Brights and Fogs on at the same time
Discussion in 'Lighting' started by toyobama, Jun 19, 2018.
  1. Jun 19, 2018 at 4:39 PM
    toyobama
    toyobama [OP] New Member
    Has anyone wired their bright lights and fogs to be on at the same time?
    2018 Limited Toyota Tundra - Super White
  2. Jun 19, 2018 at 4:40 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Yep, I will find you the link.
  3. Jun 19, 2018 at 4:57 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
  4. Jun 19, 2018 at 4:58 PM
    lionix
  5. Jun 19, 2018 at 5:14 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Please do more reasearch. Those links are know to work up to a 2017. 2018 trucks are a bit different.
  6. Jun 19, 2018 at 5:15 PM
    lionix
    Same truck??
  7. Jun 20, 2018 at 6:01 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I can't say for sure about the jumper wire under the dash mod, but the grounding of the relay mod should work exactly the same on the 18's.
  8. Jun 20, 2018 at 6:07 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Who in their right mind wants to blind oncoming traffic? I see no other reason for this and I'm gonna throw high beams back so we can both die squinting and angry anyway.
  9. Jun 20, 2018 at 6:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What?
    The point of this is so when you turn on your high beams your fogs dont turn off, you lose a lot of light right in front and to the sides when the fogs turn off.
    Obviously when a car is oncoming you'd turn off high beams?
    This is a great mod, it makes it so you fogs are on all the time. Improves visibility to other drivers and improves your lighting at night
    NewImprovedRon, T-Rex266 and 831Tun like this.
  10. Jun 20, 2018 at 8:08 PM
    lionix
    I only do it so when I am driving at night with no oncoming traffic I can use highbeam and BD Fogs to see deer and other obstacles.
  11. Jun 20, 2018 at 8:19 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    This is a GREAT mod and actually the only way that make sense. Why would you not want fogs and high beams at the same time? It would make more sense to me if the fogs went off with low beams as a courtesy to oncoming traffic.
    Pudge likes this.
  12. Jun 21, 2018 at 5:20 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Well, the only thing my fog lights in any of the 10 or so vehicles I have had with them "light up" in the slightest way are the ditch from my A pillar to half way down the fender. If you think foglight and brights go together, then you don't understand the concept of fog lights. Maybe you are confusing them with driving lights which are illegal to use on public highways in all 50 states. :crapstorm:
  13. Jun 21, 2018 at 5:22 PM
    Pudge
    CT
    Cool story
    NewImprovedRon likes this.
