DIY oil change 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Jun 2, 2017.
  1. Jun 20, 2017 at 3:25 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Forgot to update this with my experience. I have to say that it was a pain in the ass. I did it in my garage, with truck on the ground, some ramps would have made it slightly better. Having to remove the skid plate is annoying, the cartridge filter is annoying. I will keep on eye out for coupons to have it done next time. It took me about an hour, I also greased my driveshaft zerks during that time. I'd be willing to spend 20-40 bucks more to bring it somewhere, especially since I really only drive about 5k mikes a year. That said, I'm pretty cheap, and capable so we'll see come next spring.
    USCG2005 likes this.
  2. Jun 20, 2017 at 11:28 PM
    TTund16
    TTund16 New Member
    the skid plate is always annoying with any car ...
    seems like another stupid thing. never had a car with cartridge.
    thanks for update.
    can you throw away the cartridge and install a real oil filter?????
  3. Jun 20, 2017 at 11:43 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    I haven't had to do mine yet, but I'm wondering if it would be worth cutting an access hole into the skid plate to prevent having to remove it next time. Would having an exposed hole in that area be bad?
    Another thought is welding the cutout back on with a piano hinge, and some kind of latch to keep it shut.
  4. Jun 21, 2017 at 5:58 AM
    Pudge
    CT
    I'm sure someone makes a remote bypass filter for these trucks. But I bet they are expensive. That's the only way I see it happening.
    TTund16[QUOTED] likes this.
  5. Jun 21, 2017 at 6:01 AM
    Pudge
    CT
    I think that the newer TRD pro's have a cut out in the skids but I'm not certain.
    I think having a cutout would be nice. Only problem is if you did that you'd probably want to change the filter housing from plastic to metal, but those are available on Amazon for a decent price I think.
    The hinge door idea would be perfect
  6. Jun 21, 2017 at 6:28 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Cut a hole then make a lid that bolts onto the skid plate
    Pudge[OP] likes this.
  7. Jun 23, 2018 at 3:30 PM
    Crews44
    Crews44 New Member
    Southern NJ
    2025 Platinum TRD MGM CM 3” TRD lift
    Thanks for the help on this guys. Had to grab the filter wrench and was referencing this thread.
    Going back to why you do your own oil changes......look at this pic. What’s wrong with this.....only has been serviced at dealer.
  8. Jun 23, 2018 at 3:38 PM
    2 O-rings
  9. Jun 23, 2018 at 3:41 PM
    Crews44
    Crews44 New Member
    Southern NJ
    Y
    Yes sir.
  10. Jun 23, 2018 at 3:46 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
  11. Jun 23, 2018 at 3:52 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    2 rings better than 1.:D
  12. Jun 23, 2018 at 4:44 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Yep, that is the way to go. The miserable little plastic thingy is worthless, had oil running down and off my elbow since I could not get it to latch in place.
    The tool shown is the beez neez.
  13. Jun 23, 2018 at 4:55 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    lol holy crap!
  14. Jun 23, 2018 at 4:58 PM
    GWalker
    GWalker New Member
    North Carolina
    2014 White Tundra Double Cab Limited
    One trick I have is when you drain the oil from the drain plug, use a 4" diameter piece of PVC about 5 inches long, stand it upright in your oil container (if you are using a flat container), absolutely no splashing as the PVC contains the stream of oil.
  15. Jun 23, 2018 at 6:33 PM
    408Tundra
    408Tundra New Member
    Will
    2017 Tundra TRD Limited Crewmax 4x4
    I have managed auto shops for over 20 years. This is true.
    USCG2005 and TTund16 like this.
  16. Jun 23, 2018 at 7:38 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Its not bad at all once you have done it one time and had the proper cartridge wrench and drain tool with hose. I really like the new cartridge style filter system...zero mess as compared to the old canister filters. Ramps, 5 gallon bucket, drill with sockets to remove skid, torque wrench and know the specs, oil on sale at costco, filters and crush washers are cheap as well as the replacement oem metal housing...cant beat it. I have never enjoyed changing oil this much on my older vehicles.
  17. Jun 24, 2018 at 10:23 AM
    B737
    Jersey Shore
    exactly dude. I'm not sure why ppl on here whine so much about changing the oil on these things. The skid plate even has hooks to hang itself, takes 1 minute to unfasten. To re-install hang it up from its hooks, slide it over and it's back on again. You can even change the oil by just letting it hang too, don't even have to fully remove. It's not rocket science, but the lube techs sure do their share of screwing it up.
    Free oil changes, (like everyone else) and never went back to the dealer to use them, not worth the risk or hassle.
    USCG2005 and TundraTeddy like this.
  18. Jun 24, 2018 at 11:04 AM
    Tacogrande
    Jeremy
    My guess is they are getting sand and debris in eyes...always wear goggles when working under vehicles.
    https://www.amazon.com/DEWALT-DPG82...qid=1529863397&sr=8-3&keywords=dewalt+goggles
  19. Jun 24, 2018 at 11:26 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I bought an aftermarket skid for easier access to the filter, but otherwise the process isn't bad at all. There's a twist on version of the plastic filter drain that works much better than the push on. The mobil 1 and pureone filters come with it.
  20. Jun 24, 2018 at 1:25 PM
    #50
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Or you could cut one in the stock pan.
    USCG2005 and SuperSilverTundra like this.
  21. Jul 2, 2018 at 7:39 AM
    #51
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    very few had any comments on the metal filter cartridge that is available to replace the stock plastic one. Do most replace the plastic one with metal, or stick with the stock one?
  22. Jul 2, 2018 at 7:43 AM
    #52
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I have seen a lot of people opt for the metal upgrade. I haven't had any issues with the stock unit, though. Just use a little finesse and don't get too excited when you are torquing it back on.
  23. Jul 2, 2018 at 7:52 AM
    #53
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Swapped to the metal housing on the Tundra, plan to swap to the metal housing on the wife's camry. As far as oil changes go, its a breeze. Dealerships have let me down far to often on something so simple, i'd rather just do it myself. The hardest part is driving the used oil to the auto parts store for drop off...
  24. Jul 2, 2018 at 8:49 AM
    #54
    Did you remember to swap the metal tube with holes from plastic housing to new metal one?
  25. Jul 2, 2018 at 9:15 AM
    #55
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I routinely do mine for around $50 using Mobil 1 and K&N oil filter
    Jsena[QUOTED] likes this.
  26. Jul 2, 2018 at 4:30 PM
    #56
    birdman076
    Chuck
    Montana
    Of course lol. That was real easy to do as long as you don't gorilla finger the tabs and break them off.
  27. Jul 2, 2018 at 4:32 PM
    #57
    :thumbsup::rofl::fistbump:
  28. Dec 6, 2018 at 6:50 PM
    #58
    Erick
    Erick New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    Where's the link for this bad boy?
  29. Dec 6, 2018 at 6:56 PM
    #59
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  30. Dec 6, 2018 at 6:57 PM
    #60
