CPO Tundra - Scrathes/Surface rRust on Bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by BWongWong, Jul 7, 2018.
  1. Jul 7, 2018 at 6:01 AM
    BWongWong
    BWongWong [OP] New Member
    Brandon
    2016 Black Tundra Crewmax 5.7L
    I just got my Tundra 4 days ago and I forgot to check under the bed liner (1st time truck owner). I now know why the truck sold for under retail.
    It had a duraliner drop in bed liner when it was at the dealer. And I missed the opportunity to look under it before I bought it.
    Im too scared to get the linex spray on because that could void the unlimited mile corrosion warranty. (I heard they sand down the bed and then spray on the liner - which would get rid of the scratches and surface rust)
    Do you guys have any recommendations on fixing these scratches/surface rust spots? If anything, how bad is this?
    I also havent sprayed the bed down/fully taken off the liner yet to see what the extent of the issue is. But this is what I have so far:
  2. Jul 7, 2018 at 6:06 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Don't worry about it, go get the spray in liner
    rodm1, BWongWong[OP] and Jengel451 like this.
  3. Jul 7, 2018 at 6:16 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    that's just surface rust , have it sanded and get a spray in liner .
    TTund16, rodm1, BWongWong[OP] and 2 others like this.
  4. Jul 7, 2018 at 7:25 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    What they said
  5. Jul 7, 2018 at 7:30 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’d Bwong saying they Bwong. Will add: Neutralize the rust first with a readily obtained Rustoleum product, then spray line over. Get’er dun Chief.
    BWongWong[OP] likes this.
  6. Jul 7, 2018 at 7:36 AM
    Blueknights75
    Ron
    Clayton, NC
    Easy fix, just take it to get a spray in bed liner. Now let’s see that truck!
  7. Jul 7, 2018 at 9:55 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    A lot of those look like they came before the bedliner. Best fix is toss the drop in liner and get a spray in. You'll be happy.
    You have an unlimited mile corrosion warranty? If that's the case bring it to the dealer sans bedliner and have them fix it?
  8. Jul 7, 2018 at 1:41 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I think the corrosion warranty only covers perforation.
