Problems shifting into 6th
Discussion in '2nd Gen Tundras (2007-2013)' started by I Fly Low, Jul 4, 2018.
  1. Jul 4, 2018 at 7:22 AM
    I Fly Low
    I Fly Low [OP] New Member
    2007 Tundra TRD
    '07 Tundra, 5.7L Automatic; Recently, when shifting from 5th to 6th under mild throttle i get a 1-2 second vibration which feels like running over a rumble strip. There is also a delay in shifting which corresponds to the vibration.
    This also happens when shifting from 6th to 5th.
    It doesn't happen when I'm manually shifting, only in auto. It also doesn't happen with moderate to hard throttle.
    Any suggestions? Thanks!
  2. Jul 4, 2018 at 7:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe u-joints or carrier bearing?
    BTBAKER likes this.
  3. Jul 4, 2018 at 7:30 AM
    I Fly Low
    2007 Tundra TRD
    I don't think so. It really feels like transmission, since it is related to the shift, and not at any specific speeds.
  4. Jul 4, 2018 at 7:33 AM
    Have your transmission solenoids checked.
    Could be that or a TC going south.
    I Fly Low[OP] and 15whtrd like this.
  5. Jul 4, 2018 at 7:34 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe a solenoid issue. Hopefully someone else can chime in. I would think a service may be in order as a good first step.
  6. Jul 4, 2018 at 7:46 AM
    I Fly Low
    2007 Tundra TRD
    I was thinking solenoid also, had a service a few months ago. Transmission fluid level was low (I accidentally drained some while changing the oil :( When I took it in for service, They said there was a hard shift code and said it "might" be a solenoid. They said the only fix was a transmission replacement. I told them to service it and see what happens. All the problems went away, including hard shifting in 1-2. This problem started 7 weeks after the service, so I'm not sure if the code they saw was related to this or the 1-2 problem. Pretty confusing, but I'm not about to buy a new transmission based on their "might be a solenoid" diagnosis.
    15whtrd[QUOTED] and ColoradoTJ like this.
  7. Jul 4, 2018 at 7:55 AM
    Was this at the dealership?
  8. Jul 4, 2018 at 8:00 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I would try a complete fluid exchange or at least a drain and fill. When was the last time you had any transmission related work done besides the top off?
  9. Jul 4, 2018 at 8:02 AM
    I Fly Low
    2007 Tundra TRD
    Yes, it was at a dealer. They told me they don't open transmissions, so the only fix is to replace it. Struck me as odd that solenoids were not accessible from the outside, but I'm not a transmission expert, and didn't have time to put it on my lift.
  10. Jul 4, 2018 at 8:09 AM
    Well of course they don’t. Why not charge you 4000.00 instead of 2-300.00 per solenoid? 0F4E1D97-A516-4125-99C1-B323599F4F09.jpg
    Drop pan, and they are in valve body.
    I have seen them as low as 100.00. Check out this guy on eBay
    jdmplanet
    BTBAKER, Watt maker and 15whtrd like this.
  11. Jul 4, 2018 at 8:12 AM
    I Fly Low
    2007 Tundra TRD
    Awesome, that diagram made my day, thanks.
    BTBAKER and ColoradoTJ[QUOTED] like this.
  12. Jul 4, 2018 at 8:14 AM
    Glad Tundras.com could help a brother out.
    BTBAKER likes this.
  13. Jul 4, 2018 at 8:26 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Keep us posted.
  14. Nov 28, 2024 at 9:11 PM
    Smitithus
    Smitithus New Member
    Jake
    Digging up old posts, but curious if solution was ever found. My 07 Tundra CM 235k doing similar, except it’s 5 and 6th. Not just when shifting, but if I give it a little bit of gas. Sounds like rumble strips. No code presently.
    Got a code 2 months ago along with trac light, 4lo light blinking…
    P0894(1 / 2) Stored
    Transmission Component
    Slipping
    Noticed a light slip then grab at a stop sign. Did a full drain and fill, cooler flush, filter replace with max life WS. Oil looked pretty old but not terrible. No sediment.
    Road great for about 100 miles then code then got code month ago for…
    P2757(2 / 2) Pending
    Torque Converter Clutch
    Pressure Control Solenoid
    Control Circuit Performance or
    Stuck off
    Reset the code. Then next week noticed the rumbling under light throttle 5th and 6th. Manual or auto shift doesn’t matter. Thinking solenoid and/or valve body.
    Also, any good threads on how to test solenoids and which exactly controls TC and 5th/6th speeds?
  15. Nov 29, 2024 at 11:19 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Replace those solenoids and they will probably never come back. There is a diagram of solenoids somewherr, but I got those codes late last year, early this year. Swapped 4 solenoids in total since I had the P0894, P2714, P2757 and another one, can't remember which. I have 2 threads with the codes. It's been a good year so far. I did lose R, 1st, 5th and 6th.
    Mdl likes this.
  16. Nov 29, 2024 at 12:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I tested my solenoids before I swapped them into my new built valve body.
  17. Feb 8, 2025 at 3:29 PM
    JaydeemSR5
    JaydeemSR5 New Member
    Josh
    2010 Tundra DblCab SR5
    You guys are a Godsend for this post, the diagrams and bench test tips. Attempting this tonight!
  18. Feb 8, 2025 at 3:42 PM
    Smitithus
    Jake
    Post what you find. I’ve had it parked the last few months, just around town drive, couple small high trips a few exits down, still shuttering but still no new CEL’s, haven’t had time to dig in to it but planning on it next month. Thinking I’m either going to get the kit to rebore the bad valve and replace with larger valve and solenoid for TC, but might just say F it, bite the bullet and replace the whole valve body with a rebuilt one that has new solenoids and be done.
  19. Feb 8, 2025 at 4:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is it shuddering only when TC is locked?
