  1. Jul 24, 2018 at 5:28 AM
    Onaracsjh100
    Onaracsjh100 New Member
    H
    2018 dc 8’
    Toyota 8’nonskid Bed liner
    I would look for any unusual hacks by umbrella Corp to your devices
    HecticEnergy likes this.
  2. Jul 24, 2018 at 6:35 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    o_O
  3. Jul 24, 2018 at 7:56 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I am using the 1" setting. With 2" level in front and all of my kids swim gear in the back I still have ~ 3/4" of rake.
    bowhun2r[QUOTED] likes this.
  4. Jul 24, 2018 at 8:59 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    TVD came through with these. Easy to install and quality seems good. I like how the wrap around inside the vents.
    They do leave a little chrome on the outside lip but not much you can do about that.
  5. Jul 24, 2018 at 9:02 AM
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    This morning I did check the torque on all the sway bar bolts. All to spec. What did surprise me was my bed bolts were easily turned a half before coming up snug. I did have my bed Rhino lined before I took delivery...I wonder if they removed the bed to do it. Will have to check around for the proper torque settings on the bed bolts. It did subside the "klunk" a bit, so I'm on the right track.
    thanks,
    Scott
  6. Jul 24, 2018 at 9:38 AM
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    Thank you @NewImprovedRon !
    My bolts were free of liner...so they did remove them. Did some searching and found 62 lbs/ft is the torque spec. Earlier this morning I just had my socket wrench on it and turned it. Put my torque wrench on it and it was almost another 3/4 turn before hitting that spec. Guess what... no more klunk going up my driveway. Makes sense. I didn't have this sound until about a month ago it was hardly noticeable. Last week or so it was KLUNK...KLUNK going up driveway. Almost embarrassing...should not have let it go that long.
    When it's not 90 plus out with high humidity I'll remove them one at a time and put red locker on them.
    Ha!! love this place.
    Scott
  7. Jul 24, 2018 at 9:42 AM
    Pudge
    CT
    Go for it Ron. Easy to do and he gives you 6 decals in case of a slip up. They were $14. Not bad at all. Great customer service as well.
    HecticEnergy and NewImprovedRon like this.
  8. Jul 24, 2018 at 9:43 AM
    Pudge
    CT
    I was talking with @DecalsByDesign about making some. Hasn't happened yet but it would be cool to do those too
    NewImprovedRon likes this.
  9. Jul 24, 2018 at 9:46 AM
    Pudge
    CT
    I'll admit, I used 5 haha
    Also ordered his stereo TUNDRA letter inserts. Will be putting those on when they arrive. Initially I was sent the wrong size set but he fixed that in a matter of a few hours
  10. Jul 24, 2018 at 9:58 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Yep, allowed me to try my little stretch experiment to cover some of the outer chrome. Unstretched, this area isn’t covered as much or at all.
    NewImprovedRon and Pudge like this.
  11. Jul 24, 2018 at 9:59 AM
    Pudge
    CT
    Wow nice job.
    JoshuaA[QUOTED] likes this.
  12. Jul 24, 2018 at 10:04 AM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    What Rack and Lights are those?
    Darren509 likes this.
  13. Jul 24, 2018 at 10:22 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    You get 2 sets, good thing as I didn’t like the way my first try at “N” sat. Supposed to dip them in soapy water and remove from the backing with painter’s tape, not use your fingers. The wetness allows you to slide it around but they’re a solid fit once centered.
    Pudge[QUOTED] likes this.
  14. Jul 24, 2018 at 2:13 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    What color did u get black or charcoal? Tia
  15. Jul 24, 2018 at 2:22 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    @Pudge I'm losing all my business to TVD! :puke:
    I've seen his stuff, he has a lot to offer, I just don't have the time or energy to keep up with all the small stuff and my vinyl is much more expensive at cost. I will do my best to get a store up for everyone.
  16. Jul 24, 2018 at 2:25 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Im not running off...i like the designs you come up with. Btw....i want to pull the trigger on the hood flag i asked you about
  17. Jul 24, 2018 at 2:26 PM
    X2:thumbsup:
  18. Jul 24, 2018 at 2:37 PM
    mgm16trdpro
    Northern NJ
    Love the idea, can u put a rtt on top of those thule racks?
    Also what was ur method to get the chrome edges covered by stretching?
  19. Jul 24, 2018 at 2:40 PM
    mgm16trdpro
    Northern NJ
    Looks great, how long it take u? I've got conflicting reports.
  20. Jul 24, 2018 at 2:47 PM
    Pudge
    CT
    I totally understand all that man. I want knocking you at all. You have awesome stuff. And some of the most unique custom stuff which is what makes your business the best on this site
  21. Jul 24, 2018 at 2:53 PM
    DecalsByDesign
    Eagle, CO
    Yea he's got the inlays and what not dialed! I've looked through his store.
    NewImprovedRon and 4x4_Angel like this.
  22. Jul 24, 2018 at 3:13 PM
    mgm16trdpro
    Northern NJ
    Sorry been away for a bit n just catching up now. Not sure because I sold that setup. I've moved onto a gen y hitch and will revisit lighting for rear soon. Will post when I do it.
  23. Jul 24, 2018 at 3:35 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Don't you make the awesome bigger decals like on BlueBottle's? These look sick!
    Thread: https://www.tundras.com/threads/vinyl-graphics-by-decalsbydesign.24405/
    Honestly, I didn't choose by vendor name, I happened to see letter inserts and ring covers on ebay... which is another store presence you could explore if you're not there. I think you make a fantastic different product :cheers:
  24. Jul 24, 2018 at 3:50 PM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
  25. Jul 24, 2018 at 4:37 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Which RTT Mike?
    Re: the blackout rings, I did it by accident. I followed the TVD instructions to do the inlays, did those first, which is to dip it in soapy water first. I thought it was the same method for the rings (it's not).
    I removed the backing, dropped the square in the bowl of soapy water, painter's tape couldn't peel it away from the 2nd backing which I thought was odd so I carefully used my fingers and pulled the ring off which stretched it out slightly. I re-dipped the naked ring in the soapy water and I could basically slide it exactly where I wanted. The ring looks like it's not going to lie flat but gently push out all the bubbles and creases, let it dry a bit, repeat. When the ring is tacky enough where it's sticking all the way around flat, I start working the inside and outside. It started getting dark and I stopped at one.
    When I went in and looked up the instructions, it states it's a dry transfer tape application, I thought I f'd up the first one and it wouldn't stay. The next day I put the second one on the proper way and I could see the chrome around the outside, didn't like it. To my surprise, the first one was fine. I decided to do the other 3 the wet way. Worked out great, how it looks right now, I don't know if these pics are any clearer than previous.
    Inside of ring:
    Outside of ring, camera angle where my head is basically at the windshield looking down, so normally you can't see any chrome but you can see a sliver of it here:
  26. Jul 24, 2018 at 4:45 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I got the matte black ones. And I have the sliver of chrome still showing too but my solution is to put some orange trim pieces - https://www.amazon.ca/gp/product/B07DNDR21P/ref=oh_aui_detailpage_o01_s00?ie=UTF8&th=1 - around the edge to hopefully cover that up. As much as I like blacking out all the silver/chrome trim it's getting a little too monotone in colour so hopefully these orange trim pieces stick on nicely and are the right size to add a little colour to the black.
    mgm16trdpro[QUOTED] likes this.
  27. Jul 24, 2018 at 5:25 PM
    DecalsByDesign
    Eagle, CO
    Hey thanks!! I appreciate that! I know I have explored it just struggle to put out a bunch of smaller orders together while I’m working on one huge project locally. Most of my income comes from wraps and vehicle graphics for fleets.
  28. Jul 24, 2018 at 7:14 PM
    mgm16trdpro
    Northern NJ
    Tnx for info on ac rings. For the rtt could it support something like the cvt?
  29. Jul 24, 2018 at 7:16 PM
    mgm16trdpro
    Northern NJ
    Tnx for info and great idea on the trim.
    jewsNbrews likes this.
  30. Jul 24, 2018 at 7:23 PM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    Did the wireless phone charger mod in the center console.
    Worked on both my phone (iPhone X with Otterbox symmetry case)and my wife’s (iPhone 8+ With thin plastic case pictured) regardless of position. Will work on cleaning up the hidden wiring within the console later.
    Firepiko, JJ305, GAknight and 6 others like this.
