2003 Tundra 4.7
Discussion in 'General Tundra Discussion' started by Rudi Feller, Jun 26, 2018.
  1. Jun 26, 2018 at 8:01 AM
    Rudi Feller
    Rudi Feller [OP] New Member
    Rudi
    2003 Tundra 4.7
    I have a 2003 toyota Tundra with too much travel in brake pedal. I have adjusted back brakes and replaced pads. There are no leaks and does not act like master cyl problem. Is there any history of this problem?
    Black Wolf likes this.
  2. Jun 26, 2018 at 8:06 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Rudi.
  3. Jun 26, 2018 at 8:10 AM
    Not sure about your problem. But some 1sr gen'rs should chime in. Welcome from CO!
  4. Jun 26, 2018 at 8:12 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  5. Jun 26, 2018 at 9:01 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Welcome from Socal! Have you bleed the brake at 4 wheels and there is 1 at the master cylinder.
