Have you seen my brake fluid?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Juanjoolio007, Dec 21, 2017.
  1. Dec 21, 2017 at 4:08 PM
    Juanjoolio007
    Juanjoolio007 [OP] New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Ok so this morning I got up and was heading to the gym and when i released my parking brake the light stayed on. I tested it to see if it may have been stuck since it was 27 degrees out and it seemed to be released. So slightly caffeinated I headed out for some early morning cardio :bored:. While there I decided I needed to google my new found problem which lead me to another forum with a member almost in an identical situation...almost down to the degree. Anyway someone had recommended to check the fluid level so I kept that thread opened on my phone and while i was letting the truck warm up again I grabbed my flashlight and checked. Sure enough I am on the Min. mark. Ok so now fast forward to the Walmart parking lot. I bought some new fluid to fill it up and thought lets check the lines and make sure it isn't leaking and it wasn't. At work one of the many prior auto mechanics said thats a good sign your pads are going down so after I got off work I did a brief check...like yup there is material there and its not the backing of the pads digging into my rotors that is stopping me. Well now I am like Where the F did it go??? I don't check those fluids like at all really because this is a freaking Toyota Tundra not a 83 Chevy 3/4 ton.
    So how often should you have to add fluid? Besides the obvious when its on the Min mark.
    The last time my truck was in for service was for the 15,000 mile back in Jan. I did the oil change at 20,000(really 18500) because I was out of Toyota care. They noted the pads at 8mm back then. That was at just under 14k and its now just over 20k.
    So if its not leaking....and I still have brake pads....where did it go????
  2. Dec 21, 2017 at 4:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    probably from the cold.
    Juanjoolio007[OP] likes this.
  3. Dec 21, 2017 at 7:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe con one of the prior mechanics from your work to go out to your truck and check the brake fluid level. Maybe take the cap off the reservoir to do so. My 2011 has over 60k on it and I haven't run through a set of pads yet, but I have noticed that clean brake fluid on a the newer trucks, say a 2015, is tricky to get a good read on because it's so clean and nearly clear looking.
    BakNBlk2014 likes this.
  4. Dec 21, 2017 at 7:51 PM
    Juanjoolio007
    Oregon
    yeah i get that since it was right on the line(and parked on a hill). as the fluid warmed and i got on flat ground it would go out. I wish I would have looked more when I did the oil change in August. Oh well. Ill keep an eye on it more now and see what happens.
    joonbug[QUOTED] likes this.
  5. Dec 21, 2017 at 7:59 PM
    Juanjoolio007
    Oregon
    Checking it isn't the issue. It was a lot clearer then i thought but i just shinned the light from the other side and it was a lot easier to see where the line was...it being pitch black and 3am didn't help. I was more worried about if it was full and there are no leaks and its not the pads causing the calipers to have to travel further requiring more fluid...where the heck did it go? oh well since I haven't been paying attention to it. I have no idea when the level started to drop. So I guess now that I am the one doing the maintenance i will start detailing it like i do with my quads and street bikes.
  6. Dec 21, 2017 at 11:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Run the engine, and hold a HARD brake application for a minute or so. Then look over all lines, calipers, around the ABS modulator pump... for leaks. If OK, monitor it and see what happens.
  7. Dec 22, 2017 at 2:38 PM
    Juanjoolio007
    Oregon
    Ok. I will try this either tonight or tomorrow morning.
  8. Dec 22, 2017 at 4:13 PM
    I’m pretty sure you don’t have a leak, but I would highly recommend what @landphil suggested. After you run that to ground and find no leaks...
    What is happening is quite simple. For ease of math, let’s just say each of your brake pads are 1” thick. So you have a total of 8” of brake pads. The brake reservoir is at the full mark. So if you can imagine, the reservoir is marked per inch, 8 as the high, 1 as the low and brakes no longer work, a 4 is the alarm set point to fill fluids.
    Fast forward 20k miles and let’s say you have used .5” per pad. There’s plenty of service life in your pads, but you have used 50% of your pads, and something needs to take up that volume of the brake caliper pistons that are now being used 50% more stroke. Well, your brake fluid did that for you. So now you went from 8” on the reservoir down 50% to 4”. You now have lowered the fluid low enough to alarm on fluid level.
    Clear as mud?
    From the factory, your Tundra may not have been topped off on the fluids as well. I have seen several of my new vehicles like this. Brake reservoir level between the low and high....leaning more towards the low.
    kbark, 831Tun, Wvmoonshiner and 5 others like this.
  9. Dec 22, 2017 at 4:39 PM
    Juanjoolio007
    Oregon
    Yup clear as mud... i mean that makes perfect sense. I didn't know if the amount of fluid between the Max and Min was the exact amount of fluid it would have required to go from full pad thickness to time to replace the pads or not. I just so happen to be planning to go to the local Les Schwab to get an alignment and my tire balance checked(trying to buy another year before I need new ones and to allow me time to do gears this year) so I will have them measure the pad thickness. I will admit that this being the weekend before Christmas and it being cold as can be outside and raining that I don't feel like taking my 35's off the truck to measure the pads.
    The crazy thing is I have talked to about a dozen people that don't know each other and in different places....but all of them have said 20k miles...well you have 35's so maybe its getting close to time to replace them. I am thinking about switching to maybe Green EBC's next. I shouldn't need rotors with this change but next time maybe going slotted. I am planning on going 37's next.
  10. Dec 22, 2017 at 4:59 PM
    Serviceable life on your pads is 1mm. I wouldn’t go that low, probably 2-3mm max.
    35-37’s will chew up the brake pads, so it will require more maintenance.
  11. Dec 22, 2017 at 5:19 PM
    Juanjoolio007
    Oregon
    I would be guessing but i think i am in the 5-6mm area. But that was trying to feel through my rim. Maybe less. I only put about 7k on the truck in this last year. Commuting with the wife's Camry and my KTM ate up the majority of my 65 mile a day commute for work. If i do the same this year then I should have no problem getting that life out of the current pads and my tires....assuming I am close on my guess for pad thickness. But I will be checking all my fluids at least once a month from here on out.
  12. Dec 22, 2017 at 6:10 PM
    That is a great idea to check fluids and vehicle condition more frequently.
  13. Dec 23, 2017 at 3:08 AM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    That is becoming a Sunday afternoon thing. Since I have stopped watching the NFL , I spend most of that time either under the hood or detailing the truck. Vehicle get's a good once over at least once a month and usually every other weekend. Small, easy fix's become expensive problems if not caught soon enough.
  14. Dec 23, 2017 at 10:01 AM
    I’m getting more accustomed to checking under the hood every other fill up. A couple years ago now, a buddy lost his truck to fire due to mice or pack rats building a nest under his hood by the turbo exhaust.
    I also have placed fire extinguishers in all vehicles. A couple months ago I didn’t drive my car for three days and under the hood was already a nice nest on the Shock tower.
  15. Jul 4, 2018 at 1:18 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Does DOT 3 work in our trucks (2nd gen)?
    landphil likes this.
  16. Jul 4, 2018 at 1:24 PM
    Les7311
    Disregard. Cap says DOT 3.
