Getting another .5" to 1" with Bilstein 5100s?
Discussion in 'Suspension' started by Rica25, Jul 7, 2018.
  1. Jul 7, 2018 at 8:56 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    I have 5100s at highest setting. Is there any way I can get .5 to 1 inch lift on these shocks without harming anything?
  2. Jul 7, 2018 at 8:59 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Some have added cb shims to get another 1/2”. You could also look at the eibach coil overs from Toytec - these will get you to 3”.
    zcarpenter92 likes this.
  3. Jul 7, 2018 at 9:13 AM
    Rica25
    Ricardo
    Tulare
    Is the shims safe I have heard you can't add anything to the adjustable shocks
  4. Jul 7, 2018 at 9:16 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I have my 5100’s set at the middle with a cb shim on each side and have not had any issues. I believe that it is the shocks that are adjustable with a wrench that you can’t add the shims to. 5100 & 6112’s have the clips and are not adjustable unless you disassemble everything.
  5. Jul 7, 2018 at 11:46 AM
    Swap out coils to adjustable ones.
    Rica25[OP] likes this.
  6. Jul 7, 2018 at 12:13 PM
    Rica25
    Ricardo
    Tulare
    Toytec coils?
  7. Jul 7, 2018 at 12:21 PM
    You can, yes
  8. Jul 7, 2018 at 12:23 PM
    Rica25
    Ricardo
    Tulare
    But I can't just replace the coil springs my front shocks are not even 6 months old or do I have to replace the full set up?
