WTF? I've Got Foam Flying Out of My A/C Vents!?!?
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Apr 13, 2016.
  1. Apr 13, 2016 at 7:57 AM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Seems like some sort of foam seal or gasket for the heating/AC system is disintegrating and ejecting out my vents. Has anyone else had this and how much does it cost to fix? Or did it make a noticeable difference in your cooling/heating? It's not full summer heat yet here in Texas but it soon will be.
  2. Apr 13, 2016 at 8:37 AM
    are you sure it's not dirt from windy roads or anything?
  3. Apr 13, 2016 at 9:40 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I saw this I initially thought, rabies.
    I would guess that it depends upon where the foam was supposed to be originally. That would dictate what needs to be taken apart and to what extent. Have you checked your cabin filter to see if it might be coming from that area?
  4. Apr 13, 2016 at 10:57 AM
    Nor7
    It's definitely foam, its consistent and it's in uniform strips. I've seen it before in other vehicles just didn't expect it to happen in a Tundra.
    True but I'm seeing if anyone else has had this repaired and how much. There's not many other systems under the hood with foam gaskets that are in line with the A/C vent system. I haven't checked the cabin filter but I will tonight. I doubt it's the cabin filter since it's pretty new but it would be great if that were the issue since that's an easily accessible area.
  5. Apr 13, 2016 at 11:11 AM
  6. Apr 13, 2016 at 12:03 PM
    Probably the foam sealant for closing up joints in the ducting system.
    This is a common problem on Toyota vehicles. What happens is the vehicle is not traded in every 1-3 years like other manufactures due to longevity and owners start seeing things they never seen before like:
    -weight gain due to not walking to work.
    -buy tires
    You know, stuff like that. Lol
    Seriously, it isn't a problem unless you want to take your dash apart. Not worth it in my opinion. The foam sealant will blow out shortly.
  7. Apr 13, 2016 at 1:01 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    Hopefully you don't have critters in there!
  8. Apr 13, 2016 at 6:31 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Yea, my first thought was a critter chewing up something. Are you having to dodge any little flying turds?
  9. Apr 13, 2016 at 6:34 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    mine has done this. the vent right beside the drivers door has a thin strip of foam flapping around. i've reached in one with a pair of needle nose pliers and just pull it out. idk if i should have or not but i havent noticed any issues.
    i wish i had a picture, it doesnt look like sealant the way it sits it almost looks like a rudder to direct the air. could just be stuck that way but like i said i pulled mine out with pliers and threw it away.
  10. Apr 13, 2016 at 6:40 PM
    My 07 is, well, 9 yrs old. No issues like that............yet. My 2 yr extended warranty is up tomorrow. Quite frankly I wasted money paying for it.
  11. Apr 13, 2016 at 7:30 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I'd check your cabin air filter. You may have small little rodent friends making a home....
  12. Apr 13, 2016 at 8:09 PM
    Nor7
    I checked the cabin filter just now. Looks good, no evidence of critters and the material of the cabin filter doesn't look like the foam strips coming out of the vents.
    FYI: In the light the filter looks filthy but it's a metallic mesh that doesn't reflect light well. It's not as dirty as it looks.
  13. Apr 14, 2016 at 1:12 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    There is foam on the ducts and it he a/c box on blend doors. It may be deteriorating on the blend doors... not worth the repair iMO until something doesn't work
  14. Apr 14, 2016 at 6:55 PM
    Nor7
    Yeah, I haven't noticed any loss of cooling capacity, still blows cold air and lots of it.
    LOTSOFTOYS[QUOTED] likes this.
