"Waterproof Fuse Relay Box" (WFRB) vs sPOD/Switch Pros
Discussion in 'General Tundra Discussion' started by Sas, Jul 24, 2018.
  1. Jul 24, 2018 at 9:56 AM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    With the LED's that came in yesterday I got to thinking about proper wiring management. In my search for solutions I came across this. Seems pretty bad ass. I think someone was selling a similar, larger Bussman on the forums a while back as well.
    What do you all think? https://www.youtube.com/watch?v=fyqTt-KscvE
    oems1794 likes this.
  2. Jul 24, 2018 at 12:27 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I ran the spod for a while, but hated the location of the switches. I now run the switch pros system with the sdhq shifter mount and couldnt be happer
  3. Jul 24, 2018 at 12:48 PM
    Sas
    OKC, OK
    Care to upload a few pics? I'm curious about cable routing and management as well when it comes to adding accessories.
  4. Jul 24, 2018 at 12:57 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    dcsleeper408 and Sas[OP] like this.
  5. Jul 24, 2018 at 1:01 PM
    Sas
    OKC, OK
  6. Jul 24, 2018 at 1:05 PM
    Cfincke
    San Antonio
    Since I did the design work and prototyped different sheet metal versions, he gave me a deal if I would let them use the design for future customers.
    I worked with Maverick - Maverick@powertrays.com
  7. Jul 24, 2018 at 1:07 PM
    Sas
    OKC, OK
    Thanks, I'll look him up when I get a solution nailed down.
  8. Jul 24, 2018 at 1:58 PM
    DexterL
    DexterL New Member
    search for posts made by me and they will pop up- look in the baja designs thread
  9. Jul 24, 2018 at 3:18 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I have a few of mine here: Switch Pros Install :)
    Sas[QUOTED][OP] likes this.
  10. Jul 24, 2018 at 3:22 PM
    Sas
    OKC, OK
  11. Jul 24, 2018 at 5:03 PM
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    @Sas Damnit. Looks like I'll be redoing my wiring... again. Excellent find, thanks for sharing
    Sas[OP] likes this.
  12. Jul 24, 2018 at 8:54 PM
    Cfincke
    San Antonio
    Sas[OP] likes this.
  13. Jul 24, 2018 at 11:46 PM
    Sas
    OKC, OK
    Need more of this. I love building stuff and this is new territory so I'm highly considering building one from scratch just for the fun of it.
    Help likes this.
  14. Jul 25, 2018 at 5:24 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    How many fuses and relays do you need?
  15. Jul 25, 2018 at 5:58 AM
    Sas
    OKC, OK
    Not sure just yet. Still planning out the build. But obviously want enough to accommodate changes and future add-ons.
  16. Jul 25, 2018 at 8:51 AM
    Cfincke
    San Antonio
    I was going to build mine, but the minimum quantities for different components would have made it more expensive. There were a few people on TW that built them and would only do in batches of 5 or more. Mine has all the weatherproof quick connects sobi can remove the fuse block if needed
  17. Jul 25, 2018 at 9:15 AM
    Sas
    OKC, OK
    Bummer! Thanks for the info.
  18. Jul 25, 2018 at 10:23 PM
    Help New Member
    Tucson, AZ
    I'm gonna DIY one anyway, mostly for shits n giggles. I'll keep a tally of expenses
  19. Jul 26, 2018 at 3:20 AM
    Over the LINE
    New Orleans
    Check Amazon, plenty of parts there.
    Sas[OP] likes this.
  20. Jul 26, 2018 at 8:06 PM
    Help New Member
    Tucson, AZ
    On small stuff, like this project requires, Amazon isn't the cheapest place to get it. Looks like the biggest draw back to this is the parts needed must be purchased in bulk or you pay a ton more per piece. (100 waterproof 18AW plugs = $6 or 5 for $13). I'm gonna have a ton of extra stuff leftover lol
    lionix likes this.
  21. Jul 26, 2018 at 8:32 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Sell a setup to pay for parts.
    Sas[OP] and Help like this.
  22. Jul 27, 2018 at 6:10 AM
    Cfincke
    San Antonio
    I spend around $100 investing in a lot of the Metri-Pack 280 series 30A rated waterproof connectors and all the little pieces that would be needed so I can make my own harnesses.
    Sas[OP] likes this.
  23. Jul 27, 2018 at 7:51 AM
    Over the LINE
    New Orleans
    I do pretty well with boat/marine electrical parts on Amazon. When I put my truck together I guess I did end up with a handful of extra relays.
    As you can see, I mounted my fuses and relays in different places. I looked at building something like you are talking about but I did not want to mount it to the top of the factory fuse box and I had trouble finding something that would fit in the area I wanted it.
    Sas[OP] likes this.
