46 gallons
Discussion in '2.5 Gen Tundras (2014-2021)' started by DKofTampa, Jul 3, 2018.
  1. Jul 3, 2018 at 7:16 AM
    DKofTampa
    DKofTampa [OP] New Member
    2014 Tundra Limited/XP
    NSV bulge light 46 Gallon Transferflow Carven exhaust Rhino 2.0 sport bar
    45E4C7BE-32D5-4805-8532-263DBD0A026E.jpg Picked up my new TransferFlow tank today. Will post as many pictures with details as I muster up the energy to get it started.3CA1C7E3-8014-495B-A4D9-692BAD9DFBE6.jpg
    Sas, 1UPPER, Coolhardy and 3 others like this.
  2. Jul 3, 2018 at 7:30 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    That’s a lotta petrol..... 15 gallon reserve? :rofl:
  3. Jul 3, 2018 at 7:32 AM
    I wanna see pic of gas station pump total price n gallons
    1UPPER and HecticEnergy like this.
  4. Jul 3, 2018 at 7:33 AM
    nodak67
    nodak67 New Member
    JR
    lol, good luck trying to get past the $100 limit on gas pumps. pita having to cycle twice to fill up an empty tank.
  5. Jul 5, 2018 at 8:14 AM
    DKofTampa
    Install done. Took friend and I about 5 hours. Used instructions from TransferFlow which were pretty thorough. Have digital copy they sent me should anybody want it.
  6. Jul 5, 2018 at 8:32 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Im around $80-85 for a full tank of unleaded with my 38gal. good luck with the big girl!
    It's nice not having to fill up every couple of days
    HecticEnergy likes this.
  7. Jul 5, 2018 at 8:34 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    I so wish the CA EPA would allow this :(
    5.7TRDProm, sdde4n and Darren509 like this.
  8. Jul 5, 2018 at 10:25 AM
    lackeycc
    lackeycc New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    S&B CAI Raptor lights OME 612 Cooper STT PRO 295/60R20 5% Tint Husky Liners Rigid D2 Fogs on OEM Switch
    Did you have to recalibrate your gauge?
  9. Jul 5, 2018 at 10:26 AM
    lackeycc
    lackeycc New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    I’ve been thinking about pulling the trigger on one of those myself.
  10. Jul 5, 2018 at 10:39 AM
    itsdchz
    Clovis, CA
    after a 4034 mile trek with our 30ft trailer, I am so hating the 26 gallon that makes me nervous as heck at 19.5 gallons empty (low fuel light) and giving me the "you better stop or else" refuel at 20.5 gallons used!
    myt1 and TexasTundra27 like this.
  11. Jul 5, 2018 at 1:34 PM
    DKofTampa
    I am not positive on calibration or not at this point. I filled my mobil 14 gallon tote and emptied the whole thing in. When i reconnected my battery, it showed a little above 1/4 tank. The height difference between the transferflow and the oem is not that much of a difference. (Will measure them when i get the time) I also put a level on the top of my tailgate and found there was a bit of a lean, but not what i expected. The drivers side is a bit higher. Will have to check it out when i fill the tank all the way up. I realize that a full tank with the oem is going to show X miles whereas the new tank will still show the same amount for the same level. I may check into if it’s possible to show the extended range, but I won’t lose any sleep over it.
  12. Jul 5, 2018 at 1:42 PM
    DKofTampa
  13. Jul 5, 2018 at 1:57 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    So u have transfer flow AND OEM 38gal tank?
  14. Jul 5, 2018 at 2:08 PM
    DKofTampa
    No. The oem was a 26.4. The transferflow replaces it.
    RLHULK likes this.
  15. Jul 5, 2018 at 2:42 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    I wouldn't mind having those instructions. Maybe something I can do in the future.
  16. Jul 5, 2018 at 2:53 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I always assumed it hung below the frame further than that, looks good!
  17. Jul 5, 2018 at 3:05 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I might be towing a car from Denver to Jacksonville in APril, I need to get one of these before then, because that is too far for a 26 gallon tank
    Coolhardy likes this.
  18. Jul 20, 2018 at 2:23 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Curious if this gets in the way of installing rock sliders and/or RCI skid plates. I'd like to upgrade from the 26 gallon one at some point, but don't want a larger tank to get in the way of any other upgrades.
  19. Jul 20, 2018 at 3:22 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    We should try a group buy w transfer flow or LRA.
    itsdchz likes this.
  20. Jul 20, 2018 at 3:29 PM
    itsdchz
    Clovis, CA
    Would love that! I am most likely going to find a dealer in Nevada to drive to and install since CA EPA will not allow!
  21. Jul 20, 2018 at 4:34 PM
    DKofTampa
    Will try to get some better pictures of the tanks location in the next few days.
