2018 LEDs vs Retros
Discussion in 'Lighting' started by mart1nezdaniel, Jul 7, 2018.
  1. Jul 7, 2018 at 3:22 PM
    mart1nezdaniel
    mart1nezdaniel [OP] AZ
    Arizona
    Tundra TRD PRO 2017
    Haven't had much experience with either and i cant seem to get a good solid answer either way with the plethora of information on the existing threads.
    From the looks of it retros are more expensive and may not be as high of quality. But i think they look better.
    Let me know yours thoughts if you've owned both.
  2. Jul 7, 2018 at 4:01 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Not owned both but have driven both.
    Retros are marginally brighter, LEDs are more reliable, especially if you read up on some of the forums with people's experience.
    I have Retros, I love them, built them myself using @MotoTundra 's awesome guide. I didn't do any of this halo, fancy led strip crap though. Projector, bulb, done. I was meticulous in how I made and wired them since they're super sensitive to poor grounding. I also had a bad experience with a bad igniter... Aftermarket components generally won't have the reliability of OEM.... If you want worry free... LEDs, if you want something marginally brighter and arguably a little better looking, go retro but for the love of all things Holy, build them yourself ...
  3. Jul 7, 2018 at 4:18 PM
    TheBeast
    TheBeast The Beach
    retros are hit or miss depending on the shop you go with. Best is DIY for retros. They will also cost more. I say OEM LEDs are pretty hard to beat now.
    Erichudgins and MotoTundra like this.
  4. Jul 7, 2018 at 5:28 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I would go OEM LED and enjoy their reliability. As far as looks is concerned, that is strictly subjective and I like them.
    MotoTundra and Pudge like this.
  5. Jul 7, 2018 at 5:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    A good projector as far as I've seen will outperform the 18 LEDs as far as light output goes. And you can really customize them to whatever you wanna do. I think some look really nice. But reliability is the big issue, especially when it comes to certain retrofitters.
    Y0TA PR0 and MotoTundra like this.
  6. Jul 7, 2018 at 6:23 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I will echo what has already been said.
    I haven't owned both, but I retrofitted my headlights myself, and I have seen the output for the 18's.
    I kept my retro pretty basic. Projector and LED demon eyes, if a demon eye goes out, they both get unplugged, problem solved. I have some spare parts in case something goes but I haven't had any issues since I did them.
    My truck is Black and I fell in love with black bowls and black shrouds on a black truck. I had to do it.
    In my humble opinion.....
    Retro
    Pro- Best performance, ability to customize
    Con- Not as reliable, need the patience/skill to DIY or a very reputable retro shop to get it done right.
    2018 LED
    Pro- Very reliable
    Con- Not as much performance, look like every other factory LED headlight.
    I don't think you can go wrong with the 2018 LEDs.
    Pudge likes this.
  7. Jul 7, 2018 at 6:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  8. Jul 7, 2018 at 6:31 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    If you avoid doing anything fancy in the housings (namely LED accent lighting), a good HID setup will significantly outperform the 2018 LED and be just fine on reliability
  9. Jul 7, 2018 at 6:39 PM
    Shaggypeach
    Shaggypeach New Member
    Retrofits brightest less reliable and if you are not going to do it yourself most likely cost higher.
    Leds not as brighter as retrofits but still kicks halogens butt and the most reliable option.
  10. Jul 7, 2018 at 6:53 PM
    Pudge
    CT
    Was driving home from Rhode island last night on some pitch black roads. I was shocked how bright my 18 LEDs were. They really shine (no pun intended) in very dark conditions. I actually had to turn the high beans off a few times because the street signs lit up so bright it was bothering my eyes.
    RLHULK, mtTundra, Y0TA PR0 and 5 others like this.
  11. Jul 7, 2018 at 7:11 PM
    atxtundra
    atxtundra New Member
    I have retros with Morimoto LED projectors. I really like them, but I bought mine second hand. The angel eye quit working so I unplugged the other. I’m fine either way on that. I really like the output but if I did it over again... I’d just get the 2018 LEDs and call it a day.
  12. Jul 7, 2018 at 7:31 PM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
    I love my new 18's LEDs. I drove home from the dealership after sundown and man they are impressive. If the others are bright then kudos.
  13. Jul 7, 2018 at 7:34 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Retros are the brightest in my option. And you still can use OEM parts for them. Like the RX350 set I have uses OEM Ballasts and igniters. A lot of cars have stock HID and never have problem. Use OEm parts and you will get the same reliability with the best performance.
    MotoTundra likes this.
  14. Jul 7, 2018 at 9:49 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    My retros on my truck. I love the diode dynamic switchbacks and drls. They’re definitely bright!03956680-E61B-4286-97CE-2F7E939337D7.jpg
    I just installed the 2018 leds today. I really like the drls on them! I still want to retro the 18s though.
    Ostrich, JoshuaA, Pudge and 2 others like this.
  15. Jul 8, 2018 at 1:24 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    I agree. I couldn’t believe how bright the 2018 LED’s are (headlights and brights). Even the DRL’s are bright enough to see going down my driveway at night (pitch black).
    I was very impressed.
    TundraLuv and Pudge[QUOTED] like this.
  16. Jul 8, 2018 at 7:49 AM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    You have (3) choices right now as I just went through this same decision earlier this year:
    (1) retro HID projectors - brightest of the solutions for the most part, but the most components and uses an HID bulb. Widest beam pattern as well.
    (2) retro LED projectors - almost as bright as the HIDs, but more reliable as you are using LED diodes instead of bulbs. Not as wide of a beam pattern as the HIDs, but still close.
    (3) OEM 2018 LED reflectors - the least brightness of the others and uses a reflector housing, but the most reliable
    I'm currently running retros, but LED projector retros and not the HID projectors. The HID retro projectors have more components which is why they are more hit-n-miss on reliability. The HID retros are brighter, however, than both the LED projectors and 2018 LED reflectors. The LED retros are a little less complicated and the LED diodes will (supposed to) last for well over 10 years (maybe even closer to 15) depending on how often you use them. Keep in mind that the 2018 LEDs from Toyota are reflectors and not projectors, so if a nice 'cut-off' line is important you will want to go with a retro projector setup. If you don't care and just want reliability with a little less light output than either retro option, then get the OEM 2018 LEDs.
    Since my truck is black, I wanted the internal housing to be black and match my exterior paint to an extent. I wanted the reliability of LEDs, but a nice, bright cutoff as well so I went retro LED projector.
    With just the LED DRL strips running:
    Retro LED projectors on low-beam and NO fog lights - very bright with a great cut-off (where the light ends and the darkness begins):
    Ostrich, GAknight and MotoTundra like this.
  17. Jul 8, 2018 at 7:54 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    @1UPPER Are those LEDs I see mounted just inboard of your wheels!?
    @Boosted4runner Stop it. Stop it right now. You're making this decision to spend my money way too easy. I was already going to get the 2018 fogs and refrain from the 2018 heads, but you JUST HAVE TO say they're sooooo good :lalala:.
    Boosted4runner likes this.
  18. Jul 8, 2018 at 8:08 AM
    Boosted4runner
    WA
    Yep! They’re awesome!!
  19. Jul 8, 2018 at 8:48 AM
    1UPPER
    TEXAS
    Flux capacitor!
    @Yzed608 Yes sir. Rgb led rings around my rotors and over 200 light pattern options. I love the look of them! They even have an option to tie a led wire into your brake lead and they will turn red when you brake. 53949AC3-3CEA-4DD0-A9F8-ADBBD67A40CA.jpg
  20. Jul 11, 2018 at 10:34 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I have a gen 2.
    What are my options to upgrade my headlights to LED if merely swapping out the bulbs isn't a good idea.
    I assuming the 2018 LED won't fit gen 2 Tundra.
    Thanks.
  21. Jul 11, 2018 at 10:38 AM
    Shaggypeach
    You can fit the 18 sequoia headlights into yours. I've seen a couple and they are amazing. Posts on this forum as well. I've also seen 2nd gen with spyders and they look great too. You can probably do hid retro on those. Thats what I've done with my 3rd gen.
    myt1[QUOTED] and Pudge like this.
  22. Jul 11, 2018 at 10:41 AM
    Pudge
    CT
    This ^^^
    The 2018 sequoia lights are so nice. I like them better than the tundra ones. They will fit into a 2nd gen (with the addition of a trim piece I think)
    TundraLuv, myt1 and Y0TA PR0 like this.
  23. Jul 12, 2018 at 9:02 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    CDA93EFE-1EE9-4FEC-BB2F-D88A433F7E8E.jpg 0ECAB17E-B942-41A2-82CB-488113D428AD.jpg
    Totally agree :thumbsup:
  24. Jul 12, 2018 at 9:03 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  25. Jul 12, 2018 at 9:14 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I've had both Retro's and now the '18 LEDs. I had so many problems with my retros, the light output is great, but NOT worth the problems. I will say, the '18s on low beam are far superior to the retros. I honestly hated the harsh cutoff of them and maybe because I had a bad set, seemed really low. So for low beam, the '18s win.
    As far as high beam, I'd say the retros where a tad brighter, but that it's only by a very slim margin.
    So my 2cents, unless you want to spend A LOT and have them really done well, dont do retros, and for the love of God, don't get them from Leo. If you are coming from stock, you will absolutely love the '18s, and get the harness from @iHacker
    Afkouki, sk8142, B737 and 2 others like this.
  26. Jul 12, 2018 at 9:15 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  27. Jul 12, 2018 at 9:19 PM
    Nice!
  28. Jul 12, 2018 at 9:22 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  29. Jul 12, 2018 at 9:30 PM
    moonshineheadache
    moonshineheadache New Member
    Longmont , CO
    2018 Cavalry Blue CrewMax SR5 OffRoad
    Flux capacitor, Pimp-hand lotion dispenser, air mattress and Unicorn piss flex-fuel converter (it blows rainbows out the back)
    I think you might have missed a spot to install a light.
    _SP_ likes this.
  30. Jul 12, 2018 at 9:53 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Leavin' the color aside...
    That's one sick ride! Those lights set it off...best 2nd Gen I've seen. Very nice brotha!
    vq35721[QUOTED] and TheBeast like this.
