Factory gas tank
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Airbagged, Oct 13, 2015.
  1. Oct 13, 2015 at 12:35 PM
    Airbagged
    Airbagged [OP] New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    I have my original gas tank for sale, came off my 2015. I upgraded to a 46 gallon transfer flow tank.
    $250
    Located in homestead, fl
  2. Oct 13, 2015 at 1:26 PM
    Airbagged
    Oops sorry about that I guess it didn't upload correctly the first time
    T-Rex266 likes this.
  3. Jan 7, 2016 at 7:54 AM
    dyvet2004
    dyvet2004 New Member
    Maryland
    2016 Limited Tundra 5.7 Double Cab Trd Off Road Package
    Nfab nerf bars, Bilstein 5100's Front and Rear
    where did you get your aftermarket tank? also did you do the install yourself? was it difficult?
  4. Mar 7, 2016 at 10:49 PM
    jmcolejr
    jmcolejr New Member
    James
    BRONZE 2015 TUNDRA 1794
    what your review for this item? thanks
  5. Mar 8, 2016 at 10:11 AM
    His personal review of the stock fuel tank? :notsure:
    Mike likes this.
  6. Mar 8, 2016 at 11:42 AM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    I needed a good laugh...
  7. Mar 8, 2016 at 1:35 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Would you consider shipping to 43146? Rodents chewed thu the evap plastic line that connects to the charcoal canister. Dealer said I need to replace the whole tank since the line is connected to the tank and pressed in.
    Also, should it fit a 2013 and is yours flex fuel?
    Thanks.
    ColoradoTJ likes this.
  8. Mar 8, 2016 at 5:19 PM
    MillsTRD14
    MillsTRD14 New Member
    Aaron
    2014 Tundra TRD
    Ba mufflers 7 inch, Bilstein 5100 TRD strut bar, Firestone adjustable ride rite airbags, tow mirrors , BFGoodrich ta ko2 33s, TRD shift knob, blacked out emblems, tundra Pro grill......
    :notsure:
  9. Mar 8, 2016 at 7:12 PM
    Airbagged
    I have the tank still and will be driving up to Alabama from south FL March 18th if anyone along the way needs it, I could bring it with me.
  10. Apr 6, 2016 at 4:05 PM
    jmcolejr
    jmcolejr New Member
    James
    What your review of the 46gal tank?
  11. Apr 6, 2016 at 4:29 PM
    Airbagged
    I'm very happy with it, and the extended range I get from it, especially since I'm
    Always towing something. I would highly recommend it to anyone!!!
