JBA LT + Deeds 6”
Discussion in '2.5 Gen Tundras (2014-2021)' started by yoneytan, Jun 12, 2018.
  1. Jun 12, 2018 at 11:18 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    I recently installed the dirty deeds 6” muffler and considering LT headers. I see them listed on eBay for around $600. I’m curious to know if that’s all I need or are there additional parts necessary? I’ve read that Keith charges roughly $3k for the entire setup that adds around 50whp and wondering what more than long tubes does it take to achieve those gains.
  2. Jun 12, 2018 at 11:33 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    50 HP is huge!
  3. Jun 13, 2018 at 1:27 AM
    CaptainJohnnySR5
    CaptainJohnnySR5 Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
    $3,000?? I heard $1,200. If 8m wrong and its $3k I will be getting something else. No offense to Keith. Let me know.
  4. Jun 13, 2018 at 3:49 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    You will need new mid pipes. If you buy the JBA mid pipes, you loose cats and will either need O2 simulators or a DAP tune and have Dustin disable/hide the code that will be thrown by not having cats. Other option is to send Keith your cats and he can build a custom mid pipe section using them and you will not have code issues. That is the route I am going to go one day.
    Black Wolf and Pudge like this.
  5. Jun 14, 2018 at 10:42 PM
    yoneytan
    Asi
    14 CM
    While 50hp is great its definitely not "huge" and a bit tough to justify at the $3k cost. On my E63 i gained nearly 180HP and 218FT-LB for $3500, now thats "HUGE". With that said DP's for my E63 would gain about 30HP at a cost of anywhere from $2000 all the way to $4500. Not justified and the reason I didn't do them. Now, If I can install JBA LTH for under $1k(i already have DD 6" system) and gain those 50 ponies I can say its justified but not for $3k.
    trayday likes this.
  6. Jun 14, 2018 at 11:46 PM
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    Whay the hell is E63???? 180 hp?? Wtf?
  7. Jun 14, 2018 at 11:48 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Benz based on my google searching :)
  8. Jun 15, 2018 at 6:01 AM
    Cfincke
    San Antonio
    Give Keith aka @dirtydeeds a call, he sells the JBA headers and can build you mid pipes, using your cats or with new aftermarket cats. From when I talked with him, he recommends reusing the Toyota factory cats if possible.
    Black Wolf likes this.
  9. Jun 15, 2018 at 6:40 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    It's also close to 90 lbs of TQ, reason I also bought the JBA back. The whole exhaust is 3" mandrel bent with the secondary cats in place of the primary cats, secondary cats usually flow better than original primary cats.
  10. Jun 15, 2018 at 7:54 AM
    yoneytan
    Asi
    14 CM
    thats correct.
  11. Jun 15, 2018 at 7:56 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    SullyMoto19 likes this.
  12. Jun 15, 2018 at 7:59 AM
    yoneytan
    Asi
    14 CM
    :rofl::rofl::rofl:
