Change speakers but keep factory amp?
Discussion in 'Audio & Video' started by Thattundradude, Jul 14, 2018.
  1. Jul 14, 2018 at 7:40 AM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all. I have a 2014 tundra with the jbl system. My question is can I change the speakers and keep the factory amp or will that need to be replaced.
    Also if anyone has taken all their jbl system out I'm interested in buying. I'm not 100% sure if the door speakers are still in there I'm going to hook up my HU and open up the door panel.
  2. Jul 14, 2018 at 7:56 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I removed the entire non JBL system out of my truck. Let me know if interested.
  3. Jul 14, 2018 at 8:27 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    The speakers in the jbl systems seem to be decent. Its the head unit and processor that are poo poo.
    Do it right and gut the entire system.
  4. Jul 14, 2018 at 9:00 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Sweet, how much do you want. I have a Phoenix android unit that I need to install
  5. Jul 14, 2018 at 9:06 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    What is it that you want?
  6. Jul 14, 2018 at 9:35 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you replace your headunit and get some kind of adapter to make it all flow, forgot what it's called, you'll probably be fine. Many say a new headunit really helps the stock system come alive
  7. Jul 14, 2018 at 9:59 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Only problem is I don't know what is installed. I bought it from an auction and the owner took everything out. I have to open up the door panel to see if the speaker is still there. Just waiting on the body shop
  8. Jul 14, 2018 at 10:18 AM
    Pudge
    CT
    Best bet would be to check and see what's there and what's not and report back. There are 3 speakers I'm dash. 2 speakers in all 4 doors, amp under passenger seat, and should be a sub behind driver side back seat.
  9. Jul 14, 2018 at 10:51 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Tweeters amp and sub is def long gone
  10. Jul 14, 2018 at 11:18 AM
    fullofbs
    fullofbs Project SnowFlake
    Are the front speakers different size depending on the package? I've seen some people say 6.5 and some say 6x9
  11. Jul 14, 2018 at 11:20 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    at this point I'd say it's a no-brainer to go full aftermarket
    Pudge likes this.
  12. Jul 14, 2018 at 11:32 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I think 6x9 is only for the front and 6.5 are for the rear
  13. Jul 14, 2018 at 11:34 AM
    Pudge
    CT
    Dont waste your time and money. Get aftermarket stuff and start fresh
    ^^^ this
    New head unit. 5 channel amp. Components in doors, new sub and be done with it. Just disconnect dash speakers. Some days I wish my truck was stripped out lol.
  14. Jul 14, 2018 at 11:35 AM
    Pudge
    CT
    I think the size isn't exactly 6x9, most get adapters with speakers and run 6.5 or 5.25 components in doors. And if you're running a sub there's really no need for 6x9s
  15. Jul 14, 2018 at 11:36 AM
    fullofbs
    Great thanks.
  16. Jul 18, 2018 at 4:47 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    front are 6x9 but they come with a housing that needs to be replaced because they don't sit flush against the frame. back are 6.5. There's also an install depths you gotta meet. I love my pioneer hu but kenwood offers more features for the same price.
  17. Jul 20, 2018 at 10:33 PM
    Thattundradude
    Platinum Tundra
    Lifted
    These are the only remaining plugs
  18. Jul 21, 2018 at 6:05 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Do not waste time or money to install factory JBL amp and speakers especially since you have an aftermarket headunit. The factory JBL amp has a lot of noise to it. Just go full aftermarket and be done. I kept the JBL headunit so I had to install an expensive processor to provide a full range signal to the aftermarket amps.
