Anyone with 295 70 18 Hybrid tires or MTs having VSC issues
Discussion in 'Wheels & Tires' started by Rica25, Jul 4, 2018.
  1. Jul 4, 2018 at 9:14 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    When making turns doing about 25 mph or higher when getting on highway vsc kicking on?
  2. Jul 4, 2018 at 9:32 AM
    Look for rubbing marks on spindle...
  3. Jul 4, 2018 at 1:09 PM
    Rica25
    Ricardo
    Tulare
    I don't see any rubbing
  4. Jul 4, 2018 at 1:12 PM
    Rica25
    Ricardo
    Tulare
  5. Jul 4, 2018 at 1:31 PM
    Looks like you have plenty of clearance....JoeShaker had the exact same issue you are having. Tires would rub taking tight turns causing stability control issues and could feel ABS going skitzoid. T-Rex266 was with me during a long test run.
  6. Jul 4, 2018 at 1:33 PM
    Rica25
    Ricardo
    Tulare
    I have only noticed at 30 mph and making a right turn with minimal slope
  7. Jul 4, 2018 at 1:34 PM
    Exactly like JoeShaker's problem. Exactly....
  8. Jul 4, 2018 at 1:51 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I have the same problem, but I'm on 37's. So far my only solution is to drive slower.
  9. Jul 4, 2018 at 2:00 PM
    Maybe time for a Zero Point re-calibration?
    Watt maker and GiantsFanDan like this.
  10. Jul 4, 2018 at 2:12 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I see the issue....Looks like you re missing your front drive axles ;)
    Wish i could be more help here. Just had to throw that in as a New England guy.
  11. Jul 4, 2018 at 2:15 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Haven’t had it be an issue with my Ridge Grapplers, had traction control kick on a few times when taking turns too quick on stockers but never VSC.
    GiantsFanDan likes this.
  12. Jul 4, 2018 at 2:53 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Think it's time for this to be done
  13. Jul 4, 2018 at 4:39 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Mine came on the other day, I was going a little to fast entering a off-ramp. As @Cuzican said probably need to take them corners a little slower :cool:
    TheBeast likes this.
  14. Jul 4, 2018 at 5:51 PM
    Rica25
    Ricardo
    Tulare
    I've done the zero point calibration and also the vsc module lift and none worked
  15. Jul 4, 2018 at 6:24 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Its probably the Ridge Grapplers, should've went with the St Maxx :thumbsup:
  16. Jul 4, 2018 at 6:47 PM
    Rica25
    Ricardo
    Tulare
    Lol.....Toyo at2s did the same
  17. Jul 4, 2018 at 7:23 PM
    GiantsFanDan
    Do you mean adding shims?
  18. Jul 4, 2018 at 8:10 PM
    Rica25
    Ricardo
    Tulare
    Adding shims on the vsc module to trick system with the rake
  19. Jul 4, 2018 at 8:52 PM
    CaptainJohnnySR5
    CaptainJohnnySR5 Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
    I added the 33x12:50 trail Grapplers and 3" lift level and I cannot punch it from a dead stop because the traction control kicks on and strips away my power. I turn off all the nannies and I can fry those monster tires like nothing and nothing kicks on. Going to Toyota tomorrow. I need to adress this asap. Zero point Calibration was already done last week and did not change anything.
  20. Jul 4, 2018 at 9:21 PM
    Rica25
    Ricardo
    Tulare
    From a dead stop these Toyotas will not let you burn out the Traction control computer is pretty hard to override
  21. Jul 4, 2018 at 10:40 PM
    geno0506
    geno0506 New Member
    Michael
    I have the exact tires on my 2017 and have never had that issue!
  22. Jul 4, 2018 at 10:43 PM
    Cuzican
    Cuzican New Member
    Louisiana
    It typically happens to me when exiting the interstate on exit ramps that loop back around. Everything is fine unless I touch the brakes while traveling more than 25 mph, if I'm going slower than that no problems.
    rons23 likes this.
  23. Jul 5, 2018 at 8:40 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    I have not had any issues after 13,000+ miles...
  24. Jul 5, 2018 at 9:42 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    Humor me, put 100 pounds in the bed over the back passenger’s side tire and repeat. Get back to us with your findings.
    Black Wolf likes this.
  25. Jul 5, 2018 at 12:01 PM
    I like where you are going with this!
    Cement Pro[QUOTED] likes this.
  26. Oct 5, 2018 at 10:36 AM
    mizzle415
    mizzle415 New Member
    Mitch
    08 CM
    I’ve got a 2008 CM with a revtec 3/1 lift on 295/60/20 toyo AT extremes.
    Same issue with traction control going off on very mild turns.
    I’ve done the ZPC only, no change.
    I’ve got airbags that do seem to make it less sensitive when air pressures are 20 psi +, resulting poor ride.
    All ears for a real solution.
    Rica25[OP] likes this.
