So I plasti-dipped the shifter surround
Discussion in '2.5 Gen Tundras (2014-2021)' started by Donski17, Jun 5, 2018.
  1. Jun 5, 2018 at 11:17 AM
    Donski17
    Donski17 [OP] New Member
    Donald
    Jacksonville, FL
    2017 Blazing Blue Tundra 4X4
    So after deleting the chrome on the cup holder, the chrome around on the shifter surround had to go. First attempt I learned that I taped to closely (first venture into plasti-dipping). That resulted in some pealing off the chrome, so then I watched a video and learned it was too close my second time came out a bit better, but still think it can be better. The underside has 4-6 plastic welds on it. Thinking I may remove those and drop the chrome price out completely, dip it and then get some plastic weld to reinstall. Anyone attempt this? And if so is it as simple as it seems in my head?
  2. Jun 5, 2018 at 11:23 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I don't think taking off the plastic welds will be as easy as it seems, if something didn't go right then, you're screwed. I would def not take it out just to plastiDip...
  3. Jun 5, 2018 at 11:43 AM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    I did the same way with the same results. As long as the chrome is gone, I'm happy.
  4. Jun 5, 2018 at 3:10 PM
    Donski17
    Donald
    Jacksonville, FL
    Yeah I have a feeling it’s not as easy, but I somehow scratched the cover when I had it off and was dipping it. So I may look to order a replacement, and then experiment on the scratched one.
  5. Jun 5, 2018 at 3:11 PM
    Great job! Looking to do myself
  6. Jun 5, 2018 at 3:18 PM
    Nickhood23
    Nickhood23 New Member
    Murfreesboro, TN
    2012 SR5 CM SUPER WHITE
    Dipped mine when I first got it cause it had some scratches
    Donski17[OP] likes this.
  7. Jun 5, 2018 at 3:34 PM
    Found a way to take chrome piece off but super glue will be involved
    Didn't feel like doing all that tape
    WarEagle Tundra and 1UPPER like this.
  8. Jun 5, 2018 at 3:54 PM
    Donski17
    Donald
    Jacksonville, FL
    So those little plastic welds I was referring to, you got them off obviously. How did you go about doing it. Then you just super glued it back on?
  9. Jun 5, 2018 at 4:07 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I’ve also done the plasti dip on this part before. For me it didn’t hold up as well as I would have liked. This time I’m going to spray it with permanent paint. That chrome is so bad when the sun hits it.
  10. Jun 5, 2018 at 4:09 PM
    Used a sharp chisel to take plastic welds off and push out and it kinda snaps back but I will use either super glue or epoxy
    MotoTundra likes this.
  11. Jun 5, 2018 at 4:10 PM
    Yeah I didn't Plasti dip, I used flat black rattle can paint for plastic
    1UPPER[QUOTED] likes this.
  12. Jun 5, 2018 at 4:11 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Sounds good! I would avoid the super glue since it leaves a white residue.
  13. Jun 5, 2018 at 4:12 PM
    Yeah I have some black epoxy stored somewhere
    Donski17[OP] and 1UPPER[QUOTED] like this.
  14. Jun 5, 2018 at 4:58 PM
    Donski17
    Donald
    Jacksonville, FL
    I think I’m going to go ahead and go this route. The plasti looks pretty good, but I think popping it out and painting it will look a lot better. Probably gunna do that this weekend when I can dedicate some time to it.
  15. Jun 7, 2018 at 9:24 PM
    Copelin127
    Copelin127 New Member
    James
    2017 Barcelona Red Tundra Crew Cab
    I read somewhere a guy used a soldering iron to melt the plastic rivets out.
  16. Jun 8, 2018 at 3:03 AM
    Adam New Member
    @Copelin127 , your profile pic is what I was thinking of doing with mine. Red on the vent surrounds and around the shiftier. You got any more pics?
  17. Jun 8, 2018 at 4:11 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Interesting....
    :popcorn:
  18. Jun 8, 2018 at 6:29 AM
    Copelin127
    James
    I didn’t take many pics but this is what I have:
    03A83A33-130B-4147-B8D2-284D700B39BF.jpg FEFF5D89-42AC-414C-8FD8-386FF939768B.jpg 383E2F8F-A6B3-4D33-9029-793510067695.jpg
    Adam, sprtbkr and TXRailRoadBandit73 like this.
  19. Jun 8, 2018 at 6:32 AM
    Copelin127
    James
    I’m going to do the chrome around the shifter next.
  20. Jun 8, 2018 at 6:34 AM
    Copelin127
    James
    I used paint as well. Color match dupli color with primer and clear coat.
  21. Jun 8, 2018 at 6:40 AM
    Great job
    Copelin127[QUOTED] likes this.
  22. Jun 8, 2018 at 7:44 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Love that, but seems like a lot of work for me!
  23. Jun 8, 2018 at 7:57 AM
    scgrab21
    scgrab21 New Member
    Maryland
    Tundra CM | Limited | TRD | Cement
    how did you get the cup holder surround trim piece off?
  24. Jun 8, 2018 at 7:11 PM
    Donski17
    Donald
    Jacksonville, FL
    I just used a small flat head screwdriver and carefully lifted around it. The clips popped out pretty easily
    Copelin127 likes this.
  25. Jun 8, 2018 at 7:12 PM
    Donski17
    Donald
    Jacksonville, FL
    Looks great man. The AC rings are on my to do list also. Just gotta find a color match spray for my blazing blue
  26. Jun 8, 2018 at 7:38 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I first did Autodip, my wife took the truck out and somehow chipped it, the cup holders really bad lol. So I peeled it off the holders and leaving it off for now, redid the surround in Plastidip.
    ... and I got a new wife
  27. Jun 9, 2018 at 2:34 AM
    Adam New Member
    Good god man. Looks like you did it at work to boot. BALLER!
  28. Jun 9, 2018 at 5:17 AM
    scgrab21
    scgrab21 New Member
    Maryland
    Thanks! That sounds like something I might be able to handle.
  29. Jun 9, 2018 at 5:19 AM
    scgrab21
    scgrab21 New Member
    Maryland
    :ohsnap:
  30. Jun 9, 2018 at 7:09 AM
    DustinP5
    DustinP5 New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    Whenever I get around to doing this, I’m using paint as well, not a fan of plastidip
