2014 Flashers Not Working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Playzoutside, Jun 25, 2018.
  1. Jun 25, 2018 at 8:42 AM
    Playzoutside
    Playzoutside [OP] New Member
    2014 Tundra
    I went to install LEDs in the front flashers with resistors. Driver side tested out fine. Left side came on but then all flashers stopped. Putting the stock bulbs back in (without resistors) didn't help. The DRLs come on but all flasher function in gone. anyone else had this issue? Sounds like I might need a new flasher? Anyone have any suggestions?
    It pisses me off that with everything in the world going LED that Toyota makes it this hard to put LEDs on the vehicles. At least before you could replace the flasher relay and everything worked perfectly. Why mess up a good thing??
    iHacker and Black Wolf like this.
  2. Jun 25, 2018 at 8:57 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Check the fuse?
    landphil and sprtbkr like this.
  3. Jun 25, 2018 at 9:00 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    sounds like you blew a fuse to me, as well.
    joonbug likes this.
  4. Jun 25, 2018 at 9:31 AM
    Playzoutside
    2014 Tundra
    Unless there's another fuse for the flashers/signal other than the 25 amp one under the hood, then no.
  5. Jun 25, 2018 at 9:49 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Flasher’s definitely not working
  6. Jun 25, 2018 at 9:50 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Can't believe 3 posts in and no one has suggested blinker fluid could be low and needs to be refilled.
  7. Jun 25, 2018 at 9:53 AM
    Beat me to it
    TXMiamiFan[QUOTED] likes this.
  8. Jun 25, 2018 at 9:54 AM
    Playzoutside
    2014 Tundra
    I already topped it off on all four corners.
  9. Jun 25, 2018 at 9:54 AM
    TXMiamiFan
    Jose
    Did you get summer blend?
  10. Jun 25, 2018 at 9:56 AM
    Isn't there a fuse by kick panel as well????
  11. Jun 25, 2018 at 10:19 AM
    Playzoutside
    2014 Tundra
    Yes there is but none for flashers or signals
  12. Jun 25, 2018 at 11:01 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    First of all, check the turn signal socket, you can remove and inspect terminals for any rust or dirt in it, it happened to a friend and we cleaned out all the terminals and covered with dielectric grease and turn signals worked out perfectly.
    Flasher seems to be ok since your driver side is working.
    I have seen similar problems at work and same cause.
  13. Jun 25, 2018 at 11:20 AM
    Playzoutside
    2014 Tundra
    No, the driver side is not working. No flasher function at all on either side. No turn signals, no hazard flashers. Sockets are all good. The DRL part of the factory bulb comes on but flasher part does not. There's not even a flasher sound in the cab.
  14. Jun 25, 2018 at 12:08 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Ohhh ok, if all your fuses look ok problem is a flasher malfunction then :(
  15. Jun 25, 2018 at 12:11 PM
    Playzoutside
    2014 Tundra
    Thanks for your reply.
    Are there any other fuses besides the one under the hood that could affect it? the only one I saw was the 25 amp one under the hood labeled "signal/flasher".
  16. Jun 25, 2018 at 1:04 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    replace / open & inspect flasher relay under dash
    should be the same in 3rd gen. pic here
    http://www.tundratalk.net/forums/tu...ed-turn-signals.html#/topics/120417?_k=qjgisg
    also, sometimes just giving it some time might help, and test again with proper bulbs.
    there are so many threads, on multiple tundra sites, regarding DTRL and signal replacement with LEDs. It is not as simple as P&P due to the way toyota wired the DTRL. you need a switchback kit or at a minimum, depin DTRL in the cab to avoid back feeding the circuit.
    Playzoutside[OP] and iHacker like this.
  17. Jun 25, 2018 at 1:53 PM
    Playzoutside
    2014 Tundra
    Yeah I'm very familiar with this thread. I was hoping to avoid getting under there because it's not a place for big fellas....but I guess I gotta. But even if I had just used P & P then I would've had hyper flash. I didn't wanna use resistors but since Toyota made it hard I went that route. And it didn't work. This will definitely be the last Lexus/Toyota I'll buy if they can't pull their heads outta their rears. At least before you could just replace the relay.
  18. Jun 25, 2018 at 2:49 PM
    B737
    Jersey Shore
    Resistors alone won’t resolve it. You need to separate the circuits, like w the vled triton switchback things. I’m hoping when you go back to ur truck they’ll be working again. But I would start at the flasher relay if they aren’t.
  19. Jun 25, 2018 at 6:13 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Reverse the passenger side resistor yet?
  20. Jun 25, 2018 at 6:23 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  21. Jun 25, 2018 at 6:31 PM
    GiantsFanDan
    And also under the dash fuse box number 15 (LH-IG) mentions turn signal
    joonbug likes this.
  22. Jul 23, 2024 at 7:10 PM
    mr_lasseter
    mr_lasseter New Member
    This is what it was for me. Thanks!
