  1. Jun 15, 2018 at 10:51 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Pudge likes this.
  2. Jun 15, 2018 at 10:54 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    K tnx for info. I'm already wired for aux lighting in back by both reverse and in cab switch. Just got to figure out what I'm going to put back there. A cheap temp under rear bumper, or go all out on some Baja designs squadrons or s2 into a permanent mount position.
    I can see for miles with the 2 pods I have in the tow hitch now. However, I'm pretty sure I will be selling in very near future since I just dropped price to $200 for the whole setup. I've been spending the last 4 hrs answering questions on fb about it to people saying they interested in buying my setup. Yes the 1 I just installed days ago and hating myself for having to sell it now.
    Baja Mike[QUOTED] likes this.
  3. Jun 15, 2018 at 10:59 PM
    Baja Mike
    South Bay, Ca.
    I'd get better reverse lights first, like those ones, then see where you need to go from there. Those might be all you need.
    mgm16trdpro[QUOTED] likes this.
  4. Jun 15, 2018 at 11:11 PM
    Baja Mike
    South Bay, Ca.
    Holy crap, those are better than the stock halogen bulbs.
  5. Jun 15, 2018 at 11:12 PM
    mgm16trdpro
    Northern NJ
    I don't know how much they gonna help though when I already got this tinted section. That plus already having wiring done makes me think don't waste on stock housing reverse bulb, spend on lights to already ran wires. Now that I was able to put truck in park, get out, and walk back to trailer to unhook everything at night and being able to see everything as if it was day, is a feature I'm not willing to give up by simply pushing the in cab switch. I got it hooked both to come on in reverse and by push button. After having this option to light up the night behind me and still get out truck in park, is something that is huge for me. Now I got a taste I can't give that up.
  6. Jun 15, 2018 at 11:16 PM
    Baja Mike
    South Bay, Ca.
    Sounds like you already know what you want. ;)
  7. Jun 15, 2018 at 11:26 PM
    mgm16trdpro
    Northern NJ
    Yeah not a fair comparison, all that light is coming off the 2 pods in the tow hitch. U can see it in top pic. The bottom pic tinted reverse does not help getting light back there. The last pic is the reason I must sell it. Look at my rear tire tucked in. There is a heavy dose of this type of towing for me. It don't help to tow in these terrains with a good size drop. On road it was perfect, off u can now see how likely it would be for me to drag the shank or even worse get caught up, bend metal ect...
    darkknight2014 likes this.
  8. Jun 15, 2018 at 11:32 PM
    mgm16trdpro
    Northern NJ
    For sure I do, only question is put in a cheap temp for now and upgrade when better time financially. Or do it right once and figure out how to pay for it later. Not usually my style.
    geno0506 and HecticEnergy like this.
  9. Jun 16, 2018 at 5:29 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I figured the new bulbs I got were good enough. And I needed money for my 2018 led headlights lol. I'll tell you that they seemed well built and solid but after seeing your pic of those hitch lights....you'll want better ones than what I got. I doubt they'd be half as bright as what you're replacing
  10. Jun 16, 2018 at 11:20 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
  11. Jun 16, 2018 at 11:23 AM
    Pudge
    CT
    Me too. blue tundras unite !!
  12. Jun 16, 2018 at 11:33 AM
    15whtrd
    15whtrd Mr. Blonde
    Not sure what the window track that the glass lays in looks like on these trucks. But I had an issue similar to that in my 64 olds. I pinched the track a little tighter before squeezing the piece of rubber and glass into it. I think I used a glue but I can’t remember. I want to say it was some type of RTV glue. Maybe specific for windows and glass.
  13. Jun 16, 2018 at 11:40 AM
    It's super easy to take apart on ours, the window sits on two black plastic clips that are clipped to a scissor bracket in those black clips filled with some type of hard rubber glue, the window came undone from that, so I went to a auto store and got a 5 or 10 min black epoxy, held til yesterday, 1st time it happened a month or two ago
    geno0506 likes this.
  14. Jun 16, 2018 at 11:45 AM
    15whtrd
    15whtrd Mr. Blonde
    I think you need something super sticky but flexible.
  15. Jun 16, 2018 at 11:50 AM
    Ther a Safelite few miles done from me, see if they can sell me something or what I can get
    HecticEnergy and 15whtrd[QUOTED] like this.
  16. Jun 16, 2018 at 1:10 PM
    wrtnaz
    wrtnaz New Member
    Tucson, Az
    2018 MGM Tundra SR5 CrewMax
    Wireless Charging Center Console Tray 6 3/4" Antenna Mast OEM Bed Mat Weather Tech In-Channel Low Profile Wind Deflectors Chrome Mirror Caps/Handles Limited Grill w/Chrome Surround Ionic 5" Oval Stainless Step Bars Center Console 110v and USB Power Converter Black Tundra Door Sill Protecters Undercover Swing Case Wireless LED Bed Light Strip Toyota Chrome Exhaust Tip 18" TRD Wheels
    Well I bought my '18 Tundra 3 weeks ago and have slowly got a few things done.
    1. Installed OEM Tundra bedmat
    2. Switched out antenna for 6.75 stubby
    3. Added console tray
    4. Switched stock SR5 honeycomb grill to Limited chrome grill
    5. Switched stock flat black door handles to Limited chrome handles
    6. Added Weather-tech in-channel wind deflectors
    Still to do...
    -Switch stock mirror covers to chrome covers
    -Add flat black distressed flag decal to both sides
    Wanting to do when :spending:allows...
    -Drivers O-Shit handle
    -Step sides
    -Change wheels and tires
    -Tonneau Cover
    -CAI
    -Rear sway bar
    -Autostart
    -Spray-in bed liner
    -Bed rails
    Before
    After
  17. Jun 16, 2018 at 1:11 PM
    Noice!
  18. Jun 16, 2018 at 2:50 PM
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Are you interested in getting rid of the black handles?
    I may be interested in trading my chrome mirror caps for your black ones.
    wrtnaz[QUOTED] and Pudge like this.
  19. Jun 16, 2018 at 3:38 PM
    SIXSEVENONE
    SIXSEVENONE Island BASTRD
    Shane
    East Bay, CA
    2015 Super White CM Limited
    White Knuckle Baby. Passengers side done. Going to do the drivers side after a sandwich.image.jpgimage.jpg
  20. Jun 16, 2018 at 3:51 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Newm, JoshuaA, cjmay13 and 10 others like this.
  21. Jun 16, 2018 at 3:59 PM
    Vizsla
    Vizsla 2 = 2.5
    Just turned 2k miles, and decided to make some changes:confused:. Not much done today, this will take a week or so. Replacing bumper light bar with 32” 180w dual control light to match the ditch lights, and new black bumper ends. Wednesday starts stage one of my front suspension upgrade, Fox extended travel coilovers, and TC adjustable heim uppers. Stage 2 won’t be done till late summer/fall, secondary mounts with bypasses.:)
    New light bar
  22. Jun 16, 2018 at 4:35 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Installed door edge protection film. 49C842AA-8062-4494-8391-AF33FD6F53E4.jpg
  23. Jun 16, 2018 at 4:47 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Looks good
  24. Jun 16, 2018 at 4:48 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Looks good!!
  25. Jun 16, 2018 at 4:51 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    040Tundra, Newm, JoshuaA and 11 others like this.
  26. Jun 16, 2018 at 5:00 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    ooooooooo!!!! Looks sexy!!!!
  27. Jun 16, 2018 at 5:13 PM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    did you use the 3M tape? or another brand?
  28. Jun 16, 2018 at 5:20 PM
    Midnite72
    Northern MD
    18 SR 5.7 4x4
    6913B64D-EE38-4847-9B0D-0FC89C6504FE.jpg Custom Kawasaki green accents
    Inside and out!- yea I bleed GREEN!
    Got tailgate letters on line then wrapped in Kwai green!- took rubbings of everything else and had custom graphics made
  29. Jun 16, 2018 at 5:23 PM
    Midnite72
    Northern MD
    18 SR 5.7 4x4
  30. Jun 16, 2018 at 5:24 PM
    Midnite72
    Northern MD
    18 SR 5.7 4x4
