2018 PLATINUM CM 4x4 Build
Discussion in '2.5 Gen Builds (2014-2021)' started by atrinh15, Apr 5, 2018.
  1. May 8, 2018 at 6:58 PM
    atrinh15
    atrinh15 [OP] New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    My tonneau cover came in from Ebay.
    Not the greatest but its solid tri fold and works.
    Packaged good
    Daylight shining through
    Solid top
    OceanSkyWolf and Jsena like this.
  2. May 9, 2018 at 7:36 PM
    atrinh15
    495-93 area
    Had the Autobahn put on today
    Already have a couple of chips in the front end
    DD370DDD-9F9F-46DB-B0F7-A0A925914362.jpg C9D500FB-E875-4689-ADA4-D4DAAFA36311.jpg
    Jsena likes this.
  3. May 9, 2018 at 7:48 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    Sick lookin truck! Keep it comin!!!
  4. May 9, 2018 at 8:49 PM
    atrinh15
    495-93 area
    Thanks i need more time in the day so i can get more done
  5. May 14, 2018 at 7:38 PM
    atrinh15
    495-93 area
    So my power steps came in. Cant wait to do the install
    These are not Amp steps. They are another version from China.
    Jsena likes this.
  6. May 14, 2018 at 7:39 PM
    atrinh15
    495-93 area
    Omohundro and WarEagle Tundra like this.
  7. May 15, 2018 at 10:13 AM
    MGMTUNDEE
    MGMTUNDEE New Member
    Quacky
    Tampa
    What type are these? I want to get amp steps but cant justify spending that much on them.
  8. May 15, 2018 at 10:32 AM
    atrinh15
    495-93 area
    Yea i couldnt eat the price on the Amp either. They also make a Bestop power step. Which is a little less.
    These are by Wooden company out of China that supplies them too over seas. Its suppose to be plug and play as well as the Amp but i have an 2018 so we will see if i have the same problem.
  9. May 18, 2018 at 5:23 PM
    atrinh15
    495-93 area
    Got my boards on today. Super excited love them. Just need to do a final adjustment to make them even front to back.
    E2E7D0E1-4AFB-4745-8924-1E80140ECC69.jpg 2BE63F0B-733D-4D1C-B943-C5549517C777.jpg
    Omohundro and MGMTUNDEE like this.
  10. May 22, 2018 at 2:15 PM
    atrinh15
    495-93 area
    Got a chance to install my flip down screen.
    0F0F65EB-E177-4406-BD8E-4349E01918FD.jpg 2127F5CA-8859-4EB8-9BEC-2E164A078CDA.jpg
  11. May 22, 2018 at 3:16 PM
    Nice build
    atrinh15[OP] likes this.
  12. May 22, 2018 at 3:58 PM
    atrinh15
    495-93 area
    Thanks def need to get my level kit in.
  13. May 23, 2018 at 12:38 PM
    atrinh15
    495-93 area
    My 6 way Fuse block came in. Im going to run a 8 gauge wire straight from the battery to the drivers kick panel. This will feed my power running boards and flip down screen.
  14. May 29, 2018 at 7:08 AM
    atrinh15
    495-93 area
    Got my sway bar sanded down and repainted.
    65968FA3-8ABD-4DD4-93AF-2DE5F479E0D9.jpg 91E06DDB-239C-42F8-A328-DB9D57AE7C2B.jpg
  15. Jun 16, 2018 at 8:18 PM
    atrinh15
    495-93 area
    So I wanted to do the install of my leveling kit. But with no time had a buddy of mine do it at his shop.
    Before:
    Alignment :
    Washed and tire shine
    Side:
  16. Jun 16, 2018 at 8:39 PM
    MGMTUNDEE
    Quacky
    Tampa
    truck is looking might fine my man! I love the setup!
  17. Jun 16, 2018 at 8:44 PM
    atrinh15
    495-93 area
    Thank you sir. Def coming along.
  18. Jun 22, 2018 at 6:39 AM
    atrinh15
    495-93 area
    Rubbing on the liner and mud flaps.
    I pushed the front liner forward with drilling new holes and still had to use a torch and hammer to push in the liner. Now no rubbing in the front but need to remove the mud flaps
    New holes
    Omohundro and OR18TRD like this.
  19. Jul 10, 2018 at 7:56 AM
    atrinh15
    495-93 area
    Got my TRD CAI installed today thanks
    @Toyotoholic
    Before
    After
    Omohundro and Toyotoholic like this.
  20. Jul 10, 2018 at 12:29 PM
    #50
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Sweet!
  21. Sep 4, 2018 at 5:41 PM
    #51
    atrinh15
    495-93 area
    I got Fisher push plates on my truck. I buy and sell plows so this was a must. Now i need to wire it up.
    Omohundro likes this.
  22. Dec 19, 2018 at 6:42 PM
    #52
    atrinh15
    495-93 area
    Been a while since i posted. But ive had my truck since 04/17/18 and now have 20k miles on my truck. I drive a lot.
    Threw some snow tires 275/65/20 on my stock wheels. And just added a remote starter with drone. Ill update with some pics soon.
  23. Dec 19, 2018 at 7:42 PM
    #53
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    More info on this please and the install.
  24. Dec 20, 2018 at 4:01 AM
    #54
    atrinh15
    495-93 area
    Its not the best unit but def works and does the job. When cold it skips until warmed up. Doesnt shut off when you close the screen. Mainly little things. Overall i wouldnt buy it again spend a little more and get something better. But will do until dies.
    Install was pretty easy. I made no holes in my headliner just incase i want to put my truck back to stock. Comes with a metal plate and mounted it with in the factory light. I made a video.
    https://youtu.be/GuXJcE_ZvKs
  25. May 4, 2019 at 12:46 PM
    #55
    atrinh15
    495-93 area
    Been super busy and needed to post some pics i took with the snows.
    Mastercraft Snows
    275/65/R20
    Heres my Fisher 7.6 V Blade
  26. May 23, 2019 at 11:37 AM
    #56
    atrinh15
    495-93 area
    Had Phantom Lord make me a TSS bracket to fix my sensor. Installed and now i can see if they can shut this light off.
  27. Jun 2, 2019 at 8:37 PM
    #57
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    2023 TRD PRO
    Nice build! How are these working out a year later?
  28. Jun 3, 2019 at 3:53 AM
    #58
    atrinh15
    495-93 area
    Honestly great. I have no complaints so far. They lasted through a New England winter with the snow and salt. So only time will tell.
  29. Jun 4, 2019 at 10:22 AM
    #59
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Is this error due to the Ready Lift 3/2?
  30. Jun 4, 2019 at 10:45 AM
    #60
    atrinh15
    495-93 area
    Yes. I lifted the truck 3” and put 34.5 tires. And kicked the light on. I met some guys who did the same and had no light.
