TPMS on 2014+ SR models?
Discussion in '2.5 Gen Tundras (2014-2021)' started by NewTundra, Jun 18, 2018.
  1. Jun 18, 2018 at 5:28 AM
    NewTundra
    NewTundra [OP] New Member
    Junior
    2015 SR
    None
    Does your 3rd generation SR (2014+) have pressure tire sensor?
  2. Jun 18, 2018 at 7:46 AM
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    yes
    NewTundra[OP] likes this.
  3. Jun 18, 2018 at 7:50 AM
    NewTundra
    Junior
    2015 SR
    None
    I'm buying some Toyota rims from someone. Nicer than the one that come with the SR model. If the ones I'm buying don't come with the sensor, do you think I could keep using the one's that are on the truck?
    Or how does the whole thing work?
    Or should the truck read the pressure with thr sensor on the truck?
  4. Jun 18, 2018 at 8:00 AM
    Help New Member
    Tucson, AZ
    You can have the old sensors switched to your new wheels. Any halfway decent tire shop should be able to do that w/o any issues. You can buy new sensors if you dont want to pay to have the shop pull the old ones out, but there's no point in doing that if you're keeping your tires
  5. Jun 18, 2018 at 8:02 AM
    blizz86
    blizz86 New Member
    If your truck came with the stock steel wheels and you're getting alloy wheels, you should get the 20degree TPMS wheels made for allow wheels. The steel wheels use 40 degree tpms sensors that are not designed for use with allow wheels - you wont get a good seal between the sensor and wheel, and if you rotate them to fit, they may break.
  6. Jun 18, 2018 at 2:40 PM
    NewTundra
    Junior
    2015 SR
    None
    Not sure which are steel and alloy.
    But i think that's what i have, unfortunately.
    Do you think the chance is high on it breaking? Ki d of want to take the chance
  7. Jun 18, 2018 at 4:02 PM
    blizz86
    blizz86 New Member
    if you have pictures, itll help
    steel -
    https://images-na.ssl-images-amazon.com/images/I/51gQS+wIwYL.jpg
    alloy -
    https://www.hubcaphaven.com/mm5/graphics/00000001/tundra_2014_trd_rim_lg.jpg
    Anywho i wouldn't recommend it. its highly likely they will leak air where the sensor and wheel mates.
    just get a set of tpms off ebay for $50, otherwise you likely have to pay to dismount and remount the tire if it does leak down the road.
    NewTundra[QUOTED][OP] likes this.
  8. Jun 18, 2018 at 4:16 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I changed out my 2015 SR rims for Toyota rims and used my original TPMS sensors from the steel rims and have never had a problem .
  9. Jun 18, 2018 at 4:32 PM
    NewTundra
    Junior
    2015 SR
    None
    How long have you had them?
  10. Jun 18, 2018 at 4:34 PM
    Scpringle
    Jackson MS
    3 years , and the sensors work , I have had several nails and it lets me know when they get low
