Leveling kits
Discussion in 'New Member Introductions' started by Payyo710, Jun 30, 2018.
  1. Jun 30, 2018 at 6:53 AM
    Payyo710
    Payyo710 [OP] New Member
    Cesar
    White crew max tundra
    Exhausted intake
    Looking to level my truck this weekend and going with a icon stage one what’s the biggest tire I can go without rubbing going with 18s ? Or what’s the best option for leveling it ......
  2. Jun 30, 2018 at 7:43 AM
    Welcome from Texas, someone will chime in to assist you, let's see your ride
    Payyo710[OP] likes this.
  3. Jun 30, 2018 at 8:08 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Are you willing to remove pieces from your truck so it doesn't rub or adjust them if needed it so it doesn't rub or you just wanting to not have any rubbing issues as it sits with just the leveling kit
  4. Jun 30, 2018 at 8:17 AM
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    Watching this thread! Just bought my first Toyota 3 days ago! Looking to do the same thing.
    Black Wolf, jewsNbrews and 4x4_Angel like this.
  5. Jun 30, 2018 at 8:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
    Okietundra likes this.
  6. Jun 30, 2018 at 8:23 AM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Welcome from Colorado you two. :worthless:
    jewsNbrews and Okietundra like this.
  7. Jun 30, 2018 at 8:23 AM
    DPMSRECON308
    DPMSRECON308 New Member
    Terry
    2017 Tundra SR-5 Inferno
    2" lift, 295/65/18 Goodyear Duratracs, tinted windows
    So, I had installed the "RevTek" leveling kit, then added 295-65-18" Goodyear Duratrac's. I've experienced no rubbing anywhere. FYI. :)
  8. Jun 30, 2018 at 8:27 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    295-70-18 depending on wheel offset
    zcarpenter92 and 4x4_Angel like this.
  9. Jun 30, 2018 at 8:36 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    I have that size tour and rub... but did a few mods to not rub any more
  10. Jun 30, 2018 at 8:47 AM
    Okietundra
    OKC OK
  11. Jun 30, 2018 at 8:49 AM
    4x4_Angel likes this.
  12. Jun 30, 2018 at 8:49 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    ^^^^this.
    I have the ToyTec BOSS w/ shackles
  13. Jun 30, 2018 at 8:54 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    That's a great option but that's gonna get you a Cali lean. You need a 1in block in the rear to level that out along with u-bolts and hardware, which is a little more $$$. So typically if you're wanting to go that route just do something like a Pro Comp 3/1 Nitro and it'll come with level spacer, rear blocks, u-bolts and hardware. Around $250
  14. Jun 30, 2018 at 8:55 AM
    Okietundra
    OKC OK
    Ahhh... Great advice. Thanks!
    You know any details about the rough country level kits? http://www.roughcountry.com/toyota-suspension-lift-kit-872c.html?rrec=true
    Looks about the same to me.
  15. Jun 30, 2018 at 8:56 AM
    DPMSRECON308
    Terry
  16. Jun 30, 2018 at 9:45 AM
    Welcome from CO.
  17. Jun 30, 2018 at 12:53 PM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Now that is good!
  18. Jul 1, 2018 at 7:30 AM
    Okietundra
    OKC OK
    Have any of you experienced issues with your ball joints failing earlier than usual after installing a leveling kit?
  19. Jul 2, 2018 at 3:21 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Negative on them. If your gonna do a spacer lift, then at least get Billet Aluminum spacers vs mild steel. Toytec will get you straight. Welcome from Obx
  20. Jul 2, 2018 at 7:25 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO!
    4x4_Angel and Okietundra like this.
  21. Jul 3, 2018 at 2:37 AM
    Welcome from Ohio!
  22. Jul 3, 2018 at 3:11 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    What kind of rims are you running? Offset?
  23. Jul 3, 2018 at 4:24 AM
    You read my mind!!! Stop it!!
  24. Jul 3, 2018 at 4:28 AM
    Yep^^^spacer lift....sigh......go billited. Call David at ToyTec. You can also ask him about better options than spacer "lifts"!
