Distance to Empty
Discussion in '2.5 Gen Tundras (2014-2021)' started by deerfarmer, Jun 28, 2018.
  1. Jun 28, 2018 at 7:43 AM
    deerfarmer
    deerfarmer [OP] New Member
    I got a 16 TRD a couple of weeks ago and its supposed to have a 38 gallon tank. I live 30 miles from the Indian reservation in Salamanca NY. the gas is >.40 to>.45 cents a gallon cheaper there [no tax on the reservation]. Twice I drove up there to fill up with zero miles left on the DTE. When I fill up it only takes 30-31 gallons, is there that much of a "grace" on the DTE?
    driverdog and Zombiehorde like this.
  2. Jun 28, 2018 at 7:45 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Yes. The "extra" is in there to keep the in-tank fuel pump submerged and keep it cool. At least that is what I have read....
  3. Jun 28, 2018 at 7:46 AM
    Yes. I have the 26 gal tank and there is a 6 gal reserve from DTE. Gets you a bit further down the road and protects fuel pump from drying out which can damage it.
    driverdog likes this.
  4. Jun 28, 2018 at 7:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep, what they said ^^^^^^.
    driverdog and joonbug like this.
  5. Jun 28, 2018 at 9:21 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    What I don't understand is why the truck was designed to haul an extra 8 gallons around all the time. I mean seriously 50# extra. It should be advertised as a 30 gallon tank with 8 gallons of cooling fluid.
  6. Jun 28, 2018 at 9:34 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    when the low fuel light comes on, you have about 8 gallons left. depending on your mpg, you have about 125 miles left in the tank (regardless of what the display shows). I routinely drive an extra 25-50 miles after the low fuel light comes on and I usually add 32-35 gallons to the tank. the "distance to empty" display is just an estimation and it errs on the cautious side. if you calculate your mileage by hand, you will know exactly how far you can drive on your tank.
  7. Jun 28, 2018 at 9:44 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    HecticEnergy likes this.
  8. Jun 28, 2018 at 11:06 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Dale Gribble has read on the innernet that the government has been working with the automobile manufacturers to install a hidden compartment in the bottom of fuel tanks. This compartment contains tracking devices that provide the authorities information about everywhere you go and is then shared with aliens.
    Obviously this takes away from the amount of gas the tank can hold.
  9. Jun 28, 2018 at 11:38 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Don’t most our newer vehicles have EDR’s?
    Black Wolf likes this.
  10. Jun 28, 2018 at 11:58 AM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
  11. Jun 28, 2018 at 2:30 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    This topic has been beat to death. Doesn't anyone do any research on here before asking about something covered many, many times?
    Black Wolf, JeremyGSU and Netmonkey like this.
  12. Jun 29, 2018 at 6:51 AM
    deerfarmer
    Guess I'm good for 2 weeks when the DTE shows 0 miles
  13. Jun 29, 2018 at 7:42 AM
    Over the LINE
    New Orleans
    I am amazed at how many times I do a site search and come up dry even when I know the topic has been discussed.
  14. Jun 30, 2018 at 5:32 AM
    deerfarmer
    Why don't you bypass it then?
  15. Jun 30, 2018 at 5:43 AM
    How tall should my tires be??? Heh..heh
  16. Jun 30, 2018 at 5:49 AM
    I rarely ever get lower than a 1/4 tank. I've had my yellow warning light come on twice in 4 years since I've owned my truck. I always hand calculate mpgs when traveling long distances where gas stations are a bit hard to find and even then I don't care about that light coming on. I know how much gas is left.
  17. Jul 1, 2018 at 6:51 AM
    deerfarmer
    this
  18. Jul 1, 2018 at 6:59 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You can frequently get better results with a google search even though the results will be from here on this forum.
    JoshuaA and Newm like this.
  19. Jul 1, 2018 at 7:51 AM
    deerfarmer
    I'll try that next time
    Over the LINE likes this.
  20. Jul 1, 2018 at 7:56 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    The site search sucks imo. I have better luck googling my question then at the end either putting in ‘tundra’ or ‘tundra forum’
  21. Jul 1, 2018 at 8:36 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    +1 I do that on other forums I belong to
  22. Jul 1, 2018 at 11:31 AM
    deerfarmer
    its amazing the help I've received in 4 weeks, from dipping, badge removal, distance to empty info and head unit:hattip:
    JoshuaA likes this.
