Cargo light bulb popped - Help!
Discussion in 'Lighting' started by Les7311, Nov 19, 2017.
  1. Nov 19, 2017 at 12:21 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Ok I messed up. Shouldn’t have used a pliers to remove the cargo light bulb.... blah blah blah!!!
    What’s the best way to get the remnance of the bulb-base out of this socket??
  2. Nov 19, 2017 at 12:44 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Mini needle nose pliers and a dental hook should get it out of there.
    Les7311[OP] likes this.
  3. Nov 19, 2017 at 1:09 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    This!
  4. Nov 19, 2017 at 1:31 PM
    Les7311
    Nope.
    I will have to get to the base.
    Needle nose of no help
    Dental pick...... maybe.
    The base of the bulb is almost flush with the contacts so nothing to grab into
    I will have to do without an extra cargo light
  5. Nov 19, 2017 at 2:30 PM
    ACE hardware store shud carry dental pick...what about taking whole light housing off ???
  6. Nov 19, 2017 at 2:40 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I'd use needle nose pliers. I did the same thing on the interior lights. If that doesn't work just use liquid nails and sheetrock screws that always fixes stuff for me.
  7. Nov 19, 2017 at 3:06 PM
    Les7311
    I may have to drop headliner then unbolt to do surgery.
    I will take all advice under advisement before taking housing out completely
    Look at last half of youtube how to remove cargo assembly.
    https://youtu.be/FV0RDoK4s0w
    For my peeps so you don’t have the same problem as I did, use this method to remove cargo bulb........
    https://youtu.be/gLb36MJJuUY
  8. Nov 19, 2017 at 3:16 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Superglue or jbweld on a toothpick stuck into remaining part of bulb socket should get it out.
  9. Nov 19, 2017 at 3:20 PM
    Les7311
    The top of the bulb is all the way to the edge of the base where the connectors are. JB ay not be an option......
  10. Apr 19, 2018 at 4:28 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I know it's an old thread, but I just did this exact thing last night. I even had a nice pair of rubber tipped pliers specifically for bulbs, designed to grab around the bulb to the base. Both bulbs broke flush with the housing, I was being mindful of this because I knew that others have had issues with these bulbs specifically.
    Ended up using an offset pick and a 90 degree pick to dig the remainder of the bulb out. Not the end of the world, but complicated an otherwise easy task.
    I've only ever had 1 other bulb break like that. The bulbs were able to move in the housing and were not seized or corroded.
    I swapped the stocks for a set of LED's. The bed is now filled with light when I need to find something at night.
    Les7311[OP] and ColoradoTJ like this.
  11. Apr 19, 2018 at 4:42 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Might be able to put some string with a half hitch knot or other self tightening knot. Just an idea.
    Les7311[OP] and OBXTundra like this.
  12. Apr 19, 2018 at 4:48 AM
    Les7311
    I currently have one bulb bust at the base and had planned on replacing the 3rd brake light altogether.
    Have a pic of your bulb pic tool?
  13. Apr 19, 2018 at 4:53 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    After the bulb broke it really only took about 2 minutes per bulb to get the rest of it out of the housing. Not a big deal if you have a pick, just dig it out. The below picture is the set that I have in my toolbox, standard pick set.
  14. Apr 19, 2018 at 5:08 AM
    Les7311
    Thanks.
    I may have to spray WD40 since bulb base could be seized up.
    Planning surgery for this weekend
  15. May 31, 2018 at 1:35 PM
    Les7311
    Finally completed the surgery, and worked as you explained.
    The 2nd buld, I used the “tie-string-around-tooth” method.
    Am a happy Lark
    Thank you for this tool suggestion
    OBXTundra[QUOTED] likes this.
  16. Jun 11, 2018 at 7:46 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I know you posted this a while ago, but do you have a link for the LEDs? you just replaced the bulbs with LEDs or did you replace the whole housing too?
  17. Jun 11, 2018 at 7:53 AM
    tundraj
    tundraj New Member
    HecticEnergy[QUOTED] likes this.
  18. Jun 11, 2018 at 8:33 AM
    53Snipe
    53Snipe New Member
    Chuck
    NorCal 707
    2015 Blue Ribbon Metallic Tundra Limited Crewmax TRD
    RevTek 2.5" Leveling Kit, basically replaced every light bulb with LED. Otherwise completely stock.
    I bought, and replaced every light with LED's for my 2015, from Headlight Revolution and it took two months and 4 shipments for them to finally fill my order. They don't tell you things are backordered unless you actually call them to find out what's going on.
  19. Jun 12, 2018 at 10:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    yep, the Leds in the cargo light are great. I can use the cargo light to light up my drive and locate my newspaper.
    tundraj likes this.
