TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Socal_tundradude, Jun 8, 2018.
  1. Jun 8, 2018 at 11:30 AM
    Socal_tundradude
    Socal_tundradude [OP] New Member
    Ali
    2016 sr5 crew max tundra
    Hey! First post on here. Hope y’all are doin well. I just purchased a Trd sway bar for the rear of my truck. I have a 6 inch pro comp lift on my truck. Do I have to get my end links extended and if so can I just purchase new end links rather than having to fabricate and weld new ones together?
    Thanks in advance!!
    15whtrd and TXRailRoadBandit73 like this.
  2. Jun 8, 2018 at 11:31 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Socal_tundradude[OP] likes this.
  3. Jun 8, 2018 at 11:34 AM
    Welcome from Texas, I'm on a 6" RC lift on 35's with 20" wheels my RSB fits fine
  4. Jun 8, 2018 at 11:38 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Las Vegas
  5. Jun 8, 2018 at 11:39 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  6. Jun 8, 2018 at 11:41 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    You might try rotating the swaybar mounts so they're on the back of the axle instead of the bottom.
  7. Jun 8, 2018 at 11:43 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    Stock is fine. When I had my 7" installed with rear blocks, the shop just rotated the bar so it sat towards the top of the differential instead of the bottom. If replacing the leaf pack and w/o blocks, custom length ends will probably need to be made.
  8. Jun 8, 2018 at 11:54 AM
    15whtrd
    15whtrd Mr. Blonde
  9. Jun 8, 2018 at 2:17 PM
    Socal_tundradude
    Ali
    Thank you all for the response!! Very helpful! Lol I have the special TED edition sway bar. @15whtrd
    15whtrd likes this.
  10. Jun 8, 2018 at 2:20 PM
    15whtrd
    15whtrd Mr. Blonde
    Hahaha I was just clowning you man. Welcome, you have been initiated!
    I’ll keep an eye out for you around town.
  11. Jun 8, 2018 at 2:24 PM
    Socal_tundradude
    Ali
    It’s all good brotha. I got a good laugh from it myself. Thanks man @15whtrd
    15whtrd likes this.
