Aluminum Radiator Swap (Champion)
Discussion in '1st Gen Tundras (2000-2006)' started by TundaDownUnda, Jun 22, 2018.
  1. Jun 22, 2018 at 9:49 AM
    TundaDownUnda
    TundaDownUnda [OP] New Member
    I noticed my go to radiator supplier for Classic cars(Champion Radiators) is also jumping into many newer applications including the 1st Gen Tundra's. Replacing my customers OEM style radiators with All aluminum radiator is Must Truck Mod in my eyes. High performance Aluminum dissipates heat so much better than the original plastic with tanks that always crack. heres a link if anyone is interested drops in all first gen Tundra core supports. http://www.championradiators.com/Toyota-Tundra-Radiator-2000-2006
    Dragracingdan and gosolo like this.
  2. Jun 22, 2018 at 10:16 AM
    n2deep
    n2deep Pavement Princess
    I just replaced a radiator in my Gen2 and thought about going with an all aluminum but the stock radiator was designed by Toyota and had done a fine job of keeping the truck temps in the required range. Even when its 110 outside and towing the boat to the lake I never had and issue with cooling. I only replaced it because the aluminum fins were damaged and started to leak.
    For being your first post this seems like an advertisement/spam post to promote/sale your product.
    Pudge, 01erionracing and Jerry311SD like this.
  3. Jun 22, 2018 at 11:47 AM
    TundaDownUnda
    I Had seen quite a few guys complaining on Tacoma world about the 1st gen Taco having cooling issues and had a very positive response I figured some guys with similar year Tundras had similar issues.
    01erionracing likes this.
  4. Jun 22, 2018 at 12:12 PM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
  5. Jun 22, 2018 at 12:17 PM
    n2deep
    Yeah don't know about any Gen1 cooling issues but maybe this would help if they have issues.
  6. Jun 22, 2018 at 12:19 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Jimmy gen 1 has cooling problems and he replaced everything. New radiator water pump etc. He said he can't figure it out. Maybe he just needs to upgrade?
  7. Jun 22, 2018 at 1:20 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    It was coincidence, after the BB trip on Monday I called several radiator shops from Riverside to OC described my cooling temperature warm issue. One shop stated t-stat and the other was said the radiator blockage anyhow I found Champion Radiator in OC and ordered one. It show up yesterday hopefully will be replace later today after work.
    This is full aluminum 3 core radiator looks very well built. They also offer 60 days satisfaction guarantee.
    This is a little brief about the truck cooling issue:
    High speed uphill engine temp increased to 3/4 the temp will decrease if I slow down or just stop taking a break.
    Wheelin 4lo climbing uphill with AC on no problem.
    I have replaced timing belt, water pump, tensioner, t-stat (maintenance schedule), mechanical fan clutch, radiator (was leak) all Toyota parts and about 50k miles ago.
    I also have 3/16 steel front, rear bumper, rock slider, roof rack.
    osidepunker[QUOTED] likes this.
  8. Jun 22, 2018 at 2:04 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Let us know how this works out for you!
  9. Jun 23, 2018 at 8:57 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Yes keep us informed. I replaced the 02’ radiator about 4 years ago with another OEM (plastic combo) radiator. When researching for new was surprised at all the plastic combo radiators out there. No 100% aluminum until seeing this one. My replacement OEM is working fine btw.
    Jerry311SD[QUOTED] likes this.
  10. Jun 23, 2018 at 9:53 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I'd like a big fat aluminum rad with a giant electric fan.
  11. Jun 23, 2018 at 5:33 PM
    Casper421
    In the woods
    06 DC
    The champion website offers a single 16” or dual 12” electric fans.
  12. Jun 23, 2018 at 9:23 PM
    01erionracing
    Jimmy
    The new radiator was installed yesterday. One thing though there are 2 ears on the new radiator that hangs on the radiator support did not lined up, I have to cut it off. Other than that the installation was easy. I tested uphill last night the coolant temp did not creep up however it only happen when the ambient tempt upper 95° F, so I will tested again next week, the weather suppose to be in the high 90.
    Compared to the aftermarket OE
    Installed
  13. Jun 26, 2018 at 3:04 PM
    01erionracing
    Jimmy
    Update... I have ran 4 tests and the engine temp gauge stays solid center so I think the cooling issue temporary has been resolved after rad replaced.
    I have tested on a short grades, 6 miles and about 6% incline, I also pushed the engine above 3k rpm (75+ mph)
    Test 1
    Ambient temp: 75° F
    Loading: driver and my son
    Test 2
    Ambient temp: 95° F
    Loading: only driver
    Test 3
    Ambient temp: 95° F
    Loading: driver and 360 lbs quikrete
    Test 4
    Ambient temp: 98° F
    Jerry311SD likes this.
  14. Jun 28, 2018 at 4:30 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thats dope Jimmy ! Glad you got it resolved. I weigh 8k lbs and I've pushed my truck hard in deep sand at over 100 degrees for hours and it never overheats. I think the 1st gen just has an undersized radiator if you really push the truck
    01erionracing[QUOTED] likes this.
  15. Jun 28, 2018 at 7:09 AM
    01erionracing
    Jimmy
    Additionally I have some weight on the truck winch/front/rear/roof rack/rockslider and skid plate and its 3/16" steel.
  16. Jan 14, 2019 at 11:27 AM
    Do you recall if you went with Denso on the replacement? I'm told that's who makes the factory radiator. Did you do this yourself?
    https://www.densoproducts.com/product.aspx?zpid=9086
  17. Jan 14, 2019 at 12:02 PM
    Fred
    Hand Protectors
  18. Jan 14, 2019 at 1:40 PM
    moonshineheadache
    moonshineheadache New Member
    Longmont , CO
    2018 Cavalry Blue CrewMax SR5 OffRoad
    Flux capacitor, Pimp-hand lotion dispenser, air mattress and Unicorn piss flex-fuel converter (it blows rainbows out the back)
    Awwwwwwweeeee...that 4.7L is so cute!
    Darkness likes this.
  19. Jan 14, 2019 at 4:35 PM
    Fred
    Hand Protectors
    My shop did it for me about 4 years ago. Its an aluminum and plastic rad. Can’t find a name on it, but its an aftermarket from what I remember (not Denso). That link looks like a great price.
  20. Jan 22, 2019 at 2:25 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Does this Rad Hold more Coolant?
  21. Apr 11, 2019 at 3:35 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hey guys! I'm pretty new to working on tundras, and to the site. Still learning my way around. I have a question that might be dumb, but here goes.
    About a week ago I replaced the radiator in my '02 tundra V6. I watched 1A Autos "how-to for V8" video, and noticed something about my truck. It has a separate radiator for oil cooler, and video has oil cooler lines hooked up to bottom of radiator.
    Could I hook my lines up to the same hose barb on radiator or is there a difference between the V6/V8 models I don't know about?
    Any reason for separate oil cooler rad?
    I purchased denso OEM radiator.
    Thank you for any/all info!
    Noah.
  22. Apr 11, 2019 at 4:20 AM
    bmf4069 Captain wtf
    Awwww, that truck payment is so cute!
  23. Apr 11, 2019 at 4:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There is no payment, but thank you.
    Any helpful tips there, @bmf4069 ?
  24. Apr 11, 2019 at 4:41 AM
    bmf4069 Captain wtf
    I was talking to the 3rd gen guy flapping gums in here. I know my 02 has a separate trans cooler. When I pulled my rad to do the fan clutch I only had to drain the coolant. Not sure on v6/v8 differences, but somebody should chime in shortly.
  25. Apr 11, 2019 at 4:43 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okay, thank you.
    My apologies for being harsh then. I thought the payment remark was towards me. Lol
  26. Apr 11, 2019 at 4:44 AM
    bmf4069 Captain wtf
    All good. The internet is a harsh mistress when it comes to communication.
    GavinG83 and Tundra2[QUOTED] like this.
  27. Apr 11, 2019 at 4:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Miscommunication may be a better fit, and the it was on my end.
    Lol. I saw an alert, and I usually only get those when I am mentioned in a post.
    bmf4069[QUOTED] likes this.
  28. Apr 11, 2019 at 4:49 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @01erionracing you have any info on this? ^^
    Tundra2[QUOTED] likes this.
  29. Apr 11, 2019 at 4:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  30. Apr 13, 2019 at 4:01 PM
    Nwa263 tundradc
    Nwa263 tundradc New Member
    The lines you have highlighted are transmission lines. Not sure if its the same ont the v6 as the v8. Just replaced my radiator about a week ago.
