WHATS YOUR PAYLOAD RATING
Discussion in 'Towing & Hauling' started by DBL TAP, Mar 30, 2016.
  1. Mar 30, 2016 at 4:57 PM
    DBL TAP
    DBL TAP [OP] Light 'em up
    USA
    My Pro has a lower payload rating (1240 - 55) of 1185 lbs. I knew this going in, so not complaining. I've visited several dealerships and I have yet to see a Tundra, Pro or otherwise, with a payload over 1320 lbs?
    Checked CM's and DC's. The only configuration that I haven't checked is a reg cab long bed. If there's a payload over 1400 lbs., then it's probably going to be the reg cab. What's your payload?
  2. Mar 30, 2016 at 5:12 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    1520 lbs.
  3. Mar 30, 2016 at 6:17 PM
    DBL TAP
    USA
    Thanks. Guess I should have also asked, "what cab configuration?"
  4. Mar 30, 2016 at 6:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    2011 RCSB 5.7L lol
    DBL TAP[QUOTED][OP] likes this.
  5. Mar 30, 2016 at 7:03 PM
    1370 lbs. 12' CM
    Then again, I hardly ever load anything in my bed. That is what my trailer is for.
  6. Mar 30, 2016 at 7:09 PM
    DBL TAP
    USA
    So what does your trailer weigh?
  7. Mar 30, 2016 at 8:20 PM
    Without the spare tire it was 2700 lbs. With the spare tire and other accessories/add on's it is close to 2900 lbs.
    DBL TAP[OP] likes this.
