM
    #2135
    airosey
    airosey 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Installed some RGB rock lights. B2E8E753-33E8-4710-8CFD-9541CBB09A47.jpgE8B75C2D-2080-42A0-BDD7-C9F7ABB7CE29.jpg
  6. Jul 25, 2018 at 5:15 PM
    #2136
    Lars
    Lars
    Cedar Creek Texas
    This was kind of a whim purchase. My truck spends 98% of it's time doing highway speeds in Texas. I think the slight reduction in articulation for that other 2% is likely worth it...
    Sequoia TRD Front bar is on it's way but not here yet.
    Tor, Trooper2, Rica25 and 3 others like this.
  7. Jul 27, 2018 at 6:07 AM
    #2137
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    @Lars dude your truck is badass. First time I seen a full pic of it!
  8. Jul 27, 2018 at 8:19 AM
    #2138
    Lars
    Lars
    Cedar Creek Texas
    Thanks. I'm going to drill five holes through the roof next week, and move some of the bed side mounted antennas around.
    Pale_Horse[QUOTED] likes this.
  9. Jul 27, 2018 at 2:14 PM
    #2139
    Pale_Horse
    FL
    Cupcake chit.
    Installed SDHQ ditch light mounts. Caliraisedled side shooters and Baja designs fogs.
    Tucking
    the wiring:
    Really happy with the end result.
  10. Jul 27, 2018 at 2:29 PM
    #2140
    Well I drove it to work and keep checking out how great a Tundra looks!:D
  11. Jul 27, 2018 at 7:36 PM
    #2141
    Punisher17
    Punisher17 New Member
    Ok so I'm gunna post my updates..
    Front TRD sway bar. Rear OME shocks. And also!!!! I wrapped nearly all the AC lines under the hood with this and it makes the AC perform a lot better. Enough for 8 dollars was worth it lol.
    And a couple other pics
    Les7311, DalTee, Trooper2 and 4 others like this.
  12. Jul 27, 2018 at 7:41 PM
    #2142
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That really helps the AC? Its a great idea and cheap upgrade for sure.
    Mountun Goat likes this.
  13. Jul 27, 2018 at 8:27 PM
    #2143
    Punisher17
    I can tell a difference. It is slight but like I said worth 8 bucks and the 20min it took to zip tie it all on. The line right at the firewall was hard to get to but I was able to get it on there.
  14. Jul 28, 2018 at 5:57 PM
    #2144
    Pale_Horse
    FL
    Cupcake chit.
    Took her out to the Everglades this morning to prep for deer season...
    Remote start install this afternoon, should have done this years ago...
  15. Jul 28, 2018 at 6:04 PM
    #2145
    Rica25
    Ricardo
    Tulare
    How much and how difficult was it
  16. Jul 28, 2018 at 8:15 PM
    #2146
    Pale_Horse
    FL
    Cupcake chit.
    @Rica25
    I bought one for each of my vehicles off someone who sells them on Tacomaworld. I think the tundra was $250. Most difficult part was taking out the glove box. All wiring was plug and play. Very easy. If you have taken apart your interior before than it is less than 30 mins install. If you aren’t familiar than it could take 60-90 mins just fumbling with things...
    Actually I didn’t put the dash back together so maybe I will take some pics of everything involved and post them tomorrow.
  17. Jul 29, 2018 at 5:20 PM
    #2147
    Pale_Horse
    FL
    Cupcake chit.
    This is for a 2nd gen. 3x lock remote start, plug and play using factory fob. By Fortin.
    2 screws and 1 bolt removes driver side.
    1. Remove screw on each side behind steering wheel:
    Take those 2 screws out and remove bottom plastic under steering wheel.
    2. Remove this bolt:
    And use your hands to pull off the ubderdash like so:
    3. Remove glove box. Use these pics as reference:
    4. Wiring. This plug and play harness is a T harness meaning you unplug the factory plugs, plug in the harness connectors and plug the factory plugs into the harness:
    Behind glovebox
    Under ignition:
    Left side under driver side:
    OBD2 connection
    Feed the one for behind glove box with coat hanger thru here:
    5. Plug in the brain using remaining harness connections and program to vehicle following instructions. Very simple(pressing a button and turning ignition on/off).
    Test it out and put everything back together. Use zip ties to run the wiring harness clean and hold the brain in place. Make sure around the steering wheel everything is out of way of steering tilt lever and snug...
    Nemesis, Les7311, Quebec and 2 others like this.
  18. Jul 29, 2018 at 5:24 PM
    #2148
    Lars
    Lars
    Cedar Creek Texas
    Do you have a link for this?
  19. Jul 30, 2018 at 5:12 AM
    #2149
    Pale_Horse
    FL
    Cupcake chit.
    @Lars
    I don’t have a link. I bought them directly from someone who supplies them on tacomaworld. I highly reccomend buying from him, his customer service has been great.
    You can contact him:
    jmeitz@hotmail.com
    GV1990 and Lars like this.
  20. Jul 30, 2018 at 5:50 AM
    #2150
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    That is awesome! What actually connects behind the glove box? Is the brain staying on the drivers side or is it run to the passenger side?
    Lars likes this.
  21. Jul 30, 2018 at 8:58 AM
    #2151
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    C0A89F63-9E09-4D7F-8E9C-8CEA21D39D06.jpg Finally got mine a proper detail job(hand wash, clay bar, buff, and hand wax).
    There is a short bit of woodland Pinstriping on the pass side I’ll need to buff out better, but she is shiny and silky smooth!
    I can finally get my blue Pinstriping laid down now!
    Hattori, Les7311, Civiceg94 and 6 others like this.
  22. Jul 30, 2018 at 3:57 PM
    #2152
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I like those wheels
    Mountun Goat and GI Joe[QUOTED] like this.
  23. Jul 31, 2018 at 6:28 AM
    #2153
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    Thank you! They are Factory Rock Warrior wheels! I like them better than the 18’s that came with my TuRD package.
  24. Jul 31, 2018 at 3:05 PM
    #2154
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Finally no more chrome grill surround!!! The chrome bumpers don’t bug me AS bad but they’ll go eventually.
    Found the entire grill for $200 new from dealership. Install took 5min.
    1DF09371-7F51-421C-990B-73A8A36F4B2F.jpg D694B142-ECD5-4AB3-B181-16D6F69954F1.jpg
  25. Jul 31, 2018 at 4:24 PM
    #2155
    parker44
    parker44 New Member
    Do they keep these easily accessible to order? Been thinking about doing this to mine when it starts chipping.
  26. Jul 31, 2018 at 4:26 PM
    #2156
    CaptTyler
    Tyler
    Check eBay. These came from a dealership on the east coast of FL that sells them through eBay. But yes the place I got mine from had several in stock.
  27. Jul 31, 2018 at 4:27 PM
    #2157
    parker44
    parker44 New Member
    Good to hear. I’ll have to see if they stock the desert sand color.
  28. Jul 31, 2018 at 7:36 PM
    #2158
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Mounted my new whip flag:canada:. Then I cut off these skid plate corner pieces as the tires rubbed at full lock. They were flimsy but would guard the control arm bushings from debris. I’ll cut them for the final tire size later and remount them.
    Pale_Horse likes this.
  29. Aug 1, 2018 at 4:51 PM
    #2159
    Lars
    Lars
    Cedar Creek Texas
    Yesterday I got a new, smaller pair of shoes. These will be used 90% of the time since I'm on the highway driving to and from work.
    So far the plan is to keep the Rock Warrior wheels with the 315/70 R17s unless someone offers me one hell of a deal for them.
    I also got something delivered by a big rig today.
    What's in the Box?
    Sorry for Potato Photos...
  30. Aug 1, 2018 at 6:14 PM
    #2160
    Pale_Horse
    FL
    Cupcake chit.
    The brain stays on driver side. The very first pic under ‘4. wiring’ on my write up is the connection behind glove box.
    This one:
    parker44[QUOTED] likes this.
