How many swap out wheels but run stock tires...
Discussion in 'Wheels & Tires' started by cfred70, Jul 13, 2018.
  1. Jul 13, 2018 at 1:41 PM
    cfred70
    cfred70 [OP] New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    I've had my tundra now for about 6 months and I thought the TRD wheels would grow on me, but I really like the all black look. I'm debating between picking up some new wheels or powdercoating the trd wheels. Got me wondering though, I see so many people on here that swap out tires and wheels, and some that swap out just tires, but does anyone run the stock Michelins on after marker wheels.
  2. Jul 13, 2018 at 2:10 PM
    zapman29
    zapman29 New Member
    Jake
    2018 Toyota Tundra SR5 Crew Max TSS Off Road 4X4
    My truck came with 20 inch black rims and the BFG 285 55 r20's so im happy with my tires and wont change until these tires need replacing
  3. Jul 13, 2018 at 4:57 PM
    JakeyTheMost
    JakeyTheMost New Member
    Jake
    2018 Cement Tundra
    Nothing wrong with the stock tires but they just look boring to me.
  4. Jul 13, 2018 at 5:12 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I vote aftermarket. You can get a little more aggressive offset and improve the stance. When I see stock Tundra wheels now they look a little weak to me. But, if you’re going to go aftermarket or even powder coat you need to remove the tire so if you can swing it I say get a more aggressive looking tire to round it out.
    I sold my wheels and tires with 8,000 on them as a set for 1100. They were gone within 5 hours of posting and that will get close to covering tires.
    Also remember that if you change tire size it would be wise to get a spare in the same size. I bought a cheaper AT spare for 130 bucks and had them mount it up.
    joonbug likes this.
  5. Jul 13, 2018 at 5:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Biggest problem is most aftermarket wheels are wider than the stock wheels and the stock tires are a little on the skinny side for 9” wide wheels.
    BTBAKER likes this.
  6. Jul 14, 2018 at 4:43 AM
    cfred70
    Craig
    Ohio
    Do you stick with an 18” wheel or step up to the 20”
  7. Jul 14, 2018 at 7:02 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I run 18s.
    joonbug likes this.
  8. Jul 14, 2018 at 10:17 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wheel size is mostly just preference in looks. But the 18’s will have a better and softer ride, especially if you Offroad your truck. Not to mention the tires are generally cheaper. On cars, I like bigger wheels with low profile tires. But on trucks, I definitely think smaller wheels with meaty tires look way better. Most important thing when choosing a wheel is the offset.
    jewsNbrews likes this.
  9. Jul 14, 2018 at 11:27 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I swapped out both. Just didn't like the looks of the TRD wheels, plus I wanted a different stance. I needed a better offroading tire for when I am hunting. For now the truck is a dd, but one day it won't, and then it will get a new suspension and slightly larger tire
