Bought my first handgun! Glock 19. Needs & Mods?
Discussion in 'Guns & Hunting' started by TTU19, Jul 2, 2018.
  1. Jul 2, 2018 at 3:45 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Forget the mods op it’s the shooter.
    gosolo, 15whtrd and Berettafan like this.
  2. Jul 2, 2018 at 4:05 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    gosolo likes this.
  3. Jul 2, 2018 at 4:32 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Your holster :p
    gosolo and 4x4_Angel like this.
  4. Jul 2, 2018 at 4:57 PM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    A good quality holster is a must.
    Practice holstering/ unholstering with it UNLOADED until you are proficient in the motions.
    I'm a leather kinda guy, but Kydex material holsters are very sturdy and hold their shape which is important when reholstering your firearm.
    Also decide if you want to go OWB(more comfortable) or IWB(more stealthy).
    And always remember :
    "Keep your boogerhook off the bangswitch until you are absolutely ready to fire"
  5. Jul 2, 2018 at 5:24 PM
    Berettafan
    Berettafan New Member
    2017 CM
    handguns are like golf clubs. IME 95% of people that own them can't use them worth a crap but you'd never know based on the way they talk about them and obsess over them. skip the junk and become one of the 5% who can actually use one.
    for inspiration:
    https://www.youtube.com/embed/YtVmEOxLE1Q
  6. Jul 2, 2018 at 5:25 PM
    Berettafan
    2017 CM
    War_Wagon312 likes this.
  7. Jul 2, 2018 at 5:47 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Timer is no joke. You can really see where your at. I do the wizard drill every range session. Once cold once at the end.
  8. Jul 2, 2018 at 5:59 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Just shoot it. My gen 4 G17 has only stovepiped twice from letting someone else shoot it with limp wrist. Other than that it runs flawless with 1k plus rounds of blazer brass. Keep Hornady critical defense mag in at home.
  9. Jul 2, 2018 at 6:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Stovepipe? Sorry trying to follow. Is this a feeding jam and the slide gets stuck? Or a spent casing jam?
  10. Jul 2, 2018 at 6:39 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Train train train.....don't mod it up,and then have only fired 50 rounds through it!
    MatthewPTguy likes this.
  11. Jul 2, 2018 at 6:49 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I haven't done any mods to mine (23) but i want the night sites for sure
  12. Jul 2, 2018 at 6:56 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Both
  13. Jul 2, 2018 at 7:22 PM
    15whtrd
    15whtrd Mr. Blonde
    Thank you. Makes sense
  14. Jul 2, 2018 at 7:24 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Only happens with weak wrist from my experience.
    4x4_Angel and 15whtrd[QUOTED] like this.
  15. Jul 2, 2018 at 7:33 PM
    Like kitchen knives, ice picks, axes, hair dryers plugged in next to bath tub????
  16. Jul 2, 2018 at 7:34 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    As others have said, train. Shoot the hell outa that thing! Spend your money on ammo, Winchester white box is great target ammo. I would avoid aluminum casing ammo. My personal preference for defensive ammo is Federal HST 147 grain. I do think night sights are a good first mod. If you're going to train and get used to the gun, you might as well do it with the sights you want. Changing sights can potentially change your POI which is a good reason to swap them out sooner than later. I have Truglow TFO's. I put them on right away and am very happy with them.
  17. Jul 2, 2018 at 7:39 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    One othe
    I have thousands, yes thousands, of rounds through a Glock 22 and 27'and haven't had an issue. Practice and use good ammo.
    Tripleconpanna likes this.
  18. Jul 2, 2018 at 7:50 PM
    Tacogrande
    Jeremy
    Or underpowered ammo...my wifes 42 had FTE and / or FTC almost every time using Winchester training ammo. Every other kind of ammo has been perfect thru it. I dont buy winchester anymore.
  19. Jul 2, 2018 at 7:55 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    I agree. Forgot to mention that. I’ve run lower grade ammo in other guns with varying results. Winchester sucks even through a single shot .22
  20. Jul 2, 2018 at 7:58 PM
    #50
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So what Ammo do you use?
  21. Jul 2, 2018 at 8:01 PM
    #51
    MotoTundra
    MotoTundra The Ocho
    Don
    Yes!
    Consider spending some money and take a legit tactical class.
  22. Jul 2, 2018 at 8:34 PM
    #52
    duece292
    Greg
    Green Bay, WI
    I've personally never had any problems with Winchester ammo. Between 9mm and .40 after a couple thousand rounds I've never had an FTF or FTE with white box, Nato, PDX1's or Rangers. Never a problem with Winchester. 22 ammo either. I would avoid any ammo marketed as training, low recoil or low noise as it just doesn't have the energy to cycle the gun properly. I have had problems with Blazer and Aguila.
  23. Jul 2, 2018 at 9:13 PM
    #53
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I avoid aluminum casings. I have shot tons of the Winchester white box, federal, Remington ammo
  24. Jul 3, 2018 at 1:17 AM
    #54
    Berettafan
    2017 CM
    WWB is easiest to find. The last thousand rounds I ordered was about $200 for 124gr federal. Have had no problems with it.
    TTU19[OP] likes this.
  25. Jul 3, 2018 at 4:52 AM
    #55
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    I love my G19! First mod I did was slapping a Talon Grip on there, it helped a whole lot and I love the feeling of it. Still haven't gotten around to get any sights yet myself. I use to plink with winchester white box also, but lately I've been plinking with LAX ammo reloads, no hiccups so far.
    OP look for grips, something like talon grips would be the first cheap mod you might want to get before all the cool internal and appearance accessories.
  26. Jul 3, 2018 at 6:25 AM
    #56
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks.. little things like this is what I'm looking for. I'll check it out.
    5.7TRDProm[QUOTED] and 4x4_Angel like this.
  27. Jul 3, 2018 at 7:08 AM
    #57
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Like others have said, get some good training, shoot as frequently as you can afford, dry fire (with ammo in a different room) daily... don’t forget a good belt. Most of the holster manufacturers make them. Good ones cost a few $$ but they don’t sag and last a long time. I’ve had good luck with Galco’s leather 1 1/2” leather belt and Cross Breed’s 1 1/2” leather belt. Happy shooting!
    HighDesertSurfer and TTU19[OP] like this.
  28. Jul 20, 2018 at 8:24 AM
    #58
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Well just got these. Tried to put them on but the tool I have is too large to fit on the underside of the slide to turn the screw. Going to have to pick up one that has a thinner sidewall.
    4x4_Angel likes this.
  29. Jul 20, 2018 at 9:37 AM
    #59
    War_Wagon312
    Rich
    Stock horse
    Glock front sight tool?
  30. Jul 20, 2018 at 9:41 AM
    #60
    It’s a specific sized tool for removing and installing the sights on a glock. 4-7.00. Worth every penny instead of destroying a socket.
