Black wheel cleaning
Discussion in 'Detailing' started by Erichudgins, Jun 9, 2018.
  1. Jun 9, 2018 at 11:55 AM
    Erichudgins
    Erichudgins [OP] New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    What are you guys using on your tires that doesn't streak or spot your mate black wheels?
  2. Jun 9, 2018 at 1:54 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    I use the same soap that i wash the truck with but after i use compressed air to blow the rims down along with door handels, mirrors, and those fricken platinum badges that hold about a gallon of water.
  3. Jun 9, 2018 at 2:23 PM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    I do the same but use a leaf blower to dry everything
    Erichudgins[OP] and driverdog like this.
  4. Jun 9, 2018 at 2:27 PM
    ZPMAN
    Minnesota
    Now thats thinking! Only thing is I'm a cheep Finnlander and don't have a leaf blower. Lol
    driverdog likes this.
  5. Jun 9, 2018 at 5:55 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I’ve used both compressed air and the leaf blower. Both work well
  6. Jun 9, 2018 at 6:05 PM
    ZPMAN
    Minnesota
    Do you have your own power washer?
  7. Jun 15, 2018 at 12:33 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    No I usually stroll through the local was and then go home and spray detail from there. I just dont use the tire cleaner on the tires because of the rear of streaking the wheels.
  8. Jun 20, 2018 at 5:07 AM
    briarpatch
    briarpatch New Member
    Try taking a spray bottle of distilled water and misting your wheels prior to cleaning the tires. That should keep any of the tire cleaner from drying on the wheels. When your tires are clean, make certain you rinse thoroughly. After you clean your wheels, coat them with McKees Wheel Coating and I think your problem will be solved.
  9. Jun 20, 2018 at 5:15 AM
    War Machine
    War Machine SSEM # 5 3MW
