Steering rack bushing help!
Discussion in '2nd Gen Tundras (2007-2013)' started by TexasTundra27, Jul 4, 2018.
  1. Jul 4, 2018 at 6:00 AM
    TexasTundra27
    TexasTundra27 [OP] Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I’m having a hard time getting the upper driver side bushing out, it’s hitting the oil filter housing. People that have done this before, how did you get it out?? Need HELP!
  2. Jul 4, 2018 at 6:17 AM
    Oil filter housing has to come out.
  3. Jul 4, 2018 at 6:24 AM
    TexasTundra27
    Mark
    Don’t put that evil on me! This is probably a stupid question, but would I need to drain the oil to remove it?
  4. Jul 4, 2018 at 6:27 AM
    15whtrd
    15whtrd Mr. Blonde
    No. Just drain the filter housing, then remove. Actually you don’t even have to drain it, it will just be less of a mess if you do. And when you’re done just reinstall, or put a new filter in and cycle the engine. Then top off whatever amount of fluid it needs.
  5. Jul 4, 2018 at 6:28 AM
    TexasTundra27
    Mark
    Ok... thanks for the help fellas
    15whtrd likes this.
  6. Jul 4, 2018 at 6:29 AM
    Better than dropping the diff or removing the motor Ricky Bobby. :D
    mtntop, landphil, ldale and 3 others like this.
  7. Jul 4, 2018 at 6:31 AM
    TexasTundra27
    Mark
    The real shitty part is I have to do all of this just to drop it off at the dealer tomorrow for timing chain tensioners and Cam tower seals...
  8. Jul 4, 2018 at 6:32 AM
    Wow! How many miles on your truck?
    15whtrd likes this.
  9. Jul 4, 2018 at 6:32 AM
    15whtrd
    15whtrd Mr. Blonde
    On your dime or theirs?
  10. Jul 4, 2018 at 6:35 AM
    TexasTundra27
    Mark
    180k... not happy...
    mine... $3000 worth
  11. Jul 4, 2018 at 6:36 AM
    15whtrd
    15whtrd Mr. Blonde
    :eek: Im sorry man.
  12. Jul 4, 2018 at 6:38 AM
    Little surprised with the timing chain tensioners, but the tower leaks can happen a 5-200k miles.
    TexasTundra27[OP] likes this.
  13. Jul 4, 2018 at 6:42 AM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
  14. Jul 4, 2018 at 6:53 AM
    TexasTundra27
    Mark
    Black Wolf and 15whtrd like this.
  15. Jul 4, 2018 at 7:02 AM
    Pale_Horse
    FL
    Cupcake chit.
    Yea man I would say $3000 is worth raising hell about. Lol
    Awesome! I am trying to build my tundra for a Moab trip in the next couple years.
  16. Jul 4, 2018 at 7:22 AM
    Double...:eek::eek: Raise hell!!!
  17. Jul 4, 2018 at 7:28 AM
    TexasTundra27
    Mark
    Most of the $3000 is the parts and labor for the timing chain tensioners and guides, but since they’re that far I told them to fix the Cam tower leaks also.
  18. Jul 4, 2018 at 7:31 AM
    Makes sense to get it all done at the same time.
  19. Jul 4, 2018 at 7:37 AM
    TexasTundra27
    Mark
    Woooo! Just got the last one out without taking the oil filter housing completely out! Really didn’t want to take it all out. I removed the cap and filter and the bracket on the motor side that goes to the block and it gave me enough space!
    ColoradoTJ and 831Tun like this.
  20. Jul 4, 2018 at 7:45 AM
    TexasTundra27
    Mark
    Just a little bad... also I feel like a fiddler crab after swinging a 3lb hammer up that many times
    Coachbuilder1 and 15whtrd like this.
  21. Oct 1, 2018 at 11:37 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I'm about to finally do my bushings this week; was using a pickle fork really necessary to get the OEM bushings out? I don't have one on hand and don't feel like ordering one just for this.
  22. Oct 2, 2018 at 3:06 AM
    TexasTundra27
    Mark
    Yes, I tried with chisels and could only bend the lip down a bit. This is the kit I got off Amazon that bad the correct size, I think it was around $40. Also don’t be stupid like me and make sure you torque everything down correctly.... I was so tired and aggravated I just got it “tight” with my ratchet and called it good, and it was until I was on top of Imogene trail at 13k feet and one bolt got loose. Dumb way to ruin a brand new set of bushings so I had to replace them again :censored:
    831Tun and dcsleeper408 like this.
  23. Oct 2, 2018 at 3:14 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Any pics of the surgery?
  24. Oct 2, 2018 at 3:36 AM
    TexasTundra27
    Mark
    The 3rd pic is the little bracket I removed to get the upper driver side bushing out. Also make a real good mark of how the steering linkage was so you get it back on right, and pay attention to not turn the wheel or you could destroy your clock spring... :anonymous:
    dcsleeper408 likes this.
  25. Oct 2, 2018 at 3:40 AM
    Les7311
    Thanks and will try to find mine
    Was there any “triggers/symptoms ” why you had to replace them?
  26. Oct 2, 2018 at 3:58 AM
    TexasTundra27
    Mark
    Had some popping coming from the front end so jacked up the front and shook the tire side to side and whole rack was moving with it
  27. Oct 2, 2018 at 5:47 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Cam tower seals? I thought that problem didn't exist? (at least according to some people). :stirthepot:
    Sorry that crap happened.
  28. Oct 2, 2018 at 6:39 AM
    TexasTundra27
    Mark
    Sounds like some people should leave the thinking to us with proof :deadhorse:
    Haha, just glad to have it fixed finally!
  29. Oct 3, 2018 at 8:09 PM
    Spvrtan
    Kris
    San Diego, CA
    Did you have to get an alignment after swapping?
  30. Oct 3, 2018 at 8:12 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    If you dont touch the eccentrics or tie rods you dont need to.
    It doesnt hurt to sweep it on the rack and line it up again if needed. Your tires aint cheap.
    joonbug and TexasTundra27[OP] like this.
